Hey guys,
Quick background. I'm driving 2 DC motors with a dual H-Bridge board. All of it is being controlled by an Arduino Uno. The DC motors have optical encoders on the shaft with 20 divisions per rotation.
I'm trying to spin both motors up to the same RPM using a couple of PID loops. When it's running, the motors seem to pulse (I'm not talking about PWM here). This pulsing on off, which is about 1 - 2 Hz and can be felt with my finger, prevents them spinning up to their full speed or allowing them to be PID controlled as they either can't get near the desired speed (when I have a small delay of 2ms) or they can get near the speed but the sampling rate is too slow (delay of about 100ms) to make for a decet PID controller. This delay is where I measure the RPM of the motors using the interrupts.
It seems like whatever PWM is written at the end of the main loop doesn't stay written on the next loop, so they turn off in between. However, adding another analogWrite at the beginning of the main loop does nothing. Does anyone know why the motors are pulsing like this?
(P.s. I know the code would be way simpler if I understood pointers but I'm not quite there yet)
Any help is much appreciated!
#include <PID_AutoTune_v0.h>
#include <AutoPID.h>
#include <PID_v1.h>
//Motor LEFT
#define enA 9
#define in1 6
#define in2 7
#define encL 2
//Motor RIGHT
#define enB 10
#define in3 5
#define in4 4
#define encR 3
//interrupt variables
volatile long countR = 0;
volatile long countL = 0;
volatile long currentTime;
volatile long previousTimeL = 0;
volatile long previousTimeR = 0;
//RPM Variables
double LRPM;
double RRPM;
long timeL;
long timeR;
//Define Variables we'll be connecting to
double Setpoint;
double InputL, OutputL;
double InputR, OutputR;
//Specify the links and initial tuning parameters
PID LPID(&InputL, &OutputL, &Setpoint,1,0, 0, DIRECT);
PID RPID(&InputR, &OutputR, &Setpoint,1000,0,0, DIRECT);
//Interrupt pins
pinMode(encR, INPUT);
pinMode(encL, INPUT);
attachInterrupt (0, Lcounting, RISING); //First argument corresponds to pin 2 as it's the 0th interupt pin
attachInterrupt (1, Rcounting, RISING);
//Connecting the address of RPM to input
InputL = LRPM;
InputR = RRPM;
//Target Velocity
Setpoint = 4000;
//turn the PID on
LPID.SetMode(AUTOMATIC);
RPID.SetMode(AUTOMATIC);
//Motor driver pin initialiasation LEFT
pinMode(enA, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
//Motor driver pin initialiasation RIGHT
pinMode(enB, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
// Set initial rotation direction
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
void loop(){
//Sample Wheel Speed
delay(10);
//detach interrupts
detachInterrupt(0); //detaches the interrupt
detachInterrupt(1); //detaches the interrupt
//Read the RPM of the wheels
LRPM = getRPML();
RRPM = getRPMR();
Serial.print(LRPM);
Serial.print(",");
Serial.print(Setpoint);
Serial.print("\n");
//Perform PID calcs and write for LEFT
InputL = LRPM;
LPID.Compute();
OutputL = (OutputL/1023)*255;
analogWrite(enA, OutputL);
//Perform PID calcs and write for RIGHT
InputR = RRPM;
RPID.Compute();
OutputL = (OutputR/1023)*255;
analogWrite(enB, 0);
//Reattach the interrupt
long getRPML (){
long RPM;
timeL = millis() - previousTimeL; //finds the time
RPM = ((countL*60000)/(timeL*20)); //calculates rpm
previousTimeL = millis(); //saves the current time
countL = 0;
return(RPM);
long getRPMR (){
long RPM;
timeR = millis() - previousTimeR; //finds the time
RPM = ((countR*60000)/(timeR*20)); //calculates rpm
previousTimeR = millis(); //saves the current time
countR = 0;
return(RPM);
void Lcounting() { //Known as an ISR - Interrupt Service Routine
//1. Keep it short
//2. Dont use delays
//3. Don't serial print
//4. Make variables also used in the main code volatile
countL++;
void Rcounting() { //Known as an ISR - Interrupt Service Routine
countR++;
