int left1=2;
int left2=3;
int right1=4;
int right2=5;
char inSerial[15];
void setup(){
pinMode(left1, OUTPUT);
pinMode(left2, OUTPUT);
pinMode(right1, OUTPUT);
pinMode(right2, OUTPUT);
pinMode(0, INPUT);
pinMode(A3,INPUT);
pinMode(A2,INPUT);
pinMode(13,OUTPUT);
void loop(){
int i=0;
int m=0;
if (Serial.available() > 0) {
while (Serial.available() > 0) {
inSerial[i]=Serial.read();
i++;
inSerial[i]='\0';
Check_Protocol(inSerial);}
void Check_Protocol(char inStr[]){
int i=0;
int m=0;
if(!strcmp(inStr,"front")){
digitalWrite(13,HIGH);
Serial.println("front");
digitalWrite(left1, HIGH);
digitalWrite(left2, LOW);
digitalWrite(right1, HIGH);
digitalWrite(right2, LOW);
for(m=0;m<11;m++){
inStr[m]=0;}
i=0;}
else if(!strcmp(inStr,"back")){
digitalWrite(13,LOW);
Serial.println("back");
digitalWrite(left2, HIGH);
digitalWrite(left1, LOW);
digitalWrite(right2, HIGH);
digitalWrite(right1, LOW);
for(m=0;m<11;m++){
inStr[m]=0;}
i=0;} else if(!strcmp(inStr,"left")){
for(m=0;m<11;m++){
inStr[m]=0;}
i=0;}else if(!strcmp(inStr,"right")){
for(m=0;m<11;m++){
inStr[m]=0;}
i=0;} else if(!strcmp(inStr,"stop")==0){
for(m=0;m<11;m++){
inStr[m]=0;}
i=0;}
else{
for(m=0;m<11;m++){
inStr[m]=0;
i=0;
this is my code i dont know why it is not working i am using an hc05 bluetooth module with its tx pin connected to pin0 of my arduino pro mini and if i connect my bluetooth module to usb to ttl converter and check if it recieves data from my phone at the right baud rate it does i dont know why then the arduino has problem with it
