Help with millis()
When I power on the arduino, the Millis will not let the code run for the first time until after my long interval, in this case it is 10000ms. I need the code to run first then deny it to run until after the long interval.
I was going to go with a simple delay() but Millis seems like it would be a better option.
Im stuck please help!
Here is my code:
#include <Servo.h>
const int button1 = 4; //button pin, connect to ground to move servo
const int switch1 = 10; //switch pin
int ledPin =  13;      // the number of the LED pin
int press1 = 0;
int switchon = 0;
Servo servo1;
long previousMillis = 0; //store last time code was ran
long interval = 10000; //interval to run code
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  pinMode(button1, INPUT);
  pinMode(switch1, INPUT);
  servo1.attach(7);
  digitalWrite(4, HIGH); //enable pullups to make pin high
  digitalWrite(10, HIGH); //enable pullups to make pin high
  press1 = digitalRead(button1);
  switchon = digitalRead(switch1);
  if ((switchon == LOW) && (press1 == LOW))
    digitalWrite(ledPin, HIGH);
    servo1.write(10);
    delay(800);
    servo1.write(170);
    delay(3000);
    digitalWrite(ledPin, LOW);
//3HOUR LIMIT ON BUTTON PRESS
  unsigned long currentMillis = millis(); //check to see if it is time to run code
  if ((switchon == HIGH) && (press1 == LOW) && (currentMillis - previousMillis > interval))
previousMillis = currentMillis; //save the last time the LED blinked
You used quote tags, please use code tags instead. What's this talk of millis()? What I see are a lot of delay() calls. Get rid of them.
If you want to be able to execute "blink" code immediately, the trick is to set interval to 10000 in the "blink" code. In setup() you should set it to 0.
aarg:
Sorry about the quote tags, fixed.
You see the delay(1000) to make the led blink. this led is temporary so i can easily verify
works before i:
    servo1.write(10);
    delay(800);
    servo1.write(170);
    delay(3000);
Okay, so does that mean that your problem is solved, or not? What do you mean, "works before i"?
THANK YOU so much for you input but no the problem was not solved. i will rephrase my question....
What i want is for the arduino board to power on and allow a button press and run code, THEN check to make sure "long interval = 10000" time has passed BEFORE allowing another button press.......
Currently the board powers on and FIRST checks to make sure "long interval" time has passed then it will allow a button press and code run and that is not the order i want it to go obviously.
once again thank you for you help and please excuse my poor explaining and even worse coding skills.
#include <Servo.h>
int press1 = 0;
int switchon = 0;
Servo servo1;
  pinMode(ledPin, OUTPUT); //initialize the LED pin as an output
  pinMode(button1, INPUT); //initialize the button as an input
  pinMode(switch1, INPUT); //initialize the switch as an input
  servo1.attach(7); //attach servo to pin 7
  press1 = digitalRead(button1);    //read button press
  switchon = digitalRead(switch1);  //read switch
  if ((switchon == LOW) && (press1 == LOW)) //if switch is off and button pressed, run code
    digitalWrite(ledPin, HIGH);  //turn on led
    servo1.write(10);            //move servo to 10 deg
    delay(800);                  //wait for servo to reach angle
    servo1.write(170);           //move servo to 170 deg
    delay(3000);                 //wait for servo to reach angle
    digitalWrite(ledPin, LOW);   //turn off led
previousMillis = currentMillis; //save the last time the code was ran
That is nonsense. Ignoring switch presses for some interval is NOT the same thing as not ALLOWING them. There is nothing you can do to PREVENT the user from pressing the switch. Whether you do anything about it, or not, is up to you.
Now, perhaps you can look at the blink without delay example, and see that you need to keep track of when the switch was last pressed, and see that you need to compare that time to now, to see if it is again time to care about whether or not the switch is pressed.
PaulS:
+1
You should also see how using any delay()'s at all will completely wreck that method.
PaulS:
That is nonsense.
+1 constructive criticism, much welcomed and needed
PaulS:
That is where I originally got the idea to do this.
aarg:
+1
I am thinking since i cannot grasp this i will only use delay. Hopefully (im pretty sure it is stored as an int) that it will not be too big of a number.
EXAMPLE:
  //recognize button press and run code then delay for 3 hours
  if ((switchon == HIGH) && (press1 == LOW))
    servo1.write(10);
    delay(800);
    servo1.write(170);
    delay(3000);
    delay(10800000)
Have you read Robin2 's
http://forum.arduino.cc/index.php?topic=223286.0
Here are four examples:
//Blink without Delay skeleton
//4 examples demonstrated
//LarryD
//LED wiring options
//#define PlusEqualsON //uncomment to invert
#ifdef PlusEqualsON
//wired so +5V turns LED ON
#define ledON  HIGH
#define ledOFF LOW
#else
//wired so +5V turns LED OFF
#define ledON  LOW
#define ledOFF HIGH
#endif
unsigned long currentMillis;
unsigned long pin13Millis;
unsigned long pin12Millis;
unsigned long pin11Millis;
unsigned long SwitchMillis;
//if these are not changed in the sketch, they can be const
unsigned long debounceMillis = 100UL;     //100ms
unsigned long ledOnTime      = 5*1000UL;  //5 seconds
byte laststartSwitchState    = HIGH;
byte buttonState             = HIGH;
byte counter                 = 0;
//the following are enable/disable flags
//some of these might not be used in this sketch
boolean flag13 = true;
boolean flag12 = true;
boolean flag11 = true;
boolean flag10 = true;
const byte startSwitch = 2; //pushed = LOW
const byte testSwitch  = 3; //pushed = LOW
  digitalWrite(13,ledOFF);
  pinMode(13, OUTPUT);
  digitalWrite(12,ledOFF);
  pinMode(12, OUTPUT);
  digitalWrite(11,ledOFF);
  pinMode(11, OUTPUT);
  digitalWrite(10,ledOFF);
  pinMode(10, OUTPUT);
  pinMode(startSwitch, INPUT_PULLUP); //pushed = LOW
  pinMode(testSwitch,  INPUT_PULLUP); //pushed = LOW
} //  >>>>>>>>>>>>>> E N D  O F  s e t u p ( ) <<<<<<<<<<<<<<<<<
  //save the current time
  //************************************* E x a m p l e  1
  //toggle pin 13 every 200mS
  //has 200ms or more gone by?
  if (currentMillis - pin13Millis >= 200UL)
    //code here runs every 200ms
    //get ready for next iteration
    pin13Millis = pin13Millis + 200UL;
    //toggle pin 13
    digitalWrite(13,!digitalRead(13));
  //************************************* E x a m p l e  2
  //at power up, pin 12 LED goes ON, after 3 seconds goes OFF and stays OFF
  //could be used as a powerup reset signal
  if (flag12 == true && currentMillis - pin12Millis <= 3000UL)
    //code here runs for 3 seconds after power up, then stops
    digitalWrite(12,ledON);
    //disable further pin 12 control
    flag12 = false;
  //************************************* E x a m p l e  3
  //if testSwitch is pushed and released
  //pin 11 LED goes ON for 5 seconds, then goes OFF
  buttonState = digitalRead(testSwitch);
  //are we are allowed to check the switch and is it pressed?
  if(flag11 == true && buttonState == LOW)
    //enable timing of LED on pin 11
    flag11 = false; //false --> timing is enabled
    //turn LED ON
    digitalWrite(11,ledON);
    //record the time LED turned ON
    pin11Millis = currentMillis;
  //are we allowed and is it time to control pin 11
  if (flag11 == false && currentMillis - pin11Millis >= ledOnTime)
    //if enabled, code here runs after ledOnTime ms goes by
    //allow switch press detection again
    flag11 = true; //true --> switch monitoring is enabled
  //************************************* E x a m p l e  4
  //is it time to check the switches?
  //in particular, pushing startSwitch will turn ON/OFF (toggle) an output pin 10
  if (currentMillis - SwitchMillis >= debounceMillis)
    //code here runs every debounceMillis ms
    //get ready for the next iteration
    SwitchMillis += debounceMillis;
    //go and check the switches
    checkSwitches();
  //put other non-blocking stuff here
} //  >>>>>>>>>>>>>> E N D  O F  l o o p ( ) <<<<<<<<<<<<<<<<<
//                      F U N C T I O N S
//****************** c h e c k S w i t c h e s ( ) *********************
//switches are checked every debounceValue milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void checkSwitches()
  //re-usable for all the switches
  boolean thisState;
  //************************************* E x a m p l e  Push ON push OFF (toggle)
  //check if this switch has changed state
  thisState = digitalRead(startSwitch);
  if (thisState != laststartSwitchState)
    //update the switch state
    laststartSwitchState = thisState;
    //this switch position has changed so do some stuff
    //"HIGH condition code"
    //switch went from LOW to HIGH
    if(thisState == HIGH)
      //Do some HIGH switch stuff here
    //"LOW condition code"
    //switch went from HIGH to LOW
      //Do some LOW switch stuff here
      digitalWrite(10, !digitalRead(10));
      //print number of pushes
      counter++;
      Serial.println(counter);
  } //END of startSwitch code
  //similar code for other switches goes here
} //END of checkSwitches()
//                      E N D  O F  C O D E
ihsisd:
Then there is no hope for you. You are wasting your time asking for help with switches because it will never work. Never.
Well, we can assure you that millis() itself works fine.
You want, in pseudocode:
if button_pressed AND button_pressed_allowed
   do something.
   disallow_button_presses_for_some_time
   // continue doing something else, perhaps.
So, you can actually write it that way. Note the code added to buttonAllowed so that it returns TRUE after startup, as well as after an elapsed interval. And the added debugging code. debugging code is very useful!
And code to use the Serial instead of actual buttons.
// Check if the correct buttons are pressed.
bool buttonPressed() {
#if 0
  if ((switchon == LOW) && (press1 == LOW)) { // not too sure about this.  The original code had
    // two different "tests"
    Serial.println("Button Pressed");
    return true;
#else
  if (Serial.read() == 'p') {
    return true;
#endif
  return false;
bool pressAllowed() {
  // A button press is allowed if it's been "interval" since the last button press action
  unsigned long currentmillis = millis();
  if (currentmillis - previousMillis > interval) {
    previousMillis = currentmillis;
    Serial.println("ButtonAllowed because time");
    return true;
  // or if the system has just started.  This is actually slightly difficult, since a
  // start both millis() and previousmillis will be 0, and it will be "interval" before the time
  // based scheme actually allows a press.   The easiest way to correct for this is just to
  // create another variable to handle the startup condition.
  static bool firsttime = true;  // start at allowing a buttonpress
  if (firsttime) {
    previousMillis = currentmillis;  // reset the timer.
    firsttime = false;  // no longer allow the startup excemption of timeout.
    Serial.println("ButtonAllowed because startup");
    return true;
  Serial.print("Button disallowed: ");
  Serial.print(interval - (currentmillis - previousMillis));
  Serial.println("ms remaining");
  return false;  // otherwise don't allow the button to work yet.
  if (buttonPressed()) {
    if (pressAllowed()) {
      // Do stuff.  For now, blink the led
      pinMode(ledPin, HIGH);
      pinMode(ledPin, LOW);
  // Do other stuff.
Warning: there's a bug in this code. Finding it is left as an exercise for the reader :slight_smile:
It's definitely a good idea to learn to code it yourself but I also found that the library elapsedMillis.h was very useful in controlling timings.
dillonradio:
Hmmmm, never seen that library before, very handy.
If anyone else wants to try it, it's here.
