Hey everyone, I'm pretty new to both the arduino and programming in a C style environment so I have a pretty basic question to ask.
I'm using the arduino along with a PIR motion sensor for an art installation in which the sensor will blink an LED as a warning. This works quite well but I would like the LED to start blinking faster the longer a person stands in front of the sensor. Is there a way I can create a loop that changes the longer the sensor is detecting motion? I'd also like to have the arduino activate the motor of a blender once the time limit has been exceeded, and am wondering how I might achieve this. My code is based on the motion_sensor_for_arduino sketch I found on the forums. I've added the sketch below as an atachment.
I'd really appreciate any help anyone can offer, thanks!
e. g. millis()
it is quite accurate and is good for time differences of about 49days (that should be enough for ur application...)...
u could remember an internal state:
state A: no motion since 40 seconds (or so)
state B: motion detected every 40 (or less) seconds since time stamp T0 (T0 is the time stamp of transition from state A to state B)...
the time stamp T0 will enable u to say since when the LED is blinking...
internal states can be implemented as global variables, that r declared outside of the loop() function... like this:
// global variables:
char state = 'A'; // or 'B'
uint32_t T0 = 0;
uint32_t Tlast = 0;
if no motion detected and state == 'A' then return;
if motion detected
then
if state == 'A' then T0 = millis();
state = 'B';
Tlast = millis();
if (millis()-Tlast > 40*1000) state = 'A';
do blinking according to millis()-T0
maybe u should make a further global variable for the blinking (a time stamp when the state of the LED changed last),
so that u dont miss a motion sensor message...
