Hi all
I been having problems with a photosensor and println ( serial.print)
I have a photosensor on analog 0 and I want to print line once when the photosensor is cover, the code below keeps printing lines for ever.
any help guys.
int photoPin = 0; // photo resitor
int val = 0;
int ledPin = 13; // led for debugging
void setup() // run once, when the sketch starts
pinMode(ledPin,OUTPUT); // set the pin
val = analogRead(photoPin); // set val equal to the resitor input
Serial.println("dddddval");
if(val == LOW) { // if nothing from photo resistor (low light), turn on led
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
Serial.println(val);
When you've done something you don't want to repeat, remember that fact in a variable. When you want it to be allowed again, clear that condition in the variable.
int val = 0;
[glow]boolean reported = false; // have we reported the LOW?[/glow]
if(val == LOW) {
[glow]if (!reported) {
Serial.print("val="); Serial.println(val); // report the LOW once
reported = true; // remember so we don't do it again
}[/glow]
[glow]reported = false; // allow new reports[/glow]
I found this openosurce script . How can I make the printlin once
int val = 0;
void setup(){
pinMode(13,OUTPUT); // LED on pin 13 to light up whenever the shadow conidtion is met.
int lightlevel=analogRead(0); //reads the light level from the photoresistor and assigns it to the variable called lightlevel
delay(1000); //wait one second.
if (analogRead(0)<lightlevel-20) //if the light level changes by more than 20, it activates the shadow condition.
digitalWrite(13,HIGH); //turn LED on
Serial.println("A");//send signal to Mac, which interprets the A as a applescript command.
else{
digitalWrite(13,LOW); //turns LED off.
I see no functional difference between your first script and this script. I also see no attempt at adding and using the features I highlighted in my previous answer, which still applies.
