its all in the title. I have IDE 1.0 and downloaded this: https://sourceforge.net/projects/ard-core13/ it installed at C:\arduino\arduino-1.0.1\hardware\arduino\cores/core13
and put this in my boards.txt
attiny13.name=Attiny 13A standalone
attiny13.upload.using=arduino:arduinoisp
attiny13.upload.maximum_size=1024
attiny13.upload.speed=19200
attiny13.bootloader.low_fuses=0x7B
attiny13.bootloader.high_fuses=0xFF
attiny13.bootloader.path=empty
attiny13.bootloader.file=empty
attiny13.bootloader.unlock_bits=0xFF
attiny13.bootloader.lock_bits=0xFF
attiny13.build.mcu=attiny13a
attiny13.build.f_cpu=128000
attiny13.build.core=core13
attiny13int.name=Attiny13 @ 128 KHz (internal watchdog oscillator)
attiny13int.upload.using=arduino:arduinoisp
attiny13int.upload.maximum_size=1024
attiny13int.upload.speed=250 # important for not losing connection to a slow processor
attiny13int.bootloader.low_fuses=0x7B
attiny13int.bootloader.high_fuses=0xFF
attiny13int.bootloader.unlock_bits=0x3F
attiny13int.bootloader.lock_bits=0x3F
attiny13int.build.mcu=attiny13
attiny13int.build.f_cpu=128000
attiny13int.build.core=core13
attiny13at4.name=ATtiny13 @ 4.8MHz (internal 4.8 MHz clock)
attiny13at4.upload.using=arduino:arduinoisp
attiny13at4.bootloader.low_fuses=0x69
attiny13at4.bootloader.high_fuses=0xff
attiny13at4.upload.maximum_size=1024
attiny13at4.build.mcu=attiny13
attiny13at4.build.f_cpu=600000
attiny13at4.build.core=core13
attiny13.name=ATtiny13 @ 9.6MHz (interne 9.6 MHz clock)
attiny13.bootloader.low_fuses=0x7a
attiny13.bootloader.high_fuses=0xff
attiny13.build.f_cpu=1200000
Also hooked up the wires correctly to the attiny13a as shown here http://www.youtube.com/watch?v=p-fieBPj9Ng&feature=related
in the IDE I switched the board to attiny13(tryed all of the different attiny options with same result) then selected tools/programmer and set it as arduino ISP I use this code for testing it
/* Blink Turns on an LED on for one second, then off for one second, repeatedly.
This example code is in the public domain. */
// Pin 13 has an LED connected on most Arduino boards. // give it a name: int led = 4;
// the setup routine runs once when you press reset: void setup() { // initialize the digital pin as an output. pinMode(led, OUTPUT); }
// the loop routine runs over and over again forever: void loop() { digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level) delay(1000); // wait for a second digitalWrite(led, LOW); // turn the LED off by making the voltage LOW delay(1000); // wait for a second }
and EVERYTIME I upload it I get this: avrdude: stk500_getsync(): not in sync: resp=0x00
can somebody please tell me what I am doing wrong? its been driving me crAzy for 3 days now. I really would like some tips or help as to what is wrong.
thnks:)
