This project entails using a GSM module to send messages to patients when their heart rate and temperature are above a given threshold. An error keeps appearing on the line "String message = "NHS ALERT!" + patientname + " (" + nhsnum + ") ";" saying "expected initializer before 'String'". The full code is below:
#include <Adafruit_SSD1306.h>
#include <splash.h>
#include <RTClib.h>
#include <SoftwareSerial.h>
#include <SD.h>
#include <SPI.h>
#include <String.h>
// Include the libraries we need
#include <OneWire.h>
#include <DallasTemperature.h>
#define USE_ARDUINO_INTERRUPTS true // Set-up low-level interrupts for most acurate BPM math.
#include <PulseSensorPlayground.h> // Includes the PulseSensorPlayground Library.
// Variables
const int PulseWire = 0; // PulseSensor PURPLE WIRE connected to ANALOG PIN 0
const int LED = 13; // The on-board Arduino LED, close to PIN 13.
int Threshold = 550; // Determine which Signal to "count as a beat" and which to ignore.
// Use the "Gettting Started Project" to fine-tune Threshold Value beyond default setting.
// Otherwise leave the default "550" value.
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 8
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// declare an SSD1306 display object connected to I2C
RTC_DS3231 rtc;
SoftwareSerial mySerial(10, 11); // RX, TX
const int chipSelect = 4;
File alertFile; // Reading from SD card
File dateFile;
File timeFile;
File patientFile;
File nhsnumFile;
File heartRateFile;
File temperatureFile;
Adafruit_SSD1306 oled(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
PulseSensorPlayground pulseSensor; // Creates an instance of the PulseSensorPlayground object called "pulseSensor"
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Defining thresholds
String patientname = "50 Cent";
String nhsnum = "50505050";
float tempCthreshold = 20.0;
int bpmthreshold = 50;
mySerial.begin(9600); // Setting the baud rate of GSM Module
Serial.begin(9600); // For Serial Monitor
while (!Serial); // wait for serial port to connect. Needed for native USB
Wire.begin();
rtc.begin();
// The following lines can be uncommented to set the date and time
rtc.adjust(DateTime(2023, 3, 17, 16, 01, 0));
Serial.println("Dallas Temperature IC Control Library Demo");
// initialize OLED display with address 0x3C for 128x64
if (!oled.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
while (true);
delay(2000); // wait for initializing
oled.clearDisplay(); // clear display
oled.setTextSize(1); // text size
oled.setTextColor(WHITE); // text color
oled.setCursor(0, 0); // position to display
oled.println("NHS ALERT!"); // text to display
oled.display(); // show on OLED
// Start up the library
sensors.begin();
// Configure the PulseSensor object, by assigning our variables to it.
pulseSensor.analogInput(PulseWire);
pulseSensor.blinkOnPulse(LED); //auto-magically blink Arduino's LED with heartbeat.
pulseSensor.setThreshold(Threshold);
// Double-check the "pulseSensor" object was created and "began" seeing a signal.
if (pulseSensor.begin()) {
Serial.println("We created a pulseSensor Object !"); //This prints one time at Arduino power-up, or on Arduino reset.
// Start serial communication with the module
while (!mySerial) {
; // wait for serial port to connect. Needed for native USB port only
// Initialize SD card
Serial.print("Initializing SD card...");
if (!SD.begin(chipSelect)) {
Serial.println("SD card initialization failed!");
return;
Serial.println("SD card initialization done.");
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
// After we got the temperatures, we can print them here.
// We use the function ByIndex, and as an example get the temperature from the first sensor only.
float tempC = sensors.getTempCByIndex(0);
// Check if reading was successful
if(tempC != DEVICE_DISCONNECTED_C)
Serial.print("Temperature for the device 1 (index 0) is: ");
oled.setCursor(0,5);
Serial.println(tempC);
Serial.println("Error: Could not read temperature data");
if (pulseSensor.sawStartOfBeat()) { // Constantly test to see if "a beat happened".
int myBPM = pulseSensor.getBeatsPerMinute(); // Calls function on our pulseSensor object that returns BPM as an "int".
// // "myBPM" hold this BPM value now.
Serial.println("♥ A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
Serial.print("BPM: "); // Print phrase "BPM: "
Serial.println(myBPM); // Print the value inside of myBPM.
File alertFile = SD.open("alert.txt", FILE_WRITE);
if (alertFile) {
alertFile.print("NHS ALERT!");
alertFile.close();
File dateFile = SD.open("date.txt", FILE_WRITE);
if (dateFile) {
dateFile.print("17/03/2023");
dateFile.close();
File timeFile = SD.open("time.txt", FILE_WRITE);
if (timeFile) {
timeFile.print("16:00:00");
timeFile.close();
File patientFile = SD.open("patient.txt", FILE_WRITE);
if (patientFile) {
patientFile.print("50 Cent");
patientFile.close();
File nhsnumFile = SD.open("nhsnum.txt", FILE_WRITE);
if (nhsnumFile) {
nhsnumFile.print("5050505050");
nhsnumFile.close();
// Write the heart rate to the SD card
File heartRateFile = SD.open("heart_rate.txt", FILE_WRITE);
if (heartRateFile) {
heartRateFile.print(myBPM);
heartRateFile.close();
// Write the temperature to the SD card
File temperatureFile = SD.open("temperature.txt", FILE_WRITE);
if (temperatureFile) {
temperatureFile.print(tempC);
temperatureFile.close();
// Wait one second before repeating :)
delay (1000);
DateTime now = rtc.now();
oled.setCursor(0, 10);
oled.print(now.year(), DEC);
oled.print('/');
oled.print(now.month(), DEC);
oled.print('/');
oled.print(now.day(), DEC);
oled.print(' ');
oled.print(now.hour(), DEC);
oled.print(':');
oled.print(now.minute(), DEC);
oled.print(':');
oled.print(now.second(), DEC);
oled.setCursor(0,20);
oled.println("PATIENT NAME: 50 Cent");
oled.setCursor(0,30);
oled.println("NHS NUMBER: 50505050");
oled.setCursor(0, 40);
oled.print("TEMPERATURE: ");
oled.print(tempC);
oled.print(" C");
oled.setCursor(0, 50);
oled.print("HEART RATE: ");
oled.print(myBPM);
oled.print(" BPM");
oled.display();
// Wait for a short period before updating the display again
// Get data from SD card
alertFile = SD.open("alert.txt");
if (alertFile) {
while (alertFile.available()) {
// Read the data from the file and store it in a variable
String alert = alertFile.readStringUntil('\n');
alertFile.close();
else {
Serial.println("Error opening data file!");
dateFile = SD.open("date.txt");
if (dateFile) {
while (dateFile.available()) {
String date = dateFile.readStringUntil('\n');
dateFile.close();
else {
timeFile = SD.open("time.txt");
if (timeFile) {
while (timeFile.available()) {
String time = timeFile.readStringUntil('\n');
timeFile.close();
else {
patientFile = SD.open("patient.txt");
if (patientFile) {
while (patientFile.available()) {
String patient = alertFile.readStringUntil('\n');
nhsnumFile = SD.open("nhsnum.txt");
if (nhsnumFile) {
while (nhsnumFile.available()) {
String nhsnum = nhsnumFile.readStringUntil('\n');
nhsnumFile.close();
heartRateFile = SD.open("heart_rate.txt");
while (heartRateFile.available()) {
String heartRate = heartRateFile.readStringUntil('\n');
temperatureFile = SD.open("temperature.txt");
while (temperatureFile.available()) {
String temperature = temperatureFile.readStringUntil('\n');
// Send text message
void SendMessage()
// Format the message
// message += "Patient Name: 50 Cent\n";
// message += "NHS Number: 50505050\n";
message += "Heart Rate: " + String(myBPM) + " bpm\n";
message += "Temperature: " + String(tempC) + " C\n";
mySerial.println("AT+CMGF=1"); // Sets the GSM Module in Text Mode
mySerial.println("AT+CMGS=\"+447448377315\"\r"); // Replace with your mobile number
mySerial.print(message);
mySerial.println((char)26); // ASCII code of CTRL+Z
