help with passing parameters to a function
Hi all, I’m trying to create a function that accepts 3 parameters, the last parameter could be a string or integer, whats the best way to cater for both?
Also not sure if the below code is exactly correct, does using char* differ to char?
void PrintXMLTag(EthernetClient cl, char* tag, char* val)
  char tmp;
  sprintf(tmp,"<%s>%s</%s>\n",*tag,val,*tag);
  cl.print(tmp);
Thank you
Hi all, I'm trying to create a function that accepts 3 parameters, the last parameter could be a string or integer, whats the best way to cater for both?
Do like everyone else, and write two different functions.
Of course, it's pretty simple to convert an int to a string, so you really only need to write one function.
  char tmp;
That won’t compile, nor will it work. You need some sort of buffer, eg.
  char tmp [20];
Where the “20” is large enough to hold your expected values.
By the way, tag is a string, so the %s would be appropriate. *tag is a character, so the %s is not.
Judging by what you are doing you want tag, then, like this:
  sprintf(tmp, "<%s>%s</%s>\n", tag, val, tag);
The buffer may need to be bigger if these are XML tags.
Thanks, Ive changed the code a little, but doesn’t seem to be working.
PrintXMLTag_NUM(cl,"test",analogRead(TempSensorPIN));
void PrintXMLTag_NUM(EthernetClient cl, String tag, int val)
  char tmp [30];
  sprintf(tmp,"<%s>%s</%s>\n",tag,val,tag);
  Serial.println(tmp);
Why did you suddenly switch to using String? What is the reason for that?
Thanks, Ive changed the code a little, but doesn't seem to be working.
Well, of course not. You'll need to look up what the C format specifier is for the C++ String class.
Here's a hint. There isn't one.
