Help with my drone
Mode edit: See also: Help with analogic pin
I'm building a powerful arduino nano based drone, motors, need PWM pins to comunicate (concretely ESC). Mine is an hexacopter, so I need 4 PWM pins for the controller and 6 for the motors, I've been investigating, and Arduino Nano, has 6 PWM pins, but I'm being guided with a tutorial wich uses 8 and moreover, 4 of them are not listed in the PWM pins on the datasheet (we bought the same board), but when I connect all the motors, and turn it all on, some of the motors connected at the "official" PWM pins don't work (10,11) and the original motors work. I can't know what's happening and I would need help.
My test motor's code
#define usCiclo 6000    // Ciclo de ejecucion de software en microsegundos (PWM)
#define pin_motor1 3        // Pin motor 1
#define pin_motor2 4        // Pin motor 2
#define pin_motor3 5        // Pin motor 3
#define pin_motor4 6        // Pin motor 4
#define pin_motor5 11       // Pin motor 5
#define pin_motor6 10       // Pin motor 6
#define pin_Throttle 8  // Pin throttle del mando RC
#define pin_LED_rojo A2 // Pin LED rojo
#include <EnableInterrupt.h>
// PWM
float ESC1_us, ESC2_us, ESC3_us, ESC4_us,ESC5_us, ESC6_us,loop_timer;
long tiempo_motores_start;
// AJUSTE MANDO RC - THROTLLE
float RC_Throttle_consigna;
const int us_max_Throttle_adj = 2000;
const int us_min_Throttle_adj = 950;
const float us_max_Throttle_raw = 2004; // <-- Si teneis la entrada Throttle invertida sustituid este valor
const float us_min_Throttle_raw = 1116; // <-- por este y viceversa
// INTERRUPCIÓN MANDO RC --> THROTTLE
volatile long Throttle_HIGH_us;
volatile int RC_Throttle_raw;
void INT_Throttle() {
  if (digitalRead(pin_Throttle) == HIGH) Throttle_HIGH_us = micros();
  if (digitalRead(pin_Throttle) == LOW)  RC_Throttle_raw  = micros() - Throttle_HIGH_us;
  // Decalaración de LEDs
  pinMode(pin_LED_rojo, OUTPUT);
  digitalWrite(pin_LED_rojo, HIGH);
  // Serial.begin()
  // Interrupción para canal Thrtottle
  pinMode(pin_Throttle, INPUT_PULLUP);
  enableInterrupt(pin_Throttle, INT_Throttle, CHANGE);
  // Decalaración de motores
  pinMode(pin_motor1, OUTPUT);   // Declarar motor 1
  pinMode(pin_motor2, OUTPUT);   // Declarar motor 2
  pinMode(pin_motor3, OUTPUT);   // Declarar motor 3
  pinMode(pin_motor4, OUTPUT);   // Declarar motor 4
  pinMode(pin_motor5, OUTPUT);   // Declarar motor 3
  pinMode(pin_motor6, OUTPUT);   // Declarar motor 4
  digitalWrite(pin_motor1, LOW); // Motor 1 LOW por seguridad
  digitalWrite(pin_motor2, LOW); // Motor 2 LOW por seguridad
  digitalWrite(pin_motor3, LOW); // Motor 3 LOW por seguridad
  digitalWrite(pin_motor4, LOW); // Motor 4 LOW por seguridad
  digitalWrite(pin_motor5, LOW); // Motor 3 LOW por seguridad
  digitalWrite(pin_motor6, LOW); // Motor 4 LOW por seguridad
  Serial.println("Encender mando RC y bajar Throttle al mínimo");
  // Hasta no bajar Throttle al mínimo no salimos de este bucle while
  while (RC_Throttle_consigna > 1100 || RC_Throttle_consigna < 900) {
    RC_Throttle_consigna = map(RC_Throttle_raw, us_min_Throttle_raw, us_max_Throttle_raw, us_min_Throttle_adj, us_max_Throttle_adj);
  Serial.println("Encendido detectado");
  digitalWrite(pin_LED_rojo, LOW);
  //  Nuevo ciclo
  while (micros() - loop_timer < usCiclo);
  loop_timer = micros();
  //  Ecuaciones de procesamiento de la señal Throttle
  // La señal RC_Throttle_consigna define el tiempo que la señal PWM está en estado HIGH
  ESC1_us = RC_Throttle_consigna*0.125;
  ESC2_us = RC_Throttle_consigna*0.125;
  ESC3_us = RC_Throttle_consigna*0.125;
  ESC4_us = RC_Throttle_consigna*0.125;
  ESC5_us = RC_Throttle_consigna*0.125;
  ESC6_us = RC_Throttle_consigna*0.125;
  // Para generar las 4 señales PWM, el primer paso es poner estas señales a 1 (HIGH).
  digitalWrite(pin_motor1, HIGH);  // MOTOR 1
  digitalWrite(pin_motor2, HIGH);  // MOTOR 2
  digitalWrite(pin_motor3, HIGH);  // MOTOR 3
  digitalWrite(pin_motor4, HIGH);  // MOTOR 4
  tiempo_motores_start = micros();
  // Cuando se cumpa el tiempo de PWM definido en ESCx_us, se pasa cada señal a 0 (LOW) para terminar el ciclo PWM.
  while (digitalRead(pin_motor1) == HIGH || digitalRead(pin_motor2) == HIGH || digitalRead(pin_motor3) == HIGH || digitalRead(pin_motor4) == HIGH) {
    if (tiempo_motores_start + ESC1_us <= micros()) digitalWrite(pin_motor1, LOW); // MOTOR 1
    if (tiempo_motores_start + ESC2_us <= micros()) digitalWrite(pin_motor2, LOW); // MOTOR 2
    if (tiempo_motores_start + ESC3_us <= micros()) digitalWrite(pin_motor3, LOW); // MOTOR 3
    if (tiempo_motores_start + ESC4_us <= micros()) digitalWrite(pin_motor4, LOW); // MOTOR 4
    if (tiempo_motores_start + ESC5_us <= micros()) digitalWrite(pin_motor3, LOW); // MOTOR 3
    if (tiempo_motores_start + ESC6_us <= micros()) digitalWrite(pin_motor4, LOW); // MOTOR 4
  // Monitor serie
  Serial.println(RC_Throttle_consigna);
His test motors code:
#define pin_LED_rojo 13 // Pin LED rojo
// PWM
float ESC1_us, ESC2_us, ESC3_us, ESC4_us, loop_timer;
  // Serial.begin()
  //  Nuevo ciclo
  ESC1_us = RC_Throttle_consigna;
  ESC2_us = RC_Throttle_consigna;
  ESC3_us = RC_Throttle_consigna;
  ESC4_us = RC_Throttle_consigna;
  // Monitor serie
I can't add the full code and datasheets because I'm new, but in the datasheet mentions that PWM are: D3, D5, D6, D9, D10, D11
@arxi,
I've moved this to a more suitable place as 'showcase' is not for questions.
I considered merging with your other topic as both are about your drone, I decided not to as this is a different question, but really consider keeping one topic running about your drone and keep adding questions. Previous questions and answers provide the background for new questions and make it easier to provide helpful answers.
Thank you.
Ok thanks
"PWM" pins are used for 'analogWrite()'. You are not using 'analogWrite()' so you can use any digital I/O pin.
The Arduino has a built-in 'Servo' library for talking to RC hobby servos. In general, an ESC uses the same interface as an RC hobby servo.
But, where is the difference between his code and mine wich made it don't work?
PD: I can't use the library because in the bigger code, uses more complex systems
This looks wrong. Why use ESC5_us on pin_motor3 and ESC6_us on pin_motor4??
Thanks
I changed the code and now I use this one:
// !!!!!!!!!!!!!! RETIRAR LAS HELICES - SIN HELICES !!!!!!!!!!!!!!!!!!!!!!!!!!
// Puede que este prodecimiento no sirva para todos los ESC/motores, consultad vuestra hoja de datos:
// 1) Con el Throttle al mínimo, conectar la batería y cerrar el interruptor para alimentar
//    la placa Arduino (no conectar el cable USB).
// 2) Los motores emitiran unos pitidos pipipi... piiiii.
// 3) Terminado, se pueden girar los motores con el mando.
// PWM
  // Serial.begin()
  //  Nuevo ciclo
  digitalWrite(pin_motor5, HIGH);  // MOTOR 3
  digitalWrite(pin_motor6, HIGH);  // MOTOR 4
    if (tiempo_motores_start + ESC5_us <= micros()) digitalWrite(pin_motor5, LOW); // MOTOR 3
    if (tiempo_motores_start + ESC6_us <= micros()) digitalWrite(pin_motor6, LOW); // MOTOR 4
  // Monitor serie
But still doesn't work, any idea of what's happening?
You may want to add pin_motor5 and pin_motor6.
Usually, servos expect pulses every 20,000 microseconds (20 milliseconds - 50 Hz) and not every 6 milliseconds.
This variable should be 'volatile unsigned long'
Because 'RC_Throttle_raw' is volatile, this should be:
  noInterrupts();
  interrupts();
Does this library do Pin Change interrupts? Since you only have one, for now, I would change:
to
#define pin_Throttle 2 // Pin throttle del mando RC
and
to
attchInterupt(digitalPinToInterrupt(pin_Throttle), INT_Throttle, CHANGE);
That way you don't have to worry about the quality of a third-party library.
I assume that your drone has 3 or 4 propellers that create the lift.
Do you have protection-cages around your propellers and Bump-dampers all around your drone?
Developping a drone-controller from scratch is a somehow advanced project.
It is very likely that in the developping stage you will have some crashes.
So your drone should be crash-proof through the cages and the dampers
Is 3D printed, and I bogutht double of propellers, because due to it's construction, protector disadvantages become more than advantages.
PD: is an hexacopter with 6 propellers that lift, 4 for pitch and 6 for roll.
Thanks
The EnableInterrupt is because this is a fragment for testing, and comprove all works, after, we need to include more interrupts, so we need to have in account what problems could appear with third party libraries.
With the code before, 4 motors work, but the first configuration is slow, could be due the longitude of the pulse expected?
And what will be the practic changes of applying volatile unsigned long and the changes with noInterrupts?
It could be because you sit in a timing loop for some large portion of your CPU time:
  //  Nuevo ciclo
I would use the Servo library for output. It can handle up to 12 output pins and does everything in the background.
If you don't make the microsecond timer 'unsigned' it will go negative in 35.8 minutes.
If you don't protect the reading of the value from an interrupt, you will sometimes get mismatched bytes. The value will change between reading one byte and another.
Thanks,
PD: I tried with 20.000 and motors didn't respond, after, I changed it by 2.000 and it seems to respond faster except 1, the ESCs use oneshot125
A small question, there exist some kind of IDE where I can compare 2 codes and shows me the differences? I'ts because I made a first code, but I regret and I started a new one, but now I want to compare both and see differences and similitudes between them to improve both, unificating them in a better code.
The comment before apart, I have a prototype of full code completed, but I don't know why it doesn't work when the previous tests done before worked, it's like it doesn't pass from void setup whithout a LED iluminating, I read and read the code, but I can't find errors, any idea?
bool visu = 0  ;         // Visualizar variables por canal serie. En vuelo a 0!!
int visu_select = 0;   // 0: mando RC, 1: giro, 2: acc, 3: ang, 4: esc
bool MODO_vuelo = 1;   // 0: Modo acrobatico, 1: Modo estable (por defecto MODO_vuelo = 1)
#define usCiclo 6000   // Ciclo de ejecucion del software en microsegundos
#define pin_INT_Throttle 8  // Pin Throttle del mando RC
#define pin_INT_Yaw 7       // Pin Yaw del mando RC
#define pin_INT_Pitch 12    // Pin Pitch del mando RC
#define pin_INT_Roll 9      // Pin Roll del mando RC
#define pin_LED_rojo2 A2    // Pin LED rojo 2
#include <Wire.h>
// AJUSTE DE PIDs
// Modificar estos parámetros apara ajustar los PID
float Roll_ang_Kp  = 0.5, Roll_ang_Ki  = 0.05, Roll_ang_Kd  = 10;
float Pitch_ang_Kp = 0.5, Pitch_ang_Ki = 0.05, Pitch_ang_Kd = 10;
float Pitch_W_Kp   = 2,   Pitch_W_Ki   = 0.02, Pitch_W_Kd   = 0;
float Roll_W_Kp    = 2,   Roll_W_Ki    = 0.02, Roll_W_Kd    = 0;
float Yaw_W_Kp     = 1,   Yaw_W_Ki     = 0.05, Yaw_W_Kd     = 0;
int PID_W_sat1   = 380;  // Limitar parte integral PID velocidad
int PID_W_sat2   = 380;  // Limitar salida del PID velocidad
int PID_ang_sat1 = 130;  // Limitar parte integral PID ángulo
int PID_ang_sat2 = 130;  // Limitar salida del PID ángulo
float PID_ang_Pitch_error, PID_ang_Pitch_P, PID_ang_Pitch_I, PID_ang_Pitch_D, PID_ang_Pitch_OUT;
float PID_ang_Roll_error, PID_ang_Roll_P, PID_ang_Roll_I, PID_ang_Roll_D, PID_ang_Roll_OUT;
float PID_ang_Yaw_error, PID_ang_Yaw_P, PID_ang_Yaw_I, PID_ang_Yaw_D, PID_ang_Yaw_OUT;
float PID_W_Pitch_error, PID_W_Pitch_P, PID_W_Pitch_I, PID_W_Pitch_D, PID_W_Pitch_OUT;
float PID_W_Roll_error, PID_W_Roll_P, PID_W_Roll_I, PID_W_Roll_D, PID_W_Roll_OUT;
float PID_W_Yaw_error, PID_W_Yaw_P, PID_W_Yaw_I, PID_W_Yaw_D, PID_W_Yaw_OUT;
float PID_W_Pitch_consigna, PID_W_Roll_consigna;
const int us_max_Throttle_adj = 1800;
const int us_min_Throttle_adj = 970;
const float us_max_Throttle_raw = 2004;  // <-- Si la entrada Throttle está invertida sustituir este valor
// AJUSTE MANDO RC - PITCH
const float us_max_Pitch_raw = 1952;
const float us_min_Pitch_raw = 992;
const int us_max_Pitch_adj = -30;  // <-- Si la entrada Pitch está invertida sustituir este valor
const int us_min_Pitch_adj = 30;   // <-- por este y viceversa
// AJUSTE MANDO RC - ROLL
const float us_max_Roll_raw = 1960;
const float us_min_Roll_raw = 992;
const int us_max_Roll_adj = 30;    // <-- Si la entrada Roll está invertida sustituir este valor
const int us_min_Roll_adj = -30;   // <-- por este y viceversa
// AJUSTE MANDO RC - YAW
const float us_max_Yaw_raw = 1928;
const float us_min_Yaw_raw = 972;
const int us_max_Yaw_adj = 30;     // <-- Si la entrada Yaw está invertida sustituir este valor
const int us_min_Yaw_adj = -30;    // <-- por este y viceversa
// MPU6050
#define MPU6050_adress 0x68
float angulo_pitch, angulo_roll, angulo_yaw, angulo_pitch_acc, angulo_roll_acc, temperature;
float angulo_pitch_ant, angulo_roll_ant, angulo_yaw_ant;
int gx, gy, gz, gyro_Z, gyro_X, gyro_Y, gyro_X_ant, gyro_Y_ant, gyro_Z_ant;
float gyro_X_cal, gyro_Y_cal, gyro_Z_cal;
float ax, ay, az, acc_X_cal, acc_Y_cal, acc_Z_cal, acc_total_vector;
bool set_gyro_angles, accCalibOK = false;
float tiempo_ejecucion_MPU6050, tiempo_MPU6050_1;
// TIEMPOS
long loop_timer, loop_timer1, tiempo_motores_start, tiempo_ON, tiempo_1, tiempo_2;
// LECTURA TENSIÓN DE BATERÍA
bool LOW_BAT_WARING = false;
float tension_bateria, lectura_ADC;
int LOW_BAT_WARING_cont;
// OTROS
int LED_contador;
/// SEÑALES PWM
float ESC1_us, ESC2_us, ESC3_us, ESC4_us, ESC5_us, ESC6_us;
// MANDO RC
float RC_Throttle_filt, RC_Pitch_filt, RC_Yaw_filt, RC_Roll_filt;
float RC_Throttle_consigna, RC_Pitch_consigna, RC_Roll_consigna, RC_Yaw_consigna;
// LEER MANDO RC - TROTTLE
  if (digitalRead(pin_INT_Throttle) == HIGH)Throttle_HIGH_us = micros();
  if (digitalRead(pin_INT_Throttle) == LOW) RC_Throttle_raw  = micros() - Throttle_HIGH_us;
// INTERRUPCIÓN MANDO RC - PITCH
volatile long Pitch_HIGH_us;
volatile int RC_Pitch_raw;
void INT_Pitch() {
  if (digitalRead(pin_INT_Pitch) == HIGH)Pitch_HIGH_us = micros();
  if (digitalRead(pin_INT_Pitch) == LOW) RC_Pitch_raw  = micros() - Pitch_HIGH_us;
// INTERRUPCIÓN MANDO RC - ROLL
volatile long Pitch_Roll_us;
volatile int RC_Roll_raw;
void INT_Roll() {
  if (digitalRead(pin_INT_Roll) == HIGH)Pitch_Roll_us = micros();
  if (digitalRead(pin_INT_Roll) == LOW) RC_Roll_raw   = micros() - Pitch_Roll_us;
// INTERRUPCIÓN MANDO RC - YAW
volatile long Pitch_Yaw_us;
volatile int RC_Yaw_raw;
void INT_Yaw() {
  if (digitalRead(pin_INT_Yaw) == HIGH)Pitch_Yaw_us = micros();
  if (digitalRead(pin_INT_Yaw) == LOW) RC_Yaw_raw   = micros() - Pitch_Yaw_us;
  // Iniciar I2C
  Wire.begin();
  if (visu == 1) {
    // Solo iniciamos el monitor serie y aguno de los modos de visualización está activo
    // Avisar de que el modo visualización está activo encendiendo el LED naranja
    analogWrite(pin_LED_rojo2, 255);
  // Declaración de LEDs
  pinMode(pin_LED_rojo2, OUTPUT); // Led naranja --> Batería baja
  pinMode(pin_LED_rojo2, OUTPUT);   // Led rojo 2  --> Tiempo de ciclo o de 1ms excedido
  // MandoRC: declaración de interrupciones
  pinMode(pin_INT_Yaw, INPUT_PULLUP);
  enableInterrupt(pin_INT_Yaw, INT_Yaw, CHANGE);
  pinMode(pin_INT_Throttle, INPUT_PULLUP);
  enableInterrupt(pin_INT_Throttle, INT_Throttle, CHANGE);
  pinMode(pin_INT_Pitch, INPUT_PULLUP);
  enableInterrupt(12, INT_Pitch, CHANGE);
  pinMode(pin_INT_Roll, INPUT_PULLUP);
  enableInterrupt(pin_INT_Roll, INT_Roll, CHANGE);
  // Declaración de los pines de los motores
  pinMode(pin_motor1, OUTPUT);  //Motor 1
  pinMode(pin_motor2, OUTPUT);  //Motor 2
  pinMode(pin_motor3, OUTPUT);  //Motor 3
  pinMode(pin_motor4, OUTPUT);  //Motor 4
  pinMode(pin_motor5, OUTPUT);  //Motor 4
  pinMode(pin_motor6, OUTPUT);  //Motor 4
  // Forzar los pines a estado LOW
  // Para poder avanzar hay que encender el mando y bajar Throttle al mínimo
  digitalWrite(pin_LED_rojo2, HIGH);
  while (RC_Throttle_consigna < 950 || RC_Throttle_consigna > 1050) RC_procesar();
  digitalWrite(pin_LED_rojo2, LOW);
  MPU6050_iniciar();         // Iniciar sensor MPU6050
  MPU6050_calibrar();        // Calibrar sensor MPU6050
  Lectura_tension_bateria(); // Leer tension de batería
  // Para entrar el loop principal hay que mover el stick de Roll a la derecha
  while (RC_Roll_consigna < 10)RC_procesar();
  // Si se supera el tiempo de ciclo, se activa el LED rojo 2
  if (micros() - loop_timer > usCiclo + 50) digitalWrite(pin_LED_rojo2, HIGH);
  // Comienzo de un nuevo ciclo
  // Registrar instante de comienzo del ciclo
  PWM();                           // Generar señales PWM para los motores
  MPU6050_leer();                  // Leer sensor MPU6050
  MPU6050_procesar();              // Procesar datos del sensor MPU6050
  if (MODO_vuelo == 1)PID_ang();   // Obtener salida de los PID de inclinación
  PID_w();                         // Obtener salida de los PID de velocidad
  Modulador();                     // Modulador o generador de señales para PWM
  // Guardamos las lecturas del sensor MPU6050 para el siguiente ciclo (necesario para los PID)
  angulo_pitch_ant = angulo_pitch;
  angulo_roll_ant  = angulo_roll;
  angulo_yaw_ant   = angulo_yaw;
  gyro_X_ant = gyro_X; // Pitch
  gyro_Y_ant = gyro_Y; // Roll
  gyro_Z_ant = gyro_Z; // Yaw
  // Visualización de variables
  if (visu == 1)Visualizaciones();
void MPU6050_iniciar() {
  Wire.beginTransmission(MPU6050_adress);
  Wire.write(0x6B);                                                          //Registro 6B hex)
  Wire.write(0x00);                                                          //00000000 para activar giroscopio
  Wire.endTransmission();
  Wire.write(0x1B);                                                          //Register 1B hex
  Wire.write(0x08);                                                          //Girscopio a 500dps (full scale)
  Wire.write(0x1C);                                                          //Register (1A hex)
  Wire.write(0x10);                                                          //Acelerometro a  +/- 8g (full scale range)
  Wire.write(0x1B);
  Wire.requestFrom(MPU6050_adress, 1);
  while (Wire.available() < 1);
  // Si hay un error en el sensor MPU6050 avisamos y enclavamos el programa
  if (Wire.read() != 0x08) {
    while (1) {
  // Activar y configurar filtro pasa bajos LPF que incorpora el sensor
  Wire.write(0x1A);
  Wire.write(0x04);
    Frecuencia de corte del filtro pasa bajos:
    256Hz(0ms):0x00
    188Hz(2ms):0x01
    98Hz(3ms):0x02
    42Hz(4.9ms):0x03
    20Hz(8.5ms):0x04
    10Hz(13.8ms):0x05
    5Hz(19ms):0x06
void MPU6050_calibrar() {
  // Calibrar giroscopio tomando 3000 muestras
  for (int cal_int = 0; cal_int < 3000 ; cal_int ++) {
    MPU6050_leer();
    gyro_X_cal += gx;
    gyro_Y_cal += gy;
    gyro_Z_cal += gz;
    acc_X_cal  += ax;
    acc_Y_cal  += ay;
    acc_Z_cal  += az;
    delayMicroseconds(20);
  // Calcular el valor medio de las 3000 muestras
  gyro_X_cal = gyro_X_cal / 3000;
  gyro_Y_cal = gyro_Y_cal / 3000;
  gyro_Z_cal = gyro_Z_cal / 3000;
  acc_X_cal  = acc_X_cal  / 3000;
  acc_Y_cal  = acc_Y_cal  / 3000;
  acc_Z_cal  = acc_Z_cal  / 3000;
  accCalibOK = true;
void MPU6050_leer() {
  // Los datos del giroscopio y el acelerómetro se encuentran de la dirección 3B a la 14
  Wire.beginTransmission(MPU6050_adress);       // Empezamos comunicación
  Wire.write(0x3B);                             // Pedir el registro 0x3B (AcX)
  Wire.requestFrom(MPU6050_adress, 14);         // Solicitar un total de 14 registros
  while (Wire.available() < 14);                // Esperamos hasta recibir los 14 bytes
  ax = Wire.read() << 8 | Wire.read();          // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
  ay = Wire.read() << 8 | Wire.read();          // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
  az = Wire.read() << 8 | Wire.read();          // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
  temperature = Wire.read() << 8 | Wire.read(); // 0x41 (TEMP_OUT_H)   & 0x42 (TEMP_OUT_L)
  gx = Wire.read() << 8 | Wire.read();          // 0x43 (GYRO_XOUT_H)  & 0x44 (GYRO_XOUT_L)
  gy = Wire.read() << 8 | Wire.read();          // 0x45 (GYRO_YOUT_H)  & 0x46 (GYRO_YOUT_L)
  gz = Wire.read() << 8 | Wire.read();          // 0x47 (GYRO_ZOUT_H)  & 0x48 (GYRO_ZOUT_L)
  // Restar valores de calibracion del acelerómetro
  if (accCalibOK == true) {
    ax -= acc_X_cal;
    ay -= acc_Y_cal;
    az -= acc_Z_cal;
    az = az + 4096;
// Cálculo de velocidad angular (º/s) y ángulo (º)
void MPU6050_procesar() {
  // Restar valores de calibración del acelerómetro y calcular
  // velocidad angular en º/s. Leer 65.5 en raw equivale a 1º/s
  gyro_X = (gx - gyro_X_cal) / 65.5;
  gyro_Y = (gy - gyro_Y_cal) / 65.5;
  gyro_Z = (gz - gyro_Z_cal) / 65.5;
  // Calculamos exactamente cuánto tiempo ha pasado desde que se ha ejecutado el cálculo del ángulo.
  // Al tener señales PWM variables entre 1 y 2ms, este cálculo del ángulo no se ejecuta siempre
  // con un periodo constante.
  tiempo_ejecucion_MPU6050 = (micros() - tiempo_MPU6050_1) / 1000;
  // Calcular ángulo de inclinación con datos de giroscopio:
  // velocidad (º/s) * tiempo (s) = grados de inclinación (º)
  angulo_pitch += gyro_X * tiempo_ejecucion_MPU6050 / 1000;
  angulo_roll  += gyro_Y * tiempo_ejecucion_MPU6050 / 1000;
  // 0.000000266 = tiempo_ejecucion / 1000 / 65.5 * PI / 180
  angulo_pitch += angulo_roll  * sin((gz - gyro_Z_cal) * tiempo_ejecucion_MPU6050 * 0.000000266);
  angulo_roll  -= angulo_pitch * sin((gz - gyro_Z_cal) * tiempo_ejecucion_MPU6050 * 0.000000266);
  tiempo_MPU6050_1 = micros();
  // Calcular vector de aceleración
  // 57.2958 = Conversion de radianes a grados 180/PI
  acc_total_vector = sqrt(pow(ay, 2) + pow(ax, 2) + pow(az, 2));
  angulo_pitch_acc = asin((float)ay / acc_total_vector) * 57.2958;
  angulo_roll_acc  = asin((float)ax / acc_total_vector) * -57.2958;
  if (set_gyro_angles) {
    // Filtro complementario
    angulo_pitch = angulo_pitch * 0.995 + angulo_pitch_acc * 0.005;   // Angulo Pitch de inclinacion
    angulo_roll  = angulo_roll  * 0.995 + angulo_roll_acc  * 0.005;   // Angulo Roll de inclinacion
  else {
    angulo_pitch = angulo_pitch_acc;
    angulo_roll  = angulo_roll_acc;
    set_gyro_angles = true;
void RC_procesar() {
  //  Filtrado de lecturas raw del mando RC
  RC_Throttle_filt = RC_Throttle_filt * 0.9 + RC_Throttle_raw * 0.1;
  RC_Pitch_filt    = RC_Pitch_filt * 0.9 + RC_Pitch_raw * 0.1;
  RC_Roll_filt     = RC_Roll_filt  * 0.9 + RC_Roll_raw  * 0.1;
  RC_Yaw_filt      = RC_Yaw_filt   * 0.9 + RC_Yaw_raw   * 0.1;
  // Mapeo de señales del mando RC
  RC_Throttle_consigna = map(RC_Throttle_filt, us_min_Throttle_raw, us_max_Throttle_raw, us_min_Throttle_adj, us_max_Throttle_adj);
  RC_Pitch_consigna    = map(RC_Pitch_filt, us_min_Pitch_raw, us_max_Pitch_raw, us_min_Pitch_adj, us_max_Pitch_adj);
  RC_Roll_consigna     = map(RC_Roll_filt, us_min_Roll_raw, us_max_Roll_raw, us_min_Roll_adj, us_max_Roll_adj);
  RC_Yaw_consigna      = map(RC_Yaw_filt, us_min_Yaw_raw, us_max_Yaw_raw, us_min_Yaw_adj, us_max_Yaw_adj);
  // Si las lecturas son cercanas a 0, las forzamos a 0 para evitar inclinar el drone por error (us)
  if (RC_Pitch_consigna < 3 && RC_Pitch_consigna > -3)RC_Pitch_consigna = 0;
  if (RC_Roll_consigna  < 3 && RC_Roll_consigna  > -3)RC_Roll_consigna  = 0;
  if (RC_Yaw_consigna   < 3 && RC_Yaw_consigna   > -3)RC_Yaw_consigna   = 0;
void Modulador() {
  // Si el Throttle es menos a 1300us, el control de estabilidad se desactiva. La parte integral
  // de los controladores PID se fuerza a 0.
  if (RC_Throttle_consigna <= 1300) {
    PID_W_Pitch_I = 0;
    PID_W_Roll_I = 0;
    PID_W_Yaw_I  = 0;
    PID_ang_Pitch_I = 0;
    PID_ang_Roll_I = 0;
    // Si lo motores giran con el stick de Throttle al mínimo, recudir el valor de 950us
    if (ESC1_us < 1000) ESC1_us = 950*0.125;
    if (ESC2_us < 1000) ESC2_us = 950*0.125;
    if (ESC3_us < 1000) ESC3_us = 950*0.125;
    if (ESC4_us < 1000) ESC4_us = 950*0.125;
    if (ESC5_us < 1000) ESC3_us = 950*0.125;
    if (ESC6_us < 1000) ESC4_us = 950*0.125;
  // Si el throttle es mayor a 1300us, el control de estabilidad se activa.
  else {
    // Limitar throttle a 1800 para dejar margen a los PID
    if (RC_Throttle_consigna > 1800)RC_Throttle_consigna = 1800;
    // Modulador
    ESC1_us = (RC_Throttle_consigna - PID_W_Roll_OUT - PID_W_Yaw_OUT)*0.125; // Motor 1
    ESC2_us = (RC_Throttle_consigna + PID_W_Pitch_OUT - PID_W_Roll_OUT + PID_W_Yaw_OUT)*0.125; // Motor 2
    ESC3_us = (RC_Throttle_consigna - PID_W_Pitch_OUT + PID_W_Roll_OUT - PID_W_Yaw_OUT)*0.125; // Motor 3
    ESC4_us = (RC_Throttle_consigna + PID_W_Roll_OUT + PID_W_Yaw_OUT)*0.125; // Motor 4
    ESC1_us = (RC_Throttle_consigna + PID_W_Pitch_OUT + PID_W_Roll_OUT - PID_W_Yaw_OUT)*0.125; // Motor 5
    ESC2_us = (RC_Throttle_consigna + PID_W_Pitch_OUT - PID_W_Roll_OUT + PID_W_Yaw_OUT)*0.125; // Motor 6
    //    ESC1_us = RC_Throttle_filt; // Solo para testeos
    //    ESC2_us = RC_Throttle_filt;
    //    ESC3_us = RC_Throttle_filt;
    //    ESC4_us = RC_Throttle_filt;
    // Evitamos que alguno de los motores de detenga completamente en pleno vuelo
    if (ESC1_us < 1100) ESC1_us = 1100*0.125;
    if (ESC2_us < 1100) ESC2_us = 1100*0.125;
    if (ESC3_us < 1100) ESC3_us = 1100*0.125;
    if (ESC4_us < 1100) ESC4_us = 1100*0.125;
    if (ESC5_us < 1100) ESC5_us = 1100*0.125;
    if (ESC6_us < 1100) ESC6_us = 1100*0.125;
    // Evitamos mandar consignas mayores a 2000us a los motores
    if (ESC1_us > 2000) ESC1_us = 2000*0.125;
    if (ESC2_us > 2000) ESC2_us = 2000*0.125;
    if (ESC3_us > 2000) ESC3_us = 2000*0.125;
    if (ESC4_us > 2000) ESC4_us = 2000*0.125;
    if (ESC5_us > 2000) ESC3_us = 2000*0.125;
    if (ESC6_us > 2000) ESC4_us = 2000*0.125;
void PWM() {
  // ------------------ ¡¡1ms max!! ------------------
  tiempo_1 = micros();
  RC_procesar();             // Leer mando RC
  LED_blink();               // LED parpadeo
  Lectura_tension_bateria(); // Leer Vbat
  // Si la duracion entre tiempo_1 y tiempo_2 ha sido mayor de 900us, encender LED de aviso.
  // Nunca hay que sobrepasar 1ms de tiempo en estado HIGH.
  tiempo_2 = micros();
  tiempo_ON = tiempo_2 - tiempo_1;
  if (tiempo_ON > 900) digitalWrite(pin_LED_rojo2, HIGH);
  // Pasamos las señales PWM a estado LOW cuando haya transcurrido el tiempo definido en las variables ESCx_us
  while (digitalRead(pin_motor1) == HIGH || digitalRead(pin_motor2) == HIGH || digitalRead(pin_motor3) == HIGH || digitalRead(pin_motor4) == HIGH || digitalRead(pin_motor5) == HIGH || digitalRead(pin_motor6) == HIGH) {
// PID ángulo
void PID_ang() {
  // PID ángulo - PITCH
  PID_ang_Pitch_error = RC_Pitch_consigna - angulo_pitch;                        // Error entre lectura y consigna
  PID_ang_Pitch_P  = Pitch_ang_Kp  * PID_ang_Pitch_error;                        // Parte proporcional
  PID_ang_Pitch_I += (Pitch_ang_Ki * PID_ang_Pitch_error);                       // Parte integral (sumatorio del error en el tiempo)
  PID_ang_Pitch_I  = constrain(PID_ang_Pitch_I, -PID_ang_sat1, PID_ang_sat1);    // Limitar parte integral
  PID_ang_Pitch_D  = Pitch_ang_Kd * (angulo_pitch - angulo_pitch_ant);           // Parte derivativa (diferencia entre el error actual y el anterior)
  PID_ang_Pitch_OUT =  PID_ang_Pitch_P + PID_ang_Pitch_I + PID_ang_Pitch_D;      // Salida PID
  PID_ang_Pitch_OUT = constrain(PID_ang_Pitch_OUT, -PID_ang_sat2, PID_ang_sat2); // Limitar salida del PID
  // PID ángulo - ROLL
  PID_ang_Roll_error = RC_Roll_consigna - angulo_roll;                           // Error entre lectura y consigna
  PID_ang_Roll_P  = Roll_ang_Kp  * PID_ang_Roll_error;                           // Parte proporcional
  PID_ang_Roll_I += (Roll_ang_Ki * PID_ang_Roll_error);                          // Parte integral (sumatorio del error en el tiempo)
  PID_ang_Roll_I  = constrain(PID_ang_Roll_I, -PID_ang_sat1, PID_ang_sat1);      // Limitar parte integral
  PID_ang_Roll_D  = Roll_ang_Kd * (angulo_roll - angulo_roll_ant);               // Parte derivativa (diferencia entre el error actual y el anterior)
  PID_ang_Roll_OUT = PID_ang_Roll_P + PID_ang_Roll_I + PID_ang_Roll_D;           // Salida PID
  PID_ang_Roll_OUT = constrain(PID_ang_Roll_OUT, -PID_ang_sat2, PID_ang_sat2);   // Limitar salida del PID
// PID velocidad angular
void PID_w() {
  // En funcion del modo de vuelo que hayamos seleccionado, las consignas de los PID serán diferentes
  if (MODO_vuelo == 0) {
    // En modo acrobático solo controlamos la velocidad de cada eje (un PID por eje). La consigna del PID se da en º/s
    // y viene directamente del mando RC
    PID_W_Pitch_consigna = RC_Pitch_consigna;
    PID_W_Roll_consigna  = RC_Roll_consigna;
  else {
    // En modo estable las consignas de los PID de velocidad vienen de las salidas de los PID de ángulo
    PID_W_Pitch_consigna = PID_ang_Pitch_OUT;
    PID_W_Roll_consigna  = PID_ang_Roll_OUT;
  // PID velocidad - PITCH
  PID_W_Pitch_error = PID_W_Pitch_consigna - gyro_X;                       // Error entre lectura y consigna
  PID_W_Pitch_P  = Pitch_W_Kp  * PID_W_Pitch_error;                        // Parte proporcional
  PID_W_Pitch_I += (Pitch_W_Ki * PID_W_Pitch_error);                       // Parte integral (sumatorio del error en el tiempo)
  PID_W_Pitch_I  = constrain(PID_W_Pitch_I, -PID_W_sat1, PID_W_sat1);      // Limitar parte integral
  PID_W_Pitch_D  = Pitch_W_Kd * (gyro_X - gyro_X_ant);                     // Parte derivativa (diferencia entre el error actual y el anterior)
  PID_W_Pitch_OUT = PID_W_Pitch_P + PID_W_Pitch_I + PID_W_Pitch_D;         // Salida PID
  PID_W_Pitch_OUT = constrain(PID_W_Pitch_OUT, -PID_W_sat2, PID_W_sat2);   // Limitar salida del PID
  // PID velocidad - ROLL
  PID_W_Roll_error = PID_W_Roll_consigna - gyro_Y;                         // Error entre lectura y consigna
  PID_W_Roll_P  = Roll_W_Kp  * PID_W_Roll_error;                           // Parte proporcional
  PID_W_Roll_I += (Roll_W_Ki * PID_W_Roll_error);                          // Parte integral (sumatorio del error en el tiempo)
  PID_W_Roll_I  = constrain(PID_W_Roll_I, -PID_W_sat1, PID_W_sat1);        // Limitar parte integral
  PID_W_Roll_D  = Roll_W_Kd * (gyro_Y - gyro_Y_ant);                       // Parte derivativa (diferencia entre el error actual y el anterior)
  PID_W_Roll_OUT = PID_W_Roll_P + PID_W_Roll_I + PID_W_Roll_D;             // Salida PID
  PID_W_Roll_OUT = constrain(PID_W_Roll_OUT, -PID_W_sat2, PID_W_sat2);     // Limitar salida del PID
  // PID velocidad - YAW
  PID_W_Yaw_error = RC_Yaw_consigna - gyro_Z;                              // Error entre lectura y consigna
  PID_W_Yaw_P  = Yaw_W_Kp  * PID_W_Yaw_error;                              // Parte proporcional
  PID_W_Yaw_I += (Yaw_W_Ki * PID_W_Yaw_error);                             // Parte integral (sumatorio del error en el tiempo)
  PID_W_Yaw_I  = constrain(PID_W_Yaw_I, -PID_W_sat1, PID_W_sat1);          // Limitar parte integral
  PID_W_Yaw_D  = Yaw_W_Kd * (gyro_Z - gyro_Z_ant);                         // Parte derivativa (diferencia entre el error actual y el anterior)
  PID_W_Yaw_OUT = PID_W_Yaw_P + PID_W_Yaw_I + PID_W_Yaw_D;                 // Salida PID
  PID_W_Yaw_OUT = constrain(PID_W_Yaw_OUT, -PID_W_sat2, PID_W_sat2);       // Limitar salida del PID
void Lectura_tension_bateria() {
  // La tensión de batería solo se lee con Throttle inferior a 1100us
  if (RC_Throttle_consigna < 1100) {
    // Leer entrada analógica
    lectura_ADC = analogRead(A6);
    tension_bateria = 2.95 * (lectura_ADC * 4.92  / 1023);
    // Si la tension de batería es inferior a 10.5V durante un número de ciclos consecutivos
    // se activa la señal de batería baja
    if (tension_bateria < 10.5 && LOW_BAT_WARING == false) {
      LOW_BAT_WARING_cont++;
      if (LOW_BAT_WARING_cont > 30)LOW_BAT_WARING = true;
    else LOW_BAT_WARING_cont = 0;
// Función para hacer parpadear el LED al entrar en el loop() principal
void LED_blink() {
  if (LED_contador % 20 == 0) {
  LED_contador++;
// Visualizar variables por Monitor Serie
// NOTA: al visualizar variables por el Monitor Serie es posible que se sobrepase el tiempo de ciclo establecido
// debido al tiempo extra que conlleva visualizar las variables. Esta es la razón de desactivar esta opción en
// vuelo.
void Visualizaciones() {
  // Hay que seleccionar qué variable visualizar con visu_select
  if (visu == 1) {
    if (visu_select == 0) {
      Serial.print(RC_Pitch_consigna);
      Serial.print("\t");
      Serial.print(RC_Roll_consigna);
      Serial.print("\t");
      Serial.print(RC_Yaw_consigna);
      Serial.print("\t");
    if (visu_select == 1) {
      Serial.print((gx - gyro_X_cal) / 16.4);
      Serial.print("\t");
      Serial.print((gy - gyro_Y_cal) / 16.4);
      Serial.print("\t");
      Serial.println((gz - gyro_Z_cal) / 16.4);
    if (visu_select == 2) {
      Serial.print(ax / 4096);
      Serial.print("\t");
      Serial.print(ay / 4096);
      Serial.print("\t");
      Serial.println(az / 4096);
    if (visu_select == 3) {
      Serial.print(angulo_pitch);
      Serial.print("\t");
      Serial.println(angulo_roll);
    if (visu_select == 4) {
      Serial.print(ESC1_us);
      Serial.print("\t");
      Serial.print(ESC2_us);
      Serial.print("\t");
      Serial.print(ESC3_us);
      Serial.print("\t");
      Serial.println(ESC4_us);
      Pitch_W_Ki = 0;
      Roll_W_Ki  = 0;
      Yaw_W_Ki   = 0;
      Pitch_ang_Ki = 0;
      Roll_ang_Ki  = 0;
    if (visu_select == 999) {
      Serial.println(tiempo_ejecucion_MPU6050);
my idea is to add serial debugoutput at all places you suspect might be the reason.
or if serial output slow down too much then add a switch LED on at the place of interest.
The problem is that it seems to not start the void setup, 0 response on serial port (further than in the example is desactivated) and I don't know why.
change void setup to start the serial interface as the very first thing
  Serial.println("Setup-Start next Wire.begin();");
  // Iniciar I2C
  Wire.begin();
  Serial.println("Wire.begin(); done");
  if (visu == 1) {
    //Serial.begin(115200);
My estimation is Wire.begin() hangs (for whatever reason)
Hi @arxi
Notepad++ compare plugin works well, and highlights differences between code. Notepad++ can be downloaded here:
https://notepad-plus-plus.org/
Once downloaded, just go to the menu bar and select Plugins->Plugins Admin... In the Plugins Admin dialogue box tick the "Compare" checkbox from the list and press the "Install" button. Notepad++ will restart itself for the plugin to take effect.
Returning back to the "Plugins" drop down menu select the "Compare" option. The compare plugin will allow you to select the first and second files to compare them.
