I’m replicating a random positioning machine prototype from GitHub, but I am a complete beginner:
I’ve built the setup as described, but I’m facing an issue where my FS90 continuous rotation servos overheat and stallafter running (empty) for less than a day. When this happens, I can manually nudge them, and they will restart for a few minutes before stopping again. When the servos are off the machine they seem to work normally.
Setup Details
Servos: FS90 (continuous rotation)
Power Supply: 5V, 4A (servos connected in parallel)
Code: (see below) – based on the original repository
I suspect the issue could be due to excessive load, but in the original project videos, their machine runs for a week without any problem. Could there be another reason why my servos are overheating?
Any help, tips or theories would be greatly appreciated!!
Here’s the code I’m using:
Driver code the Core Electronics Random Positioning Machine
Drive the two gimbal motors with random speed setpoints that update periodically
https://github.com/CoreElectronics/CE-Random-Positioning-Machine
Runs on a Raspberry Pi Pico
Requires the micropython-servo library - https://pypi.org/project/micropython-servo/
import time
from servo import Servo
import math
from random import randrange, random
# Create our Servo object, assigning the
# GPIO pin connected the PWM wire of the servo
outer_servo = Servo(pin_id=16)
inner_servo = Servo(pin_id=15)
delay_ms = 100
def modified_sine_wave(amplitude, deadband, t):
'''removes the dead band from the centre of the sinewave. useful for driving DC motors that stall at low speeds'''
value = amplitude * math.sin(2 * math.pi * t)
if abs(value) < deadband:
value = math.copysign(deadband, value) if value != 0 else deadband
return value
frequency = 0.05 # Hz
amplitude = 25 # servos accept "speeds" between 0 and 180. most of the speed change is at low amplitudes
dead_band = 12 # dead band around where the servo changes direction. Must be smaller than amplitude
duration = 10000 # time between speed changes
last_update_time = -duration
speed_inner = setpoint_inner = 0.5
speed_outer = setpoint_outer = 0.5
try:
while True:
# Periodically update the speed setpoint
if time.ticks_ms() - duration > last_update_time:
last_update_time = time.ticks_ms()
setpoint_inner = random()
setpoint_outer = random()
# Update the current speed (-1 -> 1), moving towards the setpoint smoothly
speed_inner = speed_inner + 0.01 * (setpoint_inner - speed_inner)
speed_outer = speed_outer + 0.01 * (setpoint_outer - speed_outer)
# Convert speed (-1 -> 1) to a servo drive signal (angle 0 -> 180), and scale down to the desired amplitude.
drive_inner = 90 + modified_sine_wave(amplitude, dead_band, speed_inner)
drive_outer = 90 + modified_sine_wave(amplitude, dead_band, speed_outer)
# Drive the continuous servos
inner_servo.write(drive_inner)
outer_servo.write(drive_outer)
time.sleep_ms(delay_ms)
except Exception as e:
print(e)
finally:
outer_servo.off()
inner_servo.off()
