Hello all,
I am currently working on a project where I need to wirelessly transmit data from one Arduino to another. Currently, I am working with placeholder data; however, it is not working. I have 0 clue as to what my problem is, as I followed Robin2's tutorial and still have problems, while also being extremely new to wireless transmission.
Here are some specs:
Transmitter:
- Arduino Uno (powered by computer)
- NRF24L01+ with adapter (powered by 9V battery)
Receiver:
Here are my pinouts:
Transmitter:
CE = 7
CSN = 8
SCK = 13
MOSI = 11
MISO = 12
VCC = Breadboard positive
GND = Breadboard negative
9V power supply = Breadboard
Receiver:
CE = 7
CSN = 8
SCK = 13
MOSI = 11
MISO = 12
Here is my code (copied from Robin2):
Transmitter:
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN 7
#define CSN_PIN 8
const byte slaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[10] = "Message 0";
char txNum = '0';
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
Serial.println("SimpleTx Starting");
radio.begin();
radio.setDataRate( RF24_250KBPS );
radio.setPALevel(RF24_PA_MIN);
radio.setRetries(3,5); // delay, count
radio.openWritingPipe(slaveAddress);
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis) {
send();
prevMillis = millis();
void send() {
bool rslt;
rslt = radio.write(&dataToSend, sizeof(dataToSend));
// Always use sizeof() as it gives the size as the number of bytes.
// For example if dataToSend was an int sizeof() would correctly return 2
Serial.print("Data Sent ");
Serial.print(dataToSend);
if (rslt) {
Serial.println(" Acknowledge received");
updateMessage();
else {
Serial.println(" Tx failed");
void updateMessage() {
// so you can see that new data is being sent
txNum += 1;
if (txNum > '9') {
txNum = '0';
dataToSend[8] = txNum;
Receiver:
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 7
#define CSN_PIN 8
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
Serial.println("SimpleRx Starting");
radio.begin();
radio.openReadingPipe(0, thisSlaveAddress);
radio.startListening();
getData();
showData();
void getData() {
if ( radio.available() ) {
radio.read( &dataReceived, sizeof(dataReceived) );
newData = true;
Serial.println("WORKING");
void showData() {
if (newData == true) {
Serial.print("Data received ");
Serial.println(dataReceived);
newData = false;
My transmitter is printing "Data sent Message 0 Tx failed". If any more information is needed, just ask, and I will provide it. Thanks!
ADurian
