help with mosfet with brushless motor controller
hello
i have a brushless motor controller which i would like to hack ie make it switch higher currents
im thinking of using the same mosfet and in effect doubling them currently there is just 1 per pole im thinking of adding another same mosfet in parallel would this work can think of any reason why it wont?
thnks
This is it
There's something really important you've neglected to tell us...
The mosphet Im using is the same as is on the original same voltage just want to increase current Capability not sure if it has a gate driver will check
PDF files are not the best for use in the forum.
Actual links, pictures, text are much preferred.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
No the mosfets do not have a driver, it gets signal from processor
Can anyone help please?
Schematics and details for the current unit ?
Present MOSFET that is in there ?
Actual application you want to upgrade for ?
It is easy to stick a jet engine in a Mini but without context you would be on your own. :fearful:
