I created an 8x8 matrix. All the LEDS turn on so the hardware must be okay. I tried running an example sketch:
//Pin connected to latch pin (ST_CP) of 74HC595
const int latchPin = 6;
//Pin connected to clock pin (SH_CP) of 74HC595
const int clockPin = 12;
////Pin connected to Data in (DS) of 74HC595
const int dataPin = 7;
int rowArr[8] = {5,4,3,2,8,9,10,11}; // Pins where each Cathode is connected
byte data;
byte dataArray[8];
//set pins to output because they are addressed in the main loop
pinMode(latchPin, OUTPUT);
pinMode(5,OUTPUT);
pinMode(4,OUTPUT);
pinMode(3,OUTPUT);
pinMode(2,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
//Binary notation as comment
dataArray[0] = 0xFF; //0b11111111
dataArray[1] = 0x81; //0b10000001
dataArray[2] = 0x81; //0b10000001
dataArray[3] = 0x81; //0b10000001
dataArray[4] = 0x81; //0b10000001
dataArray[5] = 0x81; //0b10000001
dataArray[6] = 0x81; //0b10000001
dataArray[7] = 0xFF; //0b11111111
digitalWrite(5,HIGH);
digitalWrite(4,HIGH);
digitalWrite(3,HIGH);
digitalWrite(2,HIGH);
digitalWrite(8,HIGH);
digitalWrite(9,HIGH);
digitalWrite(10,HIGH);
digitalWrite(11,HIGH);
for (int j = 0; j < 8; j++) {
//load the light sequence you want from array
data = dataArray[j];
//ground latchPin and hold low for as long as you are transmitting
digitalWrite(latchPin, 0);
//move 'em out
shiftOut(dataPin, clockPin, data);
//return the latch pin high to signal chip that it
//no longer needs to listen for information
digitalWrite(latchPin, 1);
digitalWrite(rowArr[j],LOW);
delay(100);
digitalWrite(rowArr[j],HIGH);
// the heart of the program
void shiftOut(int myDataPin, int myClockPin, byte myDataOut) {
// This shifts 8 bits out MSB first,
//on the rising edge of the clock,
//clock idles low
//internal function setup
int i=0;
int pinState;
pinMode(myClockPin, OUTPUT);
pinMode(myDataPin, OUTPUT);
//clear everything out just in case to
//prepare shift register for bit shifting
digitalWrite(myDataPin, 0);
digitalWrite(myClockPin, 0);
//for each bit in the byte myDataOut�
//NOTICE THAT WE ARE COUNTING DOWN in our for loop
//This means that %00000001 or "1" will go through such
//that it will be pin Q0 that lights.
for (i=7; i>=0; i--) {
//if the value passed to myDataOut and a bitmask result
// true then... so if we are at i=6 and our value is
// %11010100 it would the code compares it to %01000000
// and proceeds to set pinState to 1.
if ( myDataOut & (1<<i) ) {
pinState= 1;
else {
pinState= 0;
//Sets the pin to HIGH or LOW depending on pinState
digitalWrite(myDataPin, pinState);
//register shifts bits on upstroke of clock pin
digitalWrite(myClockPin, 1);
//zero the data pin after shift to prevent bleed through
//stop shifting
Instead of it lighting up the LEDS according to the Data array, it just turns them all on. Any ideas?
