Help with obstacle avoiding robot!!!?
my robot, is a simple obstacle avoiding robot using the ping))) ultrasonic sensor. i have two continuously rotating servos that drive the robot. when i turn it on, and im holding the robot off the ground in air, it works perfectly fine. when i set it down on any surface it stops working.
#include <Servo.h>
Servo motorLeft;
Servo motorRight;
int ledPin = 13;
const int pingPin = 7;
  motorLeft.attach(9);
  motorRight.attach(10);
  long duration, inches, cm;
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  inches = microsecondsToInches(duration);
  cm = microsecondsToCentimeters(duration);
  Serial.print(inches);
  Serial.print("in, ");
  Serial.print(cm);
  Serial.print("cm");
  if(inches <= 10){
    digitalWrite(ledPin, HIGH);
    motorLeft.write(0);
    motorRight.write(0);
  else{
 digitalWrite(ledPin, LOW);
 motorLeft.write(180);
  delay(300);
long microsecondsToInches(long microseconds)
  return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
  return microseconds / 29 / 2;
when in air it woks fine, and when i stick my hand 10 inches or closer it tries to turn, and when i move it away, it tries to go forward like its suppose to. but, when i set it on the ground, the ping))) flashes once, and gets stuck in its rotate loop.
oh, and ps. i don't think its the code at all.
How are you powering the robot? It sounds like the motors are needing more current that is available.
what is the torque rating of the servos and how heavy is your robot? I second pauls' opinion. Is your arduino getting reset?
hmm, that seems logical. i took of the wheels and the robot worked fine when i set it down, so maybe there is to much weight. i cant tell you the specific specs right off hand but im using futaba s3003 servos. modded to continuous rotate. idk how to supply extra power to the servos but not the entire arduino.....isn't that an h-bridge or something?
hey guys, i figured it out.....what i needed to do, was a different power supply to the servos then one to the arduino. and it works now. thank you mega big time for helping me figure out.
