help with nrf24
Hi guys,
I would like to use nrf24 to send a temperature (float), if I use this code every thiing is ok:
 uint8_t data[] = "Hello World!";
  nrf24.send(data, sizeof(data));
but if I try to use a variable like this:
String str="hello";
uint8_t data[] = str;
I get this error:
initializer fails to determine size of 'data'
Can someone help me?
its the difference between a char array string and a String object, to convert the String object use tochararray() linky
to send a float you could create a structure containing a float type and pass the address of the structure to the send function.. saves manipulating the value into a char arrayon the way in and back to a float for math on the way out on the receiving side
nrf24.send(&myFloatStruc,sizeof(myFloatStruc));
if you really want to use Strings you could encapsulate one in a structure also
tho Strings and the support lib is FAT and wasteful, most would advice you drop it..
Can you make an example of the structure?
struct myFloatstruct {
float value;
// you could also load it with useful information for message control
linky
I tried with this:
struct DATA{
float temp;
DATA room;
tempC = analogRead(tempPin);
tempC = (5.0 * tempC * 100.0)/1024.0;
room.temp=tempC;
  nrf24.send(&room, sizeof(room));
I recived this error:
nrf24_client.ino: In function 'void loop()':
nrf24_client:71: error: no matching function for call to 'RH_NRF24::send(DATA*, unsigned int)'
C:\Program Files (x86)\Arduino\libraries\RadioHead/RH_NRF24.h:512: note: candidates are: virtual bool RH_NRF24::send(const uint8_t*, uint8_t)
Ive not read any documentation on the lib your using,
the rf24 lib i have looked at is documneted here.. http://tmrh20.github.io/RF24Network/
works slightly differently, you create a header structure which contains the address of the receiving node and the type of message (default 0) and a payload structure to contain the message
your error message indicates the send wants a pointer to an int and a size?
Simplest possible example of using RF24Network. Put this sketch on one node, and helloworld_rx.pde on the other. Tx will send Rx a nice message every 2 seconds which rx will print out for us.
 Copyright (C) 2012 James Coliz, Jr. <maniacbug@ymail.com>
 This program is free software; you can redistribute it and/or
 modify it under the terms of the GNU General Public License
 version 2 as published by the Free Software Foundation.
 Update 2014 - TMRh20
#include <RF24Network.h>
#include <RF24.h>
#include <SPI.h>
RF24 radio(9,10);                    // nRF24L01(+) radio attached using Getting Started board
RF24Network network(radio);          // Network uses that radio
const uint16_t this_node = 1;        // Address of our node
const uint16_t other_node = 0;       // Address of the other node
const unsigned long interval = 2000; //ms  // How often to send 'hello world to the other unit
unsigned long last_sent;             // When did we last send?
unsigned long packets_sent;          // How many have we sent already
struct payload_t {                  // Structure of our payload
  unsigned long ms;
  unsigned long counter;
void setup(void)
  Serial.begin(57600);
  Serial.println("RF24Network/examples/helloworld_tx/");
  SPI.begin();
  radio.begin();
  network.begin(/*channel*/ 90, /*node address*/ this_node);
  network.update();                          // Check the network regularly
  unsigned long now = millis();              // If it's time to send a message, send it!
  if ( now - last_sent >= interval  )
    last_sent = now;
    Serial.print("Sending...");
    payload_t payload = { millis(), packets_sent++ };
    RF24NetworkHeader header(/*to node*/ other_node);
    bool ok = network.write(header,&payload,sizeof(payload));
    if (ok)
      Serial.println("ok.");
      Serial.println("failed.");
