Hi everyone,
I'm working on a project that involves connecting an OV7670 camera module (without FIFO) to an ESP32 board. However, I'm running into an issue with the SCCB (I2C) communication. Here's the issue I'm facing:
Symptoms:
During initialization, I get the following output on the Serial Monitor:
14:57:41.793 -> --- Starting Camera Diagnostics ---
14:57:41.793 -> Step 1: Verifying Pin Configuration...
14:57:41.793 -> Pin configuration looks good!
14:57:41.793 -> Step 2: Checking SCCB Communication...
14:57:41.793 -> Testing SCCB...
14:57:41.793 -> SCCB test failed with error code: 2
14:57:41.793 -> Error: SCCB (I2C) communication failed. Check SIOD/SIOC connections and pull-up resistors.
Here is my code, that i found and edited a bit with the help of AI:
#include "esp_camera.h"
#include "Wire.h"
#define PWDN_GPIO_NUM 17
#define RESET_GPIO_NUM 16
#define XCLK_GPIO_NUM 19
#define SIOD_GPIO_NUM 21
#define SIOC_GPIO_NUM 22
#define Y9_GPIO_NUM 32
#define Y8_GPIO_NUM 33
#define Y7_GPIO_NUM 35
#define Y6_GPIO_NUM 34
#define Y5_GPIO_NUM 14
#define Y4_GPIO_NUM 26
#define Y3_GPIO_NUM 2
#define Y2_GPIO_NUM 4
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 18
pinMode(SIOD_GPIO_NUM, INPUT_PULLUP);
pinMode(SIOC_GPIO_NUM, INPUT_PULLUP);
Serial.println("\n--- Starting Camera Diagnostics ---");
// Step 1: Verify Pin Configuration
Serial.println("Step 1: Verifying Pin Configuration...");
bool pinConfigOk = true;
if (XCLK_GPIO_NUM == -1 || PCLK_GPIO_NUM == -1) {
Serial.println("Error: Clock pins not set properly.");
pinConfigOk = false;
if (!pinConfigOk) {
Serial.println("Pin configuration failed. Check your wiring.");
while (true);
Serial.println("Pin configuration looks good!");
Serial.println("Step 2: Checking SCCB Communication...");
if (!testSCCB()) {
Serial.println("Error: SCCB (I2C) communication failed. Check SIOD/SIOC connections and pull-up resistors.");
while (true);
Serial.println("SCCB communication successful!");
Serial.println("Step 3: Configuring Camera...");
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_RGB565; // Adjust if necessary
config.frame_size = FRAMESIZE_QVGA; // Use small size for testing
config.fb_count = 1;
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x\n", err);
checkErrorCode(err);
while (true);
Serial.println("Camera successfully initialized!");
Serial.println("Step 4: Testing Frame Capture...");
camera_fb_t *fb = esp_camera_fb_get();
if (!fb) {
Serial.println("Error: Failed to capture a frame.");
while (true);
Serial.printf("Frame captured successfully! Size: %d bytes\n", fb->len);
esp_camera_fb_return(fb);
Serial.println("--- Camera Diagnostics Complete ---");
// Frame capture test in the loop
if (fb) {
Serial.println("Frame capture succeeded in loop!");
Serial.println("Error: Frame capture failed in loop.");
delay(2000);
bool testSCCB() {
Serial.println("Testing SCCB...");
uint8_t addr = 0x42 >> 1;
Wire.begin(SIOD_GPIO_NUM, SIOC_GPIO_NUM);
Wire.beginTransmission(addr);
uint8_t error = Wire.endTransmission();
if (error == 0) {
Serial.println("SCCB test passed!");
return true;
Serial.printf("SCCB test failed with error code: %d\n", error);
return false;
void checkErrorCode(esp_err_t err) {
switch (err) {
case ESP_ERR_NO_MEM:
Serial.println("Error: Out of memory.");
case ESP_ERR_INVALID_ARG:
Serial.println("Error: Invalid argument.");
case ESP_ERR_INVALID_STATE:
Serial.println("Error: Invalid state.");
case ESP_ERR_NOT_FOUND:
Serial.println("Error: Requested resource not found.");
case ESP_ERR_NOT_SUPPORTED:
Serial.println("Error: Operation not supported.");
default:
Serial.printf("Unknown error: 0x%x\n", err);
I would really appreciate any insights or suggestions on how to troubleshoot or resolve this issue. Thanks in advance for your help!
