Help with pos. External library function converting data into hex
Hello, I am programming my arduino micro (original) to send midi BLE data to my iPhone using keypad buttons. The code I have so far is working but when I add the sequencer library it won't work with my BLE code.
When I tell arduino to serial print the data its trying to send when the sequencer is running, the sequencer sends different values compared to the (working)buttons. I am guessing the external sequencer library functions is converting my data into hex but I don't know how to convert it back before putting into the BLE midi function?
Serial print says:
Sent Note On
0
38
144
^ This is the working button
PRESSED
Sent Note On
0
9
38
^ This is the sequenced data
Thanks for reading
Below is the code
#include <SPI.h>
#include <BLEPeripheral.h>
//#include <MIDI.h>
#include <Keypad.h>
#include <FifteenStep.h>
#define BLE_REQ   A5
#define BLE_RDY   2
#define BLE_RST   A4
// MIDI USB
//#if defined(USBCON)
//#include <midi_UsbTransport.h>
//static const unsigned sUsbTransportBufferSize = 16;
//typedef midi::UsbTransport<sUsbTransportBufferSize> UsbTransport;
//UsbTransport sUsbTransport;
//MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
// MIDI_CREATE_INSTANCE(UsbTransport, sUsbTransport, MIDI);
//#else // No USB available, fallback to Serial
//MIDI_CREATE_DEFAULT_INSTANCE();
//MIDI_CREATE_INSTANCE(SoftwareSerial, Serial, MIDI);
BLEPeripheral blePeripheral = BLEPeripheral(BLE_REQ, BLE_RDY, BLE_RST);
BLEService service = BLEService("03B80E5A-EDE8-4B33-A751-6CE34EC4C700");
BLECharacteristic characteristic("7772E5DB-3868-4112-A1A9-F2669D106BF3", BLERead | BLEWriteWithoutResponse | BLENotify, 20);
//BLECharCharacteristic characteristic = BLECharCharacteristic("7772E5DB-3868-4112-A1A9-F2669D106BF3",
//BLERead | BLEWriteWithoutResponse | BLENotify, 20);
BLEDescriptor descriptor = BLEDescriptor("2902", "0");
uint8_t msgBuf[5];
unsigned long msOffset = 0;
#define MAX_MS 0x01FFF //13 bits, 8192 dec
//KEYPAD
const byte ROWS = 4; //four rows
const byte COLS = 3; //four columns
char keys[ROWS][COLS] = {
  {46, 44, 54},
  {42, 48, 40},
  {57, 47, 38},
  {55, 45, 36}
//char keys[ROWS][COLS] = {
//  {'1', '2', '3'},
//  {'4', '5', '6'},
//  {'7', '8', '9'},
//  {'*', '0', '#'}
byte rowPins[ROWS] = {4, 9, 8, 6}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 3, 7}; //connect to the column pinouts of the keypad
int intensity;
// Order pinout     C2   R1,   C1    R4    C3,    R3,   R2
// Pin-in Arduino    8    7    6      5      4     3     2
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS);
////SEQUENCER
FifteenStep seq = FifteenStep();
int steps = 16;
int tempo;
int seqmode;
int velocity = 90;
/////      SEQUENCER
//void seqmidi(byte channel, byte command, byte arg1, byte arg2) {
//  init combined byte
//  byte combined = command;
//  // shift if necessary and add MIDI channel
//  if (combined < 128) {
//    combined <<= 4;
//    combined |= channel;
//void seqNoteOff(byte keyOn) {
//sendNoteOn(keyOn);
//serial.println("Sequenced: keyOn");
//void seqNoteOff(byte keyOff) {
//sendNoteOn(keyOff);
//serial.println("Sequenced: keyOff");
void step(int current, int last) {
  // blink on even steps
  if(current % 2 == 0)
    digitalWrite(13, HIGH);
    digitalWrite(13, LOW);
  void setupBLE() {
    blePeripheral.setLocalName("BLEMIDI2"); // optional
    blePeripheral.setAdvertisedServiceUuid(service.uuid()); // optional
    blePeripheral.setDeviceName("BLEMIDI2");
    // add attributes (services, characteristics, descriptors) to peripheral
    blePeripheral.addAttribute(service);
    blePeripheral.addAttribute(characteristic);
    blePeripheral.addAttribute(descriptor);
    // set initial value
    characteristic.setValue(0);
    // begin initialization
    blePeripheral.begin();
    Serial.println("BLE configuration read");
    Serial1.begin(115200);
        //// B L E .   P E R I P H E R A L
   setupBLE();
    //// M .  I . D . I
    //  MIDI.begin();
    //  MIDI.turnThruOff();
    //  MIDI.setHandleNoteOn(handleNoteOn);
    //  MIDI.setHandleNoteOff(handleNoteOff);
    //KEYPAD
    //customKeypad.addEventListener(keypadEvent);
    // SEQUENCER
    tempo = 100;
    seq.begin(tempo, steps);
    seq.setMidiHandler(sendNote);
    seq.setStepHandler(step);
    seq.start();
    intensity = 90;
void sendNote(byte channel, byte keypadnote, byte onoff)
    uint8_t statusByte = ((uint8_t)onoff | 0 & 0x0f);
    uint8_t msgBuf[5]; //Outgoing buffer
    //Calculate timestamp.
    uint16_t currentTimeStamp = millis() & 0x01FFF;
    msgBuf[0] = ((currentTimeStamp >> 7) & 0x3F) | 0x80; //6 bits plus MSB
    msgBuf[1] = (currentTimeStamp & 0x7F) | 0x80; //7 bits plus MSB
    msgBuf[2] = statusByte;
    //Note
    msgBuf[3] = keypadnote;
    //Velocity
    msgBuf[4] = intensity;
    characteristic.setValue(msgBuf, 5);
    Serial.println("Sent Note");
    Serial.println(channel);
       Serial.println(keypadnote);
          Serial.println(onoff);
//  void sendNoteOn(byte keypadnote)
//    uint8_t statusByte = ((uint8_t)144 | 0 & 0x0f);
//    uint8_t msgBuf[5]; //Outgoing buffer
//    //Calculate timestamp.
//    uint16_t currentTimeStamp = millis() & 0x01FFF;
//    msgBuf[0] = ((currentTimeStamp >> 7) & 0x3F) | 0x80; //6 bits plus MSB
//    msgBuf[1] = (currentTimeStamp & 0x7F) | 0x80; //7 bits plus MSB
//    msgBuf[2] = statusByte;
//    //Note
//    msgBuf[3] = keypadnote;
//    //Velocity
//    msgBuf[4] = intensity;
//    characteristic.setValue(msgBuf, 5);
//    Serial.print("Sent Note On");
//  void sendNoteOff(byte keypadnote)
//    uint8_t statusByte = ((uint8_t)128 | 0 & 0x0f);
//    //Note
//    //Velocity
//    msgBuf[4] = 0;
//    Serial.print("Sent Note Off");
    //// DIN TO BLE
    //Prep the timestamp
    BLECentral central = blePeripheral.central();
    if (central) {
      while (central.connected()) {
        // central still connected to peripheral
        // uint16_t write ( uint8_t singlebyte);     if (key)
        if (customKeypad.getKeys())
          for (int i = 0; i < LIST_MAX; i++) // Scan the whole key list.
            if (customKeypad.key[i].stateChanged )   // Only find keys that have changed state.
              switch (customKeypad.key[i].kstate) {
                case PRESSED:
                 // sendNoteOn(customKeypad.key[i].kchar);
                    sendNote(0, customKeypad.key[i].kchar, 144);
                    seq.setNote(0, customKeypad.key[i].kchar, 144);
                  Serial.println("PRESSED");
                case RELEASED:
//                  sendNoteOff(customKeypad.key[i].kchar);
                   sendNote(0, customKeypad.key[i].kchar, 128);
                   seq.setNote(0, customKeypad.key[i].kchar, 128);
                  Serial.println("RELEASED");
                case HOLD:
                case IDLE:
//        parseMIDIonDIN();
 seq.run();
    // central disconnected
    Serial.print(F("Disconnected from central: "));
    Serial.println(central.address());
