Help with my first project!
I'm making something that detects an input from a flow meter. It pulses 4.5 times in a second. If water flows through, I want it to trigger my system. When it's activated, it waits 20 seconds and then it checks if water's still flowing. If water is still flowing through the flow meter, I want it to activate the LED. If the water has stopped flowing through the flow meter, the LED will get switched off. I think the problem I have may be due to the fact that the flow meter pulses. I simply want to know whether water is flowing through or not. How can I change the code to reflect this?
I need to finish this soon, if you could show me what's wrong and show me what it should say instead, I'd really appreciate it. Thank you!
const int sensorPin = 2;     // the digital pin which has the sensor - this may need to be an analog pin?
const int ledPin =  3;      // the number of the LED pin
// variables will change:
int sensorState = 0;         // variable for reading the sensor status
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the sensor pin as an input:
  pinMode(sensorPin, INPUT);
  // read the state of the sensor value:
  sensorState = digitalRead(sensorPin);
  // check if the sensor is activated.
  // if it is, the sensorState is HIGH:
  if (sensorState == HIGH) {
    delay(20000); // delay for 20 seconds before reading again
      // turn LED on:
      digitalWrite(ledPin, HIGH);
      // turn LED off:
      digitalWrite(ledPin, LOW);
I don't normally post a complete solution here but the original post has a good specification and a good attempt at making it work. The code below compiles but it hasn't been tested as I don't have a suitable pulse-maker close to hand.
const unsigned long NO_FLOW_TIMEOUT = 300; //milliseconds. If we don't get a pulse within this time, consider that flow has stopped.
                                           //Make this number just a bit longer than the expected pulse interval at the lowest flow.
const unsigned long WAIT_PERIOD = 20000;   //milliseconds. The amount of time that flow must exist before turning on the output LED.
unsigned long LastPulseDetected = 0;
unsigned long FirstFlowDetected = 0;
  int sensorState = digitalRead(sensorPin);
  // check if the sensor is currently sending an active pulse.
    if(millis() - LastPulseDetected > NO_FLOW_TIMEOUT) {
      //flow has just started
      FirstFlowDetected = millis();
      //pulse arrived within timeout, flow is still flowing
    LastPulseDetected = millis(); //record that we got a pulse
  if(millis() - LastPulseDetected < NO_FLOW_TIMEOUT && millis() - FirstFlowDetected > WAIT_PERIOD) {
    //flow is still flowing and it has been flowing for more than the wait period
Is there a defined relationship between flow and output pulses?
What do you mean by "4.5 pulses" ? Is that a 100% are just a little bit of flow?
Do you want to detect if there is some flow at all?
