I have both mesh network and MQTT-hivemq working separately I just would like to combine them together where the esp32's will relay their information to the root esp32 and relay to hivemq. I'm also using a sensor dashboard called virtuino to display the data in real time as well to control the onboard led. Currently I'm having issues implementing the mesh network which causes my real time data to stop. Can I get some advice on how to properly implement.
#include <WiFi.h>
#include <painlessMesh.h>
#include <PubSubClient.h>
#include <WiFiClientSecure.h>
#define MESH_PREFIX "whateverYouLike"
#define MESH_PASSWORD "somethingSneaky"
#define MESH_PORT 5555
void receivedCallback( const uint32_t &from, const String &msg );
void mqttCallback(char* topic, byte* payload, unsigned int length);
painlessMesh mesh;
//---- WiFi settings
const char* ssid = "";
const char* password = "";
#define HOSTNAME "MQTT_Bridge"
//---- MQTT Broker settings
const char* mqtt_server = "";
const char* mqtt_username = "";
const char* mqtt_password = "";
const int mqtt_port =8883;
WiFiClientSecure espClient;
PubSubClient client(espClient);
unsigned long lastMsg = 0;
#define MSG_BUFFER_SIZE (50)
char msg[MSG_BUFFER_SIZE];
int sensor1 = 0;
float sensor2 = 0;
int command1 =0;
const char* sensor1_topic= "sensor1";
const char* sensor2_topic="sensor2";
//const char* sensor2_topic="sensor3";
const char* command1_topic="command1";
//const char* command1_topic="command2";
static const char *root_ca PROGMEM = R"EOF(
-----BEGIN CERTIFICATE-----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=
-----END CERTIFICATE-----
)EOF";
void setup_wifi() {
delay(10);
Serial.print("\nConnecting to ");
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print(".");
randomSeed(micros());
Serial.println("\nWiFi connected\nIP address: ");
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
String clientId = "ESP8266Client-"; // Create a random client ID
clientId += String(random(0xffff), HEX);
// Attempt to connect
if (client.connect(clientId.c_str(), mqtt_username, mqtt_password)) {
Serial.println("connected");
client.subscribe(command1_topic); // subscribe the topics here
//client.subscribe(command2_topic); // subscribe the topics here
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds"); // Wait 5 seconds before retrying
delay(5000);
//================================================ setup
while (!Serial) delay(1);
setup_wifi();
pinMode(BUILTIN_LED, OUTPUT); // Initialize the BUILTIN_LED pin as an output
mesh.setDebugMsgTypes( ERROR | STARTUP | CONNECTION ); // set before init() so that you can see startup messages
mesh.init( MESH_PREFIX, MESH_PASSWORD, MESH_PORT, WIFI_AP_STA, 6 );
mesh.onReceive(&receivedCallback);
mesh.stationManual(STATION_SSID, STATION_PASSWORD);
mesh.setHostname(HOSTNAME);
mesh.setRoot(true);
mesh.setContainsRoot(true);
#ifdef ESP8266
espClient.setInsecure();
#else // for the ESP32
espClient.setCACert(root_ca);
#endif
client.setServer(mqtt_server, mqtt_port);
client.setCallback(callback);
mesh.update()
if (!client.connected()) reconnect();
client.loop();
//---- example: how to publish sensor values every 5 sec
unsigned long now = millis();
if (now - lastMsg > 5000) {
lastMsg = now;
sensor1= random(50);
sensor2= 20+random(80);
publishMessage(sensor1_topic,String(sensor1),true);
publishMessage(sensor2_topic,String(sensor2),true);
void callback(char* topic, byte* payload, unsigned int length) {
String incommingMessage = "";
for (int i = 0; i < length; i++) incommingMessage+=(char)payload[i];
Serial.println("Message arrived ["+String(topic)+"]"+incommingMessage);
//--- check the incomming message
if( strcmp(topic,command1_topic) == 0){
if (incommingMessage.equals("1")) digitalWrite(BUILTIN_LED, LOW); // Turn the LED on
else digitalWrite(BUILTIN_LED, HIGH); // Turn the LED off
// check for other commands
/* else if( strcmp(topic,command2_topic) == 0){
if (incommingMessage.equals("1")) { } // do something else
void publishMessage(const char* topic, String payload , boolean retained){
client.publish(topic, (byte*) payload.c_str(), 10, true);
Serial.println("Message publised ["+String(topic)+"]: "+payload);
void receivedCallback( const uint32_t &from, const String &msg ) {
Serial.printf("bridge: Received from %u msg=%s\n", from, msg.c_str());
String topic = "painlessMesh/from/" + String(from);
client.publish(topic.c_str(), msg.c_str());
void mqttCallback(char* topic, uint8_t* payload, unsigned int length) {
char* cleanPayload = (char*)malloc(length+1);
payload[length] = '\0';
memcpy(cleanPayload, payload, length+1);
String msg = String(cleanPayload);
free(cleanPayload);
String targetStr = String(topic).substring(16);
if(targetStr == "gateway")
if(msg == "getNodes")
auto nodes = mesh.getNodeList(true);
String str;
for (auto &&id : nodes)
str += String(id) + String(" ");
client.publish("painlessMesh/from/gateway", str.c_str());
else if(targetStr == "broadcast")
mesh.sendBroadcast(msg);
uint32_t target = strtoul(targetStr.c_str(), NULL, 10);
if(mesh.isConnected(target))
mesh.sendSingle(target, msg);
client.publish("painlessMesh/from/gateway", "Client not connected!");
