Help with multiple conditions in an If statement(s)
Hi:
I have a problem with trying to set up a valid heat index calculation. I make the initial calculation no problem. Then you make an adjustment if RH (relative humidity is < 13%) and (80 <t and t < 112). I don't know how to set this up. There is one other complication. If t <80 another formula with no adjustments are needed. Thanks for any guidance.
Bob
 if (t < 80) {...}
else if (RH  < 0.13 and t < 112) {...
and? You still suck in the Pascal days? How about &&?
EDIT : OMG, when did and get added to c++?
-jim lee
