Help with my fallback routine / Timer issues
Greetings!
After some successful projects, I'm struggeling with this simple code:
The first trigger impulse activates flash1. If there is a second trigger impuls, then flash2 will be triggered. So far, so good.
I'd like to implement a fallback routine, that switches back to flash1 again if there is no second trigger impulse within e. g. 5 seconds.
I've tried the TimerOne library, but in my code the fallback timer runs free so there is no defined timing.
I'd have a timer, that starts after the first trigger and is waiting for the next trigger within 5 seconds. If there is no second trigger within 5 sec. then flash1 should become active again.
Any ideas?
#include "TimerOne.h"
#include "pitches.h"
int flash1 = 2; // Front Flash
int flash2 = 3; // Mask Flash
int button = 5; // Trigger
int trig;  // Trigger State
int count; // Flash switching
int fallbacktime=5;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(flash1, OUTPUT);
  pinMode(flash2, OUTPUT);
  pinMode(trig, INPUT);
  count=0;
  trig=0;
  digitalWrite(flash1, LOW);
  digitalWrite(flash2, LOW);
    Timer1.attachInterrupt(fb);
    Timer1.initialize(fallbacktime*1000000);
// fallback tryout
void fb() {
      if (count == 1) {
        count = 0;
        tone(8, 2000, 70);
// the loop
  trig = digitalRead(button);
  // waiting for the very first flash trigger signal
  if (trig == HIGH && count == 0) {
    digitalWrite(flash1, HIGH);
    delay (20);
    count = 1; // switch to the second flash
    delay (100);
  // if there is a second flash trigger within 5 seconds, trigger the second flash
  if (trig == HIGH && count == 1) {
    digitalWrite(flash2, HIGH);
    delay (20);
    delay (100);
    count = 0; // switch back to the first flash
When flash 1 happens save the current value of millis(). At the end of loop() test whether 5 seconds have elapsed since the first flash
if (millis() - flash1Time >= 5000)
and set count back to 0 if it has.
The delay()s are a nuisance and it would be better to use millis() timing throughout but try the simple test for 5 seconds first to get the idea.
Of course! Thank you for kicking me in the right direction ;-)
