Help with passing variable to a function and updating variable value
Hi guys,
so the story goes that I notice that I been using millis() function extensively in my coding for a while now. As recommended by blink without delay, I use this line a lot in my code
if ( timeNow - timePrev >= interval )
Usually I would declare those variable as a local variable in void loop as so
  const unsigned long interval = 500;
  static unsigned long timePrev = 0 ;
  unsigned long timeNow = millis();
    timePrev = timeNow;
so i was thinking to refactor this line into a function
    timePrev = timeNow;
into something like this
boolean timeElapse( unsigned long timeNow, unsigned long timePrevious, unsigned long timeDelay)
  if ( timeNow - timePrevious >= timeDelay )
    timePrev = timeNow;
    return 1;
  return 0;
so now when i tested the code, timePrev will not change unless I put timePrev as a global variable, and I do think its not as robust as i would like to use it as one possible reuse of the function.
to demonstrate what i mean lets say i have 2 timer
  const unsigned long timeInterval_A = 300;
  const unsigned long timeInterval_B = 500;
  static unsigned long timePrev_A = 0 ;
  static unsigned long timePrev_B = 0 ;
  timeElapse( timeNow, timePrev_A, timeInterval_A);
  timeElapse( timeNow, timePrev_B, timeInterval_B);
is I could say both timePrev_A, and timePrev_B is not updated to the value of timeNow when this function is called.
So my question is that how do I able to call this function to return a boolean and also update the TimePrevious ( in my example ) ?
any help and suggestion are most welcome.
many thank you in advance
See if you can follow these examples:
unsigned long counter = 0;
unsigned long Millis13 = millis();
  pinMode(13, OUTPUT);
  pinMode(2, INPUT_PULLUP);
} //  >>>>>>>>>>>>>> E N D  O F  s e t u p ( ) <<<<<<<<<<<<<<<<<
  //leave this line of code at the top of loop()
  if(CheckTime(Millis13,1000UL,true))
  digitalWrite(13, !digitalRead(13));
  if(digitalRead(2) == 0)
    Serial.println(++counter);
} //  >>>>>>>>>>>>>> E N D  O F  l o o p ( ) <<<<<<<<<<<<<<<<<
//                      F U N C T I O N S
//Delay time expired function
//lastMillis = time we started, wait = delay in mS, restart = do we start again
boolean CheckTime(unsigned long &lastMillis, unsigned long wait,boolean restart)
  //is the time up for this task?
  if (currentMillis - lastMillis >= wait)
    //should this start again?
    if(restart)
      //get ready for the next iteration
      lastMillis = millis();  //get ready for the next iteration
    return true;
  return false;
} // END of CheckTime()
//                      E N D  O F  C O D E
//Blink without Delay skeleton example using a structure.
//LarryD
//LED wiring options
//#define PlusEqualsON //uncomment to invert
#ifdef PlusEqualsON
//wired so +5V turns LED ON
#define ledON  HIGH
#define ledOFF LOW
#else
//wired so +5V turns LED OFF
#define ledON  LOW
#define ledOFF HIGH
#endif
struct timer
  //lastMillis = the time this "timer" was (re)started
  //waitMillis = delay time (mS) we are looking for
  //restart    = do we start "this timer" again and again
  //enableFlag = is "this timer" enabled/allowed to be accessed
  //For each timer object you need:
  //Example:
  //   timer myTimer = //give the timer a name "myTimer"
  //     0, 200UL, true, true  //lastMillis, waitMillis, restart, enableFlag
  // You have access to:
  // myTimer.lastMillis, myTimer.waitMillis, myTimer.restart, myTimer.enableFlag, myTimer.CheckTime()
  unsigned long lastMillis;
  unsigned long waitMillis;
  bool          restart;
  bool          enableFlag;
  bool CheckTime() //Delay time expired function "CheckTime()"
    if (enableFlag && millis() - lastMillis >= waitMillis)
    //Note: if delays of < 2 millis are needed use micros() and adjust waitMillis as needed
      if(restart)
      //time was reached
      return true;
    //time was not reached
    return false;
  } //END of CheckTime()
}; //END of structure timer
//Let's create 6 timer objects and initialize them in this sketch
timer pin13 = //create timer pin13
timer pin12 = //create timer pin12
  0, 3000UL, true, true //lastMillis, waitMillis, restart, enableFlag
timer pin11 = //create timer pin11
  0, 10000UL, true, true //lastMillis, waitMillis, restart, enableFlag
timer pin10 = //create timer pin10
  0, 6000UL, true, true //lastMillis, waitMillis, restart, enableFlag
timer Toggle10 = //create timer Toggle10
  0, 50UL, true, true //lastMillis, waitMillis, restart, enableFlag
timer checkSwitches = //create timer checkSwitches
byte lastMySwitchState = 1; //for mySwitch on Pin 2
byte counter           = 0;
const byte Pin13 = 13;
const byte Pin12 = 12;
const byte Pin11 = 11;
const byte Pin10 = 10;
const byte Pin9  =  9;
const byte mySwitch = 2;
  pinMode(Pin13,OUTPUT);
  pinMode(Pin12,OUTPUT);
  pinMode(Pin11,OUTPUT);
  pinMode(Pin10,OUTPUT);
  pinMode(Pin9, OUTPUT);
  digitalWrite(Pin13,LOW);
  digitalWrite(Pin12,LOW);
  digitalWrite(Pin11,LOW);
  digitalWrite(Pin10,LOW);
  digitalWrite(Pin9, LOW);
  pinMode(mySwitch,INPUT_PULLUP);
  //Below are examples demonstrating different timing situations
  //example 1    Toggle Pin13 every 200ms
  if (pin13.CheckTime())
    //Toggle Pin13
    digitalWrite(Pin13,!digitalRead(Pin13));
    //if you only want this section of code to happen once
    //uncomment the next line
    //pin13.enableFlag = false;
  //example 2    After 3 seconds, Pin12 goes and stays HIGH
  if (pin12.CheckTime())
    //Pin12 HIGH now
    digitalWrite(Pin12,HIGH);
    //disable timing section of code
    pin12.enableFlag = false;
  //example 3    Pin11 is HIGH for 10 seconds, then goes and stays LOW
  //if (pin11.enableFlag && !pin11.CheckTime())
  if (!pin11.CheckTime())
    digitalWrite(Pin11,HIGH);
  //10 seconds is now up now, leave the Pin11 LOW
    pin11.enableFlag = false;
  //example 4    For 6 seconds, toggle Pin10
  //if (pin10.enableFlag && !pin10.CheckTime())
  if (!pin10.CheckTime())
    //example 5  Toggling Pin10 every 50mS
    if(Toggle10.CheckTime())
      //toggle Pin10
      digitalWrite(Pin10,!digitalRead(Pin10));
  //6 seconds is now up, stop toggling, toggle at 100ms
    pin10.enableFlag = false;
  //example 6    Is it time to check the switches?
  if (checkSwitches.CheckTime())
    //time to read the switches
    Switches();
  //Put other non-blocking stuff here
//switches are checked every checkSwitches.waitMillis milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void Switches()
  boolean thisState; //re-usable for all the switches
  //****************************************** mySwitch Pin 2 code
  //check if this switch has changed state
  thisState = digitalRead(mySwitch);
  if (thisState != lastMySwitchState)
    //update the switch state
    lastMySwitchState = thisState;
    //This switch position has changed, let's do some stuff
    //"HIGH condition code"
    //switch goes from LOW to HIGH
    if(thisState == HIGH)
      //example: LED on Pin9 is Push ON, Push OFF
      digitalWrite(Pin9,!digitalRead(Pin9));
    //"LOW condition code"
    //switch goes from HIGH to LOW
      //example: display the current switch push count
  } //END of mySwitch Pin 2 code
  //similar code for other switches goes here
} //END of Switches()
[/code]
In old-style C you would use a pointer to pass-by-reference instead of pass-by-value:
  if (timeElapse(timeNow, &timePrev, interval){
   // Do Stuff
boolean timeElapse( unsigned long timeNow, unsigned long *timePrevious, unsigned long timeDelay) {
  if ( timeNow - *timePrevious >= timeDelay ) {
    *timePrevious = timeNow;
    return 1;
  return 0;
In modern C and C++ you can use a 'reference':
  if (timeElapse(timeNow, timePrev, interval) {
   // Do Stuff
boolean timeElapse( unsigned long timeNow, unsigned long &timePrevious, unsigned long timeDelay) {
  if ( timeNow - timePrevious >= timeDelay ) {
    return 1;
  return 0;
@LarryD :
Hey thanks for both example, I will study them both and if I have any problem understanding them, I will get back to you
I love that the first example you gave, It shows the simplicity of the code while at the same time allow for a much complex behaviour. For the second example I still in the process of understanding it.
As a thank you token, you deserves a Karma
@johnwasser:
Wow, just by putting a "*" or "&" the function work as I wanted. I know pointer, reference are the strength of C++, after all this years I still find it hard to wrap my head around pointer and also polymorphism too.
Johnwasser you too receive Karma as a thank you token.
Maybe I should change the Topic as SOLVE?
