Help with pins for Pot Trimmer
Can anyone tell me what the pins are for this potrim:
http://www.radioshack.com/product/index.jsp?productId=2062308
[I was going to link it but apparently I'm not allow to yet.] :-?
I figured I would experiment and if I broke it I would buy another, and then I bought the thing and noticed how much they were. I looked around and found nothing on the actual specs of the thing, Mouser, Digikey, etc... The serial number on the trim is: 3006P-1-103
Any help/yelling at for posting a stupid question is openly welcome!
10k ohm total resistance trim-pot it takes 15 turns to go from one end of the other
the middle lead is the arm while the other two are the legs
| |o
| | | +5 pin gnd
for example, though gnd and +5 could be reversed.
Wow thought these were one way, thanks for the info!
if you want the voltage to increase with clockwise turning you need to hook it up a certain way and vice versa.
