hello I was working on driving an 4 digit 7 segment display (common cathode) with an max7219 driver.
to be more specific I was working on an project that was taking input from an button and then displaying how many times the button was pressed on the 7 segment display. to elaborate I found some code (listed bellow) that dose just that but I was trying to modify the code so it only has one input (it only has one input and only displays that one input) and also I was wanting it to count up to 9999 on all four digits rather than just 99. I have been reluctant to ask for help but I have been trying to work on modifying this code all weekend and IF anyone who is more experienced with the max7219 library can help me with this than that would be an real life saver. thanks in advance to anyone who can help me than that would be really appreciated
the code (not modifyed. grabed from https://www.brainy-bits.com/using-7-segment-display-with-arduino/)
/* Arduino 7 Segment scoreboard
- Using the MAX7219CNG LED Driver
Created by Yvan / https://Brainy-Bits.com
This code is in the public domain...
You can: copy it, use it, modify it, share it or just plain ignore it!
Thx!
#include "LedControl.h" // Library used for communcation with 7 segment
LedControl lc=LedControl(12,11,10,1); // (DIN, CLK, LOAD, number of Max7219 chips)
// Variable to hold current scores
int displayone=0;
int displaytwo=0;
// Variables to split whole number into single digits
int rightdigit;
int leftdigit;
// Switches pin connection to Arduino UNO
#define switchone 2
#define switchtwo 3
pinMode(switchone,INPUT_PULLUP);
pinMode(switchtwo,INPUT_PULLUP);
lc.shutdown(0,false); // Wake up MAX7219
lc.setIntensity(0,7); // Set brightness to medium
lc.clearDisplay(0); // Clear all displays connected to MAX7219 chip #
// Put zeros on both displays at startup
lc.setDigit(0,0,0,false); // (Max7219 chip #, Digit, value, DP on or off)
lc.setDigit(0,1,0,false);
lc.setDigit(0,2,0,false);
lc.setDigit(0,3,0,false);
// If switch 1 is clicked
if (!digitalRead(switchone)) {
displayone++; // Increase score by 1
// convert whole number to single digits
rightdigit=displayone%10;
leftdigit=displayone%100/10;
// Display extracted digits on the display
lc.setDigit(0,0,leftdigit,false);
lc.setDigit(0,1,rightdigit,false);
// Wait until switch is released to continue
while (!digitalRead(switchone)) {
delay(5); // Small delay to debounce the switch
if (!digitalRead(switchtwo)) {
displaytwo++;
rightdigit=displaytwo%10;
leftdigit=displaytwo%100/10;
lc.setDigit(0,2,leftdigit,false);
lc.setDigit(0,3,rightdigit,false);
while (!digitalRead(switchtwo)) {
delay(5);
