help with Oled + encoder
Hi guys so im using 1.3"oled IIC SH1106 with a kY-040 encoder, i want to have a menu with multiple values and a start button, like for example i can set value A to x amount and value B to X amount etc....and at the end Start to start the program, i don't know how need help pls
User interfaces like this usually have complex and messy code. There isn't a simple library you can use to make a menu.
Can you get the screen working? Can you print "hello" or anything on the screen?
Can you get the encoder working?
Now combine the two: print a number on the screen that changes when the encoder moves.
MorganS: There isn't a simple library you can use to make a menu.
You can find one of the non existing libraries here: https://github.com/neu-rah/ArduinoMenu. ;)
