Help with PID to code.
Looking for some assistance with getting my project up and running, a multi turn servo.
I have code to set initial position and run it manually, but need help in getting it to do exactly what i want.
Any assistance appreciated!
Code? What code?
Servo? What servo?
Well, you offer absolutely no information, but I used the Brett Beauregard PID library for a project recently and it worked quite well.
I have tried to use the Brett Beauregard PID library but i only get #include <PID_v1.h> into the sketch.
There is no other code showing.
Mega 2560, driving IBT2 H bridge. 400CPR encoder.
Here is my code so far.
#define ENCODER0PINA         20      // this pin needs to support interrupts
#define ENCODER0PINB         18      // interuppt
#define CPR                  400     // encoder cycles per revolution
#define CLOCKWISE            1       // direction constant
#define COUNTER_CLOCKWISE    2       // direction constant
#define HOME_SWITCH          36      // Home limit switch
#define MOTOR_REPOSITION_TIME 2000
#define E_SWITCH             40
volatile byte state = LOW;
volatile long encoder0Position = 0; // variables modified by interrupt handler must be declared as volatile
volatile long interruptsReceived = 0;
short currentDirection = CLOCKWISE;// track direction: 0 = counter-clockwise; 1 = clockwise
long previousPosition = 0;// track last position to see if worth printing new output
int SENSOR_PIN = 0; // center pin of the potentiometer
int RPWM_Output = 5; // Arduino PWM output pin 5; connect to IBT-2 pin 1 (RPWM)
int LPWM_Output = 6; // Arduino PWM output pin 6; connect to IBT-2 pin 2 (LPWM)
  Serial.println("<Arduino is ready>");
  pinMode(RPWM_Output, OUTPUT);
  pinMode(LPWM_Output, OUTPUT);
  pinMode(ENCODER0PINA, INPUT_PULLUP);
  pinMode(ENCODER0PINB, INPUT_PULLUP);
  pinMode(HOME_SWITCH, INPUT_PULLUP); // home switch
  pinMode(E_SWITCH, INPUT_PULLUP);     //E stop switch,  to be set.
  Serial.begin (9600);        // enable diagnostic output
  Serial.println("\n\n\n");
  Serial.println("Ready.");
  analogWrite(RPWM_Output, 0);           // ensure that the RPWM pin is set to 0
  analogWrite(LPWM_Output, 100);         // start the motor moving the device slowly towards the home position
  while (digitalRead(HOME_SWITCH))       // Continually read the home switch. While the switch is HIGH
    ;                                    // Do nothing.
  analogWrite(LPWM_Output, 0);           // The home switch has been hit! Stop the motor.
  Serial.println ("Switch closed.");     // Print a status message, indicating the home position has been reached.
  analogWrite(RPWM_Output, 100);         // start the motor moving the device slowly away from the home position
  delay(MOTOR_REPOSITION_TIME);          // do nothing while the motor repositions the device
  analogWrite(RPWM_Output, 0);           // stop the motor.
  attachInterrupt(digitalPinToInterrupt(ENCODER0PINA), onInterrupt, RISING);
  noInterrupts();                         // Temporarily turn off interrupts
  long cur_position = encoder0Position;   // take a copy of encoder0Position
  interrupts();                           // Turn on interrupts again.
  if (cur_position != previousPosition)   // Has the position changed?
    Serial.print(cur_position, DEC);
    Serial.print("\t");
    Serial.print(currentDirection == CLOCKWISE ? "clockwise" : "counter-clockwise");
    Serial.print("\t");
    Serial.println(interruptsReceived, DEC);
    previousPosition = cur_position;
  int sensorVal = digitalRead(36); //read the pushbutton value into a variable
  Serial.println(sensorVal);   //print out the value of the pushbutton
  int sensorValue = analogRead(SENSOR_PIN); // sensor value is in the range 0 to 1023
  // the lower half of it we use for reverse rotation; the upper half for forward rotation
  if (sensorValue < 512)
    int reversePWM = -(sensorValue - 511) / 2;  // reverse rotation
    analogWrite(RPWM_Output, reversePWM);
    int forwardPWM = (sensorValue - 512) / 2;  // forward rotation
    analogWrite(LPWM_Output, forwardPWM);
void onInterrupt()     // interrupt function needs to do as little as possible
  int a = digitalRead(ENCODER0PINA);
  int b = digitalRead(ENCODER0PINB);  // read both inputs
  if (a == b)       // b is leading a (counter-clockwise)
    encoder0Position--;
    currentDirection = COUNTER_CLOCKWISE;
    encoder0Position++;      // a is leading b (clockwise)
  encoder0Position = encoder0Position % CPR;   // track 0 to 20000
  interruptsReceived++;        // track the number of interrupts
