Help with proximity sensor
HELLO, I AM REALIZING A PROJECT OF DEGREE FOR THE SCHOOL, BUT I AM NOT ABLE TO PERFORM IT BECAUSE I DO NOT KNOW VERY WELL THE PROGRAMMING IN ARDUINO.
CONSISTS OF A DEVICE WITH AN INFRARED PROXIMITY SENSOR e18-d50nk, WHOSE FUNCTION IS TO PERMIT THE STEP OF WATER, THIS DEVICE WILL APPLY TO THE WASHBASINS AS IN THE SHOPPING CENTERS, WHEN THE HAND IS UNDER THE KEY IT OPENS AND WHEN IT IS REMOVE IT IS CLOSED, BUT IN ADDITION TO THAT, IT IS NEEDED TO MEASURE THE PRESSURE AND FLOW OF WATER THAT GOES OU
  1. Please don't type in upper case.
  2. You are using a proximity sensor e18-d50nk to detect the presence of someone's hand in the vicinity of a wash basin, with the purpose of controlling the operation of a water tap.
  3. You additionally want to measure the pressure of the water and the flow rate.
Start here: e18-d50nk arduino - Google Search
Also posted (equally badly) in the Spanish section
