Help with programming a tester!
When the Arduino Run switch closes:
  • turn off the LEDs
  • energize the relay module
  • start a TIMER
  • if the TIMER falls up out of the maximum range turn ON red LED
  • if reset switch closes, cancel timing operation
When the UUT closes it’s contact:
  • stop the TIMER
  • determine if the TIMER value is within the allowable time needed.
  • control LEDs as appropriate
  • de-energize the relay module
