Hello I am working on a science fair project for my school utilizing the nRF24L01 module. I have tried many different things including using codes that worked for other people, changing the modules, and puting a transistor between ground and 3.3V. Im new with this module and have little experience coding. This is the last code I tried. I am using an arduino uno r3 and an arduino uno r4 wifi to run the code.
//transmitter
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
// Instantiate RF24 class with CE and CSN values
RF24 radio(7, 8);
// Address to devices comunicate each other (same in both)
const uint64_t pipe = 0xE8E8F0F0E1LL;
// A variable to hold some info
boolean info = false;
pinMode(10, OUTPUT);
// Setup serial output
// Start RF
radio.begin();
// Setup the channel to work within, number 100
radio.setChannel(100);
// Open wite pipe
radio.openWritingPipe(pipe);
// it changes every interval
info = !info;
if (info) {
Serial.print("Sending positive... ");
Serial.print("Sending negative... ");
// Send info over RF
bool success = radio.write(&info, sizeof(boolean));
if (success) {
Serial.println("sent!");
Serial.println("fail!");
// Wait 2 seconds and repeat
delay(2000);
//receiver
#include <SPI.h>
#include "RF24.h"
RF24 radio(7, 8);
// Start RF
radio.begin();
// Open recept pipe
radio.openReadingPipe(1, pipe);
// Start to listen
radio.startListening();
// Wait until some data
if (radio.available()) {
// Read payload, and check if it finished
radio.read(&info, sizeof(info));
// Manage info
if (info) {
Serial.println("We received positive!");
Serial.println("We received negative!");
// Wait a bit
delay(50);
This is not wifi. It is its own signal. It uses SPI connections to talk to the device.
If the Uno R4 can use the same sketch as the Uno R3, have you tried GettingStarted.ino from the RF24.h library? This one sketch is loaded onto your transmitter and receiver. The code lets you configure which device transmits and which device receives as you start the program.
* See documentation at https://nRF24.github.io/RF24
* See License information at root directory of this library
* Author: Brendan Doherty (2bndy5)
* A simple example of sending data from 1 nRF24L01 transceiver to another.
* This example was written to be used on 2 devices acting as "nodes".
* Use the Serial Monitor to change each node's behavior.
#include <SPI.h>
#include "printf.h"
#include "RF24.h"
#define CE_PIN 7
#define CSN_PIN 8
// instantiate an object for the nRF24L01 transceiver
RF24 radio(CE_PIN, CSN_PIN);
// Let these addresses be used for the pair
uint8_t address[][6] = { "1Node", "2Node" };
// It is very helpful to think of an address as a path instead of as
// an identifying device destination
// to use different addresses on a pair of radios, we need a variable to
// uniquely identify which address this radio will use to transmit
bool radioNumber = 1; // 0 uses address[0] to transmit, 1 uses address[1] to transmit
// Used to control whether this node is sending or receiving
bool role = false; // true = TX role, false = RX role
// For this example, we'll be using a payload containing
// a single float number that will be incremented
// on every successful transmission
float payload = 0.0;
while (!Serial) {
// some boards need to wait to ensure access to serial over USB
// initialize the transceiver on the SPI bus
if (!radio.begin()) {
Serial.println(F("radio hardware is not responding!!"));
while (1) {} // hold in infinite loop
// print example's introductory prompt
Serial.println(F("RF24/examples/GettingStarted"));
// To set the radioNumber via the Serial monitor on startup
Serial.println(F("Which radio is this? Enter '0' or '1'. Defaults to '0'"));
while (!Serial.available()) {
// wait for user input
char input = Serial.parseInt();
radioNumber = input == 1;
Serial.print(F("radioNumber = "));
Serial.println((int)radioNumber);
// role variable is hardcoded to RX behavior, inform the user of this
Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
// Set the PA Level low to try preventing power supply related problems
// because these examples are likely run with nodes in close proximity to
// each other.
radio.setPALevel(RF24_PA_LOW); // RF24_PA_MAX is default.
// save on transmission time by setting the radio to only transmit the
// number of bytes we need to transmit a float
radio.setPayloadSize(sizeof(payload)); // float datatype occupies 4 bytes
// set the TX address of the RX node into the TX pipe
radio.openWritingPipe(address[radioNumber]); // always uses pipe 0
// set the RX address of the TX node into a RX pipe
radio.openReadingPipe(1, address[!radioNumber]); // using pipe 1
// additional setup specific to the node's role
if (role) {
radio.stopListening(); // put radio in TX mode
radio.startListening(); // put radio in RX mode
// For debugging info
// printf_begin(); // needed only once for printing details
// radio.printDetails(); // (smaller) function that prints raw register values
// radio.printPrettyDetails(); // (larger) function that prints human readable data
} // setup
if (role) {
// This device is a TX node
unsigned long start_timer = micros(); // start the timer
bool report = radio.write(&payload, sizeof(float)); // transmit & save the report
unsigned long end_timer = micros(); // end the timer
if (report) {
Serial.print(F("Transmission successful! ")); // payload was delivered
Serial.print(F("Time to transmit = "));
Serial.print(end_timer - start_timer); // print the timer result
Serial.print(F(" us. Sent: "));
Serial.println(payload); // print payload sent
payload += 0.01; // increment float payload
Serial.println(F("Transmission failed or timed out")); // payload was not delivered
// to make this example readable in the serial monitor
delay(1000); // slow transmissions down by 1 second
// This device is a RX node
uint8_t pipe;
if (radio.available(&pipe)) { // is there a payload? get the pipe number that received it
uint8_t bytes = radio.getPayloadSize(); // get the size of the payload
radio.read(&payload, bytes); // fetch payload from FIFO
Serial.print(F("Received "));
Serial.print(bytes); // print the size of the payload
Serial.print(F(" bytes on pipe "));
Serial.print(pipe); // print the pipe number
Serial.print(F(": "));
Serial.println(payload); // print the payload's value
} // role
if (Serial.available()) {
// change the role via the serial monitor
char c = toupper(Serial.read());
if (c == 'T' && !role) {
// Become the TX node
role = true;
Serial.println(F("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK"));
} else if (c == 'R' && role) {
// Become the RX node
role = false;
Serial.println(F("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK"));
} // loop
The 'radio hardware is not responding' message means that your wiring is probably incorrect. It means the radio cannot talk to the microcontroller successfully.
