Help with mpu-6050 self stabilization system
i recently made a stabilization system for my Rc Glider project. It uses only two servos X and Y and it has a problem when i tilt he gyro to left the servo arm turns left and when the gyro tilts right the servo arm turns right.i need to make this exactly opposite.so hes the code i use please help me with this
#include <Wire.h>
#include <Servo.h>
const int MPU=0x68;  // I2C address of the MPU-6050
int16_t GyX, GyY; //Variabile int a 16bit
Servo ServoMot_X;
Servo ServoMot_Y;
void setup(){
  Wire.begin();
  Wire.beginTransmission(MPU);
  Wire.write(0x6B);  // PWR_MGMT_1 register
  Wire.write(0);     // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
  ServoMot_X.attach(8);
  ServoMot_Y.attach(9);
void loop(){
  Wire.write(0x3B);                // starting with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  Wire.requestFrom(MPU,14,true);  // request a total of 14 registers
  GyX=Wire.read()<<8|Wire.read();  // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
  GyY=Wire.read()<<8|Wire.read();  // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
  int PosServo_X = map(GyX, -16000, 16000, 0, 179);
  int PosServo_Y = map(GyY, -16000, 16000, 0, 179);
  ServoMot_X.write(PosServo_X);
  ServoMot_Y.write(PosServo_Y);
  Serial.println("Giroscopio");
  Serial.print("Asse X : "); Serial.println(PosServo_X);
  Serial.print("Asse Y : "); Serial.println(PosServo_Y);
  Serial.println(" ");
  delay(100);
Modify these statements to match your requirements:
E.g. swap the low and high bounds to reverse the direction of movement.
Why are you double posting?
