Hi everyone,
I've built a labeling machine which puts one label on another,
The project is built using arduino nano, two optical sensors, two steppers driven by big easy driver.
currently the motors work simultaneously at the same speed. I want motor A to work a little faster than motor B. how can I do that?
When I try to play with delay times for individual motors it affects the whole process, so I understand that delay() command is not suitable for what i'm looking for.
Here's the code, the part I wish to modify is under TTI() process:
int const potPin1 = A6; // analog pin used to connect to sensor1
int potVal;
int const potPin2 = A7; // analog pin used to connect to sensor2
int potVal2;
const int stepPin = 5;
const int dirPin = 4;
const int enable1 = 12;
const int stepPin2 = 2;
const int dirPin2 = 3;
const int enable2 = 6;
int const buttonPin = A0; // digital pin used to connect to button(request TTI)
int button;
int potValLow = 400;
int Speed = 180; //delay between actions
int button_VAL = 400; // button_VAL active val
// set the two pins as outputs
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
pinMode(stepPin2,OUTPUT);
pinMode(dirPin2,OUTPUT);
pinMode(buttonPin,INPUT);
pinMode(enable1,OUTPUT);
pinMode(enable2,OUTPUT);
pinMode(potPin1, INPUT);
pinMode(potPin2, INPUT);
button=0;
calibrate();
TTI();
void calibrate()
potVal = analogRead(potPin1); // read the value of the sensor
potVal2 = analogRead(potPin2); // read the value of the sensor
while((potVal < potValLow) || (potVal2 < potValLow))
digitalWrite(enable1,LOW);
digitalWrite(enable2,LOW);
if(potVal < potValLow) // calibrate position of Active labels. bring space between labels into sensor
digitalWrite(stepPin2,HIGH);
if(potVal2 < potValLow)
digitalWrite(stepPin,HIGH);
digitalWrite(stepPin2,LOW);
digitalWrite(stepPin,LOW);
delayMicroseconds(Speed);
void TTI()
button = analogRead(buttonPin);
if(button > button_VAL)
while((potVal > potValLow) || (potVal2 > potValLow))
if(potVal > potValLow)// calibrate position of Active labels. bring start of label into sensor
if(potVal2 > potValLow)// calibrate position of Base labels. bring start of label into sensor
Thanks,
I tried to test the AccelStepper commands, with a simplified version of the program i'm using, and it doesn't seem to turn the motors.
Is there anything obvious that i'm missing?
#include <AccelStepper.h>
int potVal;
int potVal2;
int button;
// Define two steppers and the pins they will use
AccelStepper stepper1(AccelStepper::DRIVER, 5, 4);
AccelStepper stepper2(AccelStepper::DRIVER, 2, 3);
stepper1.setMaxSpeed(1000);
stepper1.setAcceleration(1000);
stepper2.setMaxSpeed(1000);
stepper2.setAcceleration(1000);
button=0;
stepper1.run();
stepper2.run();
I tried the runSpeed() instead run(), still the same, it sounds like the motors are stuck in place.
the move commands are less appropriate because the number of steps is not constant, I need to pull the motor until a label gets into the optical sensor.
I do not understand what you are doing with the Vdd lines to the motor drivers. Those terminals should be connected to 5V logic power. What is the purpose of switching them?
you can ignore that, it's drawn incorrectly to indicate a momentary switch for "give me next label"
The motors are connected to 12v from the input power, VDD connected to 5v from the arduino
regarding opto interrupters, i'm working with labels of different density and can identify that level through the value I put in the program ("potValLow")
If you use runSpeed(), you must also use setSpeed() to make the motors turn. With runSpeed() you don't get acceleration and deceleration, but that won't work with your approach anyway.
Here are 2 ways to do what (I think) that you want. The first uses your AccelStepper code but modified to use runSpeed (with setSpeed as @MicroBahner mentions). I use an if structure instead of while so it does not block. The other uses the MobaTools steppers. I use a CNC shield with an Uno for testing so the pin numbers must be changed to suit your setup.
AccelStepper:
int const potPin1 = A0; // analog pin used to connect to sensor1
int potVal;
int const potPin2 = A1; // analog pin used to connect to sensor2
int potVal2;
int const buttonPin = A2; // digital pin used to connect to button(request TTI)
int button;
const byte enablePin = 8; // for CNC shield
AccelStepper stepper1(AccelStepper::DRIVER, 2, 5);
AccelStepper stepper2(AccelStepper::DRIVER, 3, 6);
pinMode(buttonPin, INPUT);
pinMode(enablePin, OUTPUT);
digitalWrite(enablePin, LOW);
button = 0;
if ((potVal < potValLow) || (potVal2 < potValLow))
stepper1.setSpeed(800);
stepper1.runSpeed();
stepper2.setSpeed(800);
stepper2.runSpeed();
stepper1.stop();
stepper2.stop();
Thanks very much!
thanks to your AccelStepper variation, I see progress in the project,
I used the code below, it works for bringing each label into the optical sensor and stopping, but the motors sound like they are stuck in place and not off, I filmed a video to demonstrate:
int potVal;
int potVal2;
int button;
AccelStepper stepper1(AccelStepper::DRIVER, 2, 3);
AccelStepper stepper2(AccelStepper::DRIVER, 5, 4);
stepper1.setMaxSpeed(-10000);
stepper1.setAcceleration(-1000);
stepper2.setMaxSpeed(-10000);
stepper2.setAcceleration(-1000);
pinMode(enable1, OUTPUT);
pinMode(enable2, OUTPUT);
//digitalWrite(enable1, HIGH);
button = 0;
if (potVal < potValLow)
stepper1.setSpeed(-2000);
else if (potVal2 < potValLow)
stepper2.setSpeed(-2000);
if ((potVal < potValLow) && (potVal2 < potValLow))
stepper1.stop();
stepper2.stop();
int potVal;
int potVal2;
int button;
button = 0;
digitalWrite(enable1, LOW);
digitalWrite(enable2, LOW);
stepper1.stop();
stepper2.stop();
digitalWrite(enable2, HIGH);
is there a command I can use to break out of this loop of reading sensors and moving the motors?
I mean something like "break", or to go to another sub program that waits for a push of the button to start running the motors again.
because as it is right now, it seems that perhaps it doesn't get into the last if() that turns the motors off. maybe I need to read the input of the sensors somehow differently?
Parameters
[in] speed The desired maximum speed in steps per second. Must be > 0. Caution: Speeds that exceed the maximum speed supported by the processor may Result in non-linear accelerations and decelerations.
start writing a very basic code that makes both motor spins to make sure you got the wiring and power right
