Help with powerbank for mobile phones ... who knows them well?
I would like to understand how the various PowerBank work for mobile phones ....
Let me explain better, I wanted to feed a classic flashing light with
The usual IC Timer 555 and an LED diode, all of 5 volt.
Except that I connected it to the 4 different powerbank that I have but nothing, off !!!
With the tester in fact I read from 2 to 3 volts out of the way ....
If, however, the various keyboards, a miracle, the 5 volt and the circuit comes out
Outside it works!
Only then after a while ... everything goes out and the 5 volts still disappear.
So there must be something to do on the connector for I believe
make Powerbank understand that there is an external load and to continue
To give the 5 volts out of the way, right?
But how should I do, maybe some resistance ... but where?
You can also search using Google etc. for the following phrase: "arduino power bank autoshutoff" to see some tricks for using these as a general power supply.
Many power banks have current sensing circuit, so if the draw is too low they switch off.
Try with 200ohm resistor between 5V/Gnd. If it's not enough, add another..
Obviously it's not efficient circuit for the battery life.
