Hi there!
Since I finally run a GU256x128C-3900, now I have another challenge. Try to run Noritake Itron GU256x64-372 with Uno.
Small Datasheet -> http://media.digikey.com/pdf/Data%20Sheets/Noritake%20PDFs/GU256X64-372.pdf
Full Datasheet -> http://cypax.net/downloads/A0%20GU256X64-372.pdf
Code for WinAVR -> http://kimboricha.blogspot.kr/2013/10/noritake-itron-gu256x64-901a-vfdvacuum.html
I can't use any example on net with Arduino.
Tryed too with other routines that connect with a parallel LCD, but this model use a 2us delay instead BUSY signal.
I need to fix the code above to accept communications with GU256x64-372. The GU7000 library for Arduino, appear to be good for use.
class GU7000_Parallel : public GU7000_Interface {
protected:
unsigned RS_PIN:4;
unsigned WR_PIN:4;
unsigned RD_PIN:4;
unsigned RESET_PIN:4;
unsigned BUSY_PIN:4;
unsigned D0_PIN:4;
unsigned D1_PIN:4;
unsigned D2_PIN:4;
unsigned D3_PIN:4;
unsigned D4_PIN:4;
unsigned D5_PIN:4;
unsigned D6_PIN:4;
unsigned D7_PIN:4;
unsigned jrb:2; // Pin#3 (JRB jumper): 0=BUSY, 1=RESET, 2=nonthing
public:
GU7000_Parallel(uint8_t jrb,
uint8_t busy, uint8_t reset, uint8_t wr, uint8_t rd,
uint8_t d0, uint8_t d1, uint8_t d2, uint8_t d3,
uint8_t d4, uint8_t d5, uint8_t d6, uint8_t d7):
jrb(2), BUSY_PIN(busy), RESET_PIN(reset), WR_PIN(wr), RD_PIN(rd),
D0_PIN(d0), D1_PIN(d1), D2_PIN(d2), D3_PIN(d3),
D4_PIN(d4), D5_PIN(d5), D6_PIN(d6), D7_PIN(d7)
if ((jrb|0x20) == 'b') this->jrb = 0;
if ((jrb|0x20) == 'r') this->jrb = 1;
void init() {
if (this->jrb == 1) {
RAISE(RESET);
DIRECTION(RESET, 1);
if (this->jrb != 0) {
RAISE(RD);
DIRECTION(RD, 1);
RAISE(WR);
DIRECTION(BUSY, 0);
DIRECTION(WR, 1);
DIRECTION(D0, 1);
DIRECTION(D1, 1);
DIRECTION(D2, 1);
DIRECTION(D3, 1);
DIRECTION(D4, 1);
DIRECTION(D5, 1);
DIRECTION(D6, 1);
DIRECTION(D7, 1);
void write(uint8_t data) {
if (data & 0x01) RAISE(D0); else LOWER(D0);
if (data & 0x02) RAISE(D1); else LOWER(D1);
if (data & 0x04) RAISE(D2); else LOWER(D2);
if (data & 0x08) RAISE(D3); else LOWER(D3);
if (data & 0x10) RAISE(D4); else LOWER(D4);
if (data & 0x20) RAISE(D5); else LOWER(D5);
if (data & 0x40) RAISE(D6); else LOWER(D6);
if (data & 0x80) RAISE(D7); else LOWER(D7);
if (this->jrb == 0)
while (CHECK(BUSY));
else {
bool ok;
DIRECTION(D7,0);
do {
LOWER(RD);
_delay_us(.08);
ok = CHECK(D7);
RAISE(RD);
} while (ok);
DIRECTION(D7,1);
LOWER(WR);
_delay_us(0.11);
RAISE(WR);
_delay_us(20);
void hardReset() {
init();
LOWER(RESET);
_delay_ms(1);
RAISE(RESET);
_delay_ms(100);
Of course, the WinAVR code from Boricha have more features like a load of custom font.
Thanks a lot.
