Help with password
I am newbie with arduino :smiley: :smiley: .. i am making a security system with 2 ping sensors and LCD + Keypad
this is the code for ping sensor
**const int pingPin = 7;
int Buzzer = 8;
pinMode(Buzzer, OUTPUT);
 int duration, distance;
 pinMode(pingPin, OUTPUT);
 digitalWrite(pingPin, LOW);
 delayMicroseconds(2);
 digitalWrite(pingPin, HIGH);
 delayMicroseconds(5);
 pinMode(pingPin, INPUT);
 duration = pulseIn(pingPin, HIGH);
  distance = (duration/2) / 29.1;
  //distance value changes we will measure it first (elmakeet):
    if (distance >= 80 || distance <= 0){
   Serial.println("no object detected");
   digitalWrite(Buzzer, LOW);
 else {
   Serial.println("object detected");
   digitalWrite(Buzzer, HIGH);
** __**ok . if there are any mistakes please tell me .... and for lcd and keypad i am using this code**__ **
**#include <Password.h>
#include <LiquidCrystal.h>
#include <Keypad.h>
LiquidCrystal lcd(2,3,4,9,10,11,12);
Password password = Password( "4321" );
const byte ROWS = 4; // Four rows
const byte COLS = 3; // Three columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','2','3',},
{'4','5','6',},
{'7','8','9',},
{'*','0',' ',}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = {25, 24, 23, 22}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {28, 27, 26}; //connect to the column pinouts of the keypad
const int buttonPin = 7;
int buttonState = 0;
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
#define ledPin 13
void setup(){
pinMode(buttonPin, INPUT);
lcd.begin(16, 2);
pinMode(ledPin,OUTPUT);
keypad.addEventListener(keypadEvent); //add an event listener for this keypad
keypad.setDebounceTime(250);
void loop(){
keypad.getKey();
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
lcd.clear();
//take care of some special events
void keypadEvent(KeypadEvent eKey){
switch (keypad.getState()){
case PRESSED:
lcd.print(eKey);
switch (eKey){
case ' ': guessPassword(); break;
default:
password.append(eKey);
void guessPassword(){
if (password.evaluate()){
digitalWrite(ledPin,HIGH); //activates garaged door relay
lcd.print("VALID PASSWORD "); //
password.reset(); //resets password after correct entry
delay(600);
lcd.print("Welcome");
delay(2000);
lcd.clear();
else{
digitalWrite(ledPin,LOW);
lcd.print("INVALID PASSWORD ");
password.reset(); //resets password after INCORRECT entry
delay(600);
lcd.clear();
__**i got it from here http://www.instructables.com/id/Password-access-with-arduino/?ALLSTEPS**__
the whole system is to control the +VCC on ping sensor " ON-OFF Control " i ll attach the VCC pin of the sensor instead off the ledPin as my sensor needs 5v ..... is it possible to make another password to turn it off i mean when i enter 4321 it turns on when i press 5678 turn off ???? :~ :~....and what is the function of "buttonPin = 7" ?? i couldnt get it :grin: :grin:
and if there are any tutorials about this system send it to me [/size][/b]
Well your password sketch does compile, so that's good, but now the issues is, you didn't make it, so you don't really know how it works or how to add in the things you need.
This can be done but the digital pins can only supply so much current, so you might need to get some NPN transistors or even some opto-couplers in order to control the power to the sensors, if they are not going directly to the 5V line.
Yes it is possible to have multiple passwords. This link HERE is to another post with the same question. Look at reply #21 for a working code. NOTE: that sketch uses 3 passwords.
As for your ping sensors, you may want to download the NewPing library, as it is faster and more precise.
