Help with programming memory game
I am doing memory game with UNO where I have 4 leds and 4 pushbuttons connected to 8 different digital pins and goal is to make a memory game where every turn that you successfully do it would add one extra step in the sequence you need to do and it should continue until you make a mistake and then it should come back to level 1. Problem occurs when user makes a first mistake, the game doesent start from step 1 but sequence blinks again and it is just stuck like that. It is probably a simple fix but I just cant wrap my head around it at the moment.
This is code:
int switch1 = 7; //The four button input pins
int switch2 = 6;
int switch3 = 5;
int switch4 = 4;
int led1 = 13; //LED pins
int led2 = 12;
int led3 = 11;
int led4 = 10;
int turn = 0;
int input1 = LOW;
int input2 = LOW;
int input3 = LOW;
int input4 = LOW;
int randomArray[50];
int inputArray[50];
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(switch1, INPUT);
pinMode(switch2, INPUT);
pinMode(switch3, INPUT);
pinMode(switch4, INPUT);
randomSeed(analogRead(0)); //Added to generate “more randomness” with the randomArray for the output function
void output() { //function for generating the array
for (int y=turn; y <= turn; y++){
randomArray[y] = random(4, 8);
int size = sizeof(randomArray)/sizeof(int);
for(int k=0; k<size; k++)
  if(randomArray[k]== 4)
  {digitalWrite(led1, HIGH);
  digitalWrite(led1, LOW);
  delay(100);}
  else if(randomArray[k]== 5)
  {digitalWrite(led2, HIGH);
  digitalWrite(led2, LOW);
  delay(100);}
  else if(randomArray[k]== 6)
  {digitalWrite(led3, HIGH);
  digitalWrite(led3, LOW);
  delay(100);}
  else if(randomArray[k]== 7)
  {digitalWrite(led4, HIGH);
  digitalWrite(led4, LOW);
  delay(100);}
void input() { //Function for allowing user input and checking input against the generated array
for (int x=0; x <= turn;){ //Statement controlled by turn count
input1 = digitalRead(switch1);
input2 = digitalRead(switch2);
input3 = digitalRead(switch3);
input4 = digitalRead(switch4);
if (input1 == HIGH){ //Checking for button push
delay(200);
inputArray[x] = 4;
delay(50);
if (inputArray[x] != randomArray[x]) { //Checks value input by user and checks it against
fail(); //the value in the same spot on the generated array
} //The fail function is called if it does not match
x++;
if (input2 == HIGH){
delay(200);
inputArray[x] = 5;
delay(50);
fail();
x++;
if (input3 == HIGH){
delay(200);
inputArray[x] = 6;
delay(50);
fail();
x++;
if (input4 == HIGH){
delay(200);
inputArray[x] = 7;
delay(50);
Serial.print(" ");
Serial.print(4);
fail();
x++;
turn++;
void fail() { //Function used if the player fails to match the sequence
for (int y=0; y<=5; y++){
delay(200);
delay(200);
turn = -1; //Resets turn value so the game starts over
  output();
  input();
Hi
You need to understand the for loop syntax
This loop will run only once:
and this will be run infinitely
As I understand, the error in that last loop is origin of your problem
Hello
Take a view here to get some ideas.
https://create.arduino.cc/projecthub/Metonymy/arduino-simple-simon-says-351b9e
