Help with programing Neopixels to chase at different speeds
I have a project that I am working on which is basically a Theater Chase of Neopixels that transition from blue to red and back again along the same chase. It is one long string of 463 neopixels. Right now all the colors are chasing at the same "speed". Is there a way to make the red Neopixel move at a faster "speed" than the blue one? Any help would be appreciated, I am still new to programming. My code is uploaded below.
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 6
Adafruit_NeoPixel strip = Adafruit_NeoPixel(463, PIN, NEO_GRB + NEO_KHZ800);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
theaterChase(100);
//Theatre-style crawling lights.
void theaterChase(int wait) {
  for (int q=0; q < 3; q++)                             //offset
       for (int x=0; x < 90; x=x+3) {
         strip.setPixelColor(x+q, strip.Color(0,0,200));    //turn every third pixel on blue
       for (int y=93; y < 213; y=y+3) {
        strip.setPixelColor(y+q, strip.Color(200,0,0));    //turn every third pixel on red
       for (int z=228; z < 231; z=z+3) {
         strip.setPixelColor(z+q, strip.Color(200,0,100));    //turn every third pixel on purple
       for (int z=231; z < 281; z=z+3) {
         strip.setPixelColor(z+q, strip.Color(0,0,200));    //turn every third pixel on blue
        for (int a=282; a < 285; a=a+3) {
         strip.setPixelColor(a+q, strip.Color(200,0,200));    //turn every third pixel on purple
        for (int b=285; b < 355; b=b+3) {
         strip.setPixelColor(b+q, strip.Color(200,0,0));    //turn every third pixel on red
        for (int b=366; b < 369; b=b+3) {
        for (int c=375; c < 406; c=c+3) {
         strip.setPixelColor(c+q, strip.Color(0,0,200));    //turn every third pixel on blue
        for (int g=405; g < 410; g=g+3) {
         strip.setPixelColor(g+q, strip.Color(200,0,200));    //turn every third pixel on purple
        for (int s=411; s < 462; s=s+3) {
         strip.setPixelColor(s+q, strip.Color(200,0,0));    //turn every third pixel on red
     strip.show();
    delay(wait);
    for (int i=0; i < 463; i=i+3) {
      strip.setPixelColor(i+q, strip.Color(0,0,0));        //turn every third pixel off
 /code]
Polar_Motion_10_03_18.ino (2.4 KB)
OK, let's cut to the chase.
Please go and read the instructions, then go back and modify your original post using the "More --> Modify" option you will find to the bottom right of the post, to mark up the code (but it always needs to be the complete code) as such so we can examine it conveniently and accurately. Please do not post a ".ino" file as an attachment - that would mean that you are expecting people to actually load it to their IDE to look at it and that is extra unnecessary labour. In fact, attachments do not always show properly on different operating systems.
If you do not mark it up as code, whatever code you do post could well be garbled and is certainly anything but easy to read. Yours seems to have survived so far but I didn't look too closely.
Note: Also mark up any data - as a separate section - in the same way. This includes error output that you get from the IDE.
And - before you post any code, use "Auto Format" in the Tools menu of the IDE to properly present the code. You can then use the "copy for forum" function in order to paste it into a message with the "code" tags already provided.
Try and avoid unnecessary white space (blank lines). You should only use these to separate functional blocks of code.
Thanks for the info on how to post the code.
I was able to work out the code .
Here it is:
#define PIXELSPIN1   6
#define PIXELSPIN2   9
#define NUMPIXELS1   300
#define NUMPIXELS2   300
#define CALIBRATIONTIME 20000
Adafruit_NeoPixel pixels1 = Adafruit_NeoPixel(NUMPIXELS1, PIXELSPIN1, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel pixels2 = Adafruit_NeoPixel(NUMPIXELS2, PIXELSPIN2, NEO_GRB + NEO_KHZ800);
unsigned long pixelsInterval1=225;  // timing for Blue
unsigned long pixelsInterval2=150;  // timing for Red
unsigned long theaterChase1PreviousMillis=0;
unsigned long theaterChase2PreviousMillis=0;
int theaterChaseQ = 0;
uint16_t currentPixel = 0;// what pixel are we operating on
  currentPixel = 0;
  pixels1.begin(); // This initializes the NeoPixel library.
  pixels1.show(); // This sends the updated pixel color to the hardware.
  pixels2.begin(); // This initializes the NeoPixel library.
  pixels2.show(); // This sends the updated pixel color to the hardware.
void loop () {
        if ((unsigned long)(millis() - theaterChase1PreviousMillis) >= pixelsInterval1) {
          theaterChase1PreviousMillis = millis();
          theaterChase1(pixels1.Color(0, 0, 200)); // Blue
        if ((unsigned long)(millis() - theaterChase2PreviousMillis) >= pixelsInterval2) {
          theaterChase2PreviousMillis = millis();
          theaterChase2(pixels2.Color(200, 0, 0)); // Red
//Theatre-style crawling lights Blue
void theaterChase1(uint32_t c) {
  for (int i=0; i < pixels1.numPixels(); i=i+3) {
      pixels1.setPixelColor(NUMPIXELS1 -(i+theaterChaseQ), c);    //turn every third pixel on
    pixels1.show();
      pixels1.setPixelColor(NUMPIXELS1 - (i+theaterChaseQ), 0);        //turn every third pixel off
    theaterChaseQ++;
    if(theaterChaseQ >= 3) theaterChaseQ = 0;
//Theatre-style crawling lights Red
void theaterChase2(uint32_t c) {
  for (int i=0; i < pixels2.numPixels(); i=i+3) {
      pixels2.setPixelColor(NUMPIXELS2 -(i+theaterChaseQ), c);    //turn every third pixel on
    pixels2.show();
      pixels2.setPixelColor(NUMPIXELS2 -(i+theaterChaseQ), 0);        //turn every third pixel off
    theaterChaseQ++;
