help i have wired up my ps2 reciver but now the serial monitor says cannot enter configuration mode this is the code /*******************************************************************************
- This file is part of PsxNewLib. *
- Copyright (C) 2019-2020 by SukkoPera software@sukkology.net *
- PsxNewLib is free software: you can redistribute it and/or *
- modify it under the terms of the GNU General Public License as published by *
- the Free Software Foundation, either version 3 of the License, or *
- (at your option) any later version. *
- PsxNewLib is distributed in the hope that it will be useful, *
- but WITHOUT ANY WARRANTY; without even the implied warranty of *
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
- GNU General Public License for more details. *
- You should have received a copy of the GNU General Public License *
- along with PsxNewLib. If not, see Licenses - GNU Project - Free Software Foundation. *
- This sketch will dump to serial whatever is done on a PSX controller. It is
- an excellent way to test that all buttons/sticks are read correctly.
- It's missing support for analog buttons, that will come in the future.
- This example drives the controller by bitbanging the protocol, there is
- another similar one using the hardware SPI support.
#include <DigitalIO.h>
#include <PsxControllerBitBang.h>
#include <avr/pgmspace.h>
typedef const __FlashStringHelper * FlashStr;
typedef const byte* PGM_BYTES_P;
#define PSTR_TO_F(s) reinterpret_cast<const __FlashStringHelper *> (s)
const byte PIN_PS2_ATT = 13;
const byte PIN_PS2_CMD = 12;
const byte PIN_PS2_DAT = 10;
const byte PIN_PS2_CLK = 11;
const byte PIN_BUTTONPRESS = A0;
const byte PIN_HAVECONTROLLER = A1;
const char buttonSelectName[] PROGMEM = "Select";
const char buttonL3Name[] PROGMEM = "L3";
const char buttonR3Name[] PROGMEM = "R3";
const char buttonStartName[] PROGMEM = "Start";
const char buttonUpName[] PROGMEM = "Up";
const char buttonRightName[] PROGMEM = "Right";
const char buttonDownName[] PROGMEM = "Down";
const char buttonLeftName[] PROGMEM = "Left";
const char buttonL2Name[] PROGMEM = "L2";
const char buttonR2Name[] PROGMEM = "R2";
const char buttonL1Name[] PROGMEM = "L1";
const char buttonR1Name[] PROGMEM = "R1";
const char buttonTriangleName[] PROGMEM = "Triangle";
const char buttonCircleName[] PROGMEM = "Circle";
const char buttonCrossName[] PROGMEM = "Cross";
const char buttonSquareName[] PROGMEM = "Square";
const char* const psxButtonNames[PSX_BUTTONS_NO] PROGMEM = {
buttonSelectName,
buttonL3Name,
buttonR3Name,
buttonStartName,
buttonUpName,
buttonRightName,
buttonDownName,
buttonLeftName,
buttonL2Name,
buttonR2Name,
buttonL1Name,
buttonR1Name,
buttonTriangleName,
buttonCircleName,
buttonCrossName,
buttonSquareName
byte psxButtonToIndex (PsxButtons psxButtons) {
byte i;
for (i = 0; i < PSX_BUTTONS_NO; ++i) {
if (psxButtons & 0x01) {
psxButtons >>= 1U;
return i;
FlashStr getButtonName (PsxButtons psxButton) {
FlashStr ret = F("");
byte b = psxButtonToIndex (psxButton);
if (b < PSX_BUTTONS_NO) {
PGM_BYTES_P bName = reinterpret_cast<PGM_BYTES_P> (pgm_read_ptr (&(psxButtonNames[b])));
ret = PSTR_TO_F (bName);
return ret;
void dumpButtons (PsxButtons psxButtons) {
static PsxButtons lastB = 0;
if (psxButtons != lastB) {
lastB = psxButtons; // Save it before we alter it
Serial.print (F("Pressed: "));
for (byte i = 0; i < PSX_BUTTONS_NO; ++i) {
byte b = psxButtonToIndex (psxButtons);
Serial.print (PSTR_TO_F (bName));
psxButtons &= ~(1 << b);
if (psxButtons != 0) {
Serial.print (F(", "));
Serial.println ();
void dumpAnalog (const char *str, const byte x, const byte y) {
Serial.print (str);
Serial.print (F(" analog: x = "));
Serial.print (x);
Serial.print (F(", y = "));
Serial.println (y);
const char ctrlTypeUnknown[] PROGMEM = "Unknown";
const char ctrlTypeDualShock[] PROGMEM = "Dual Shock";
const char ctrlTypeDsWireless[] PROGMEM = "Dual Shock Wireless";
const char ctrlTypeGuitHero[] PROGMEM = "Guitar Hero";
const char ctrlTypeOutOfBounds[] PROGMEM = "(Out of bounds)";
const char* const controllerTypeStrings[PSCTRL_MAX + 1] PROGMEM = {
ctrlTypeUnknown,
ctrlTypeDualShock,
ctrlTypeDsWireless,
ctrlTypeGuitHero,
ctrlTypeOutOfBounds
PsxControllerBitBang<PIN_PS2_ATT, PIN_PS2_CMD, PIN_PS2_DAT, PIN_PS2_CLK> psx;
boolean haveController = false;
void setup () {
fastPinMode (PIN_BUTTONPRESS, OUTPUT);
fastPinMode (PIN_HAVECONTROLLER, OUTPUT);
delay (300);
Serial.begin (115200);
Serial.println (F("Ready!"));
void loop () {
static byte slx, sly, srx, sry;
fastDigitalWrite (PIN_HAVECONTROLLER, haveController);
if (!haveController) {
if (psx.begin ()) {
Serial.println (F("Controller found!"));
delay (300);
if (!psx.enterConfigMode ()) {
Serial.println (F("Cannot enter config mode"));
PsxControllerType ctype = psx.getControllerType ();
PGM_BYTES_P cname = reinterpret_cast<PGM_BYTES_P> (pgm_read_ptr (&(controllerTypeStrings[ctype < PSCTRL_MAX ? static_cast<byte> (ctype) : PSCTRL_MAX])));
Serial.print (F("Controller Type is: "));
Serial.println (PSTR_TO_F (cname));
if (!psx.enableAnalogSticks ()) {
Serial.println (F("Cannot enable analog sticks"));
//~ if (!psx.setAnalogMode (false)) {
//~ Serial.println (F("Cannot disable analog mode"));
//~ delay (10);
if (!psx.enableAnalogButtons ()) {
Serial.println (F("Cannot enable analog buttons"));
if (!psx.exitConfigMode ()) {
Serial.println (F("Cannot exit config mode"));
haveController = true;
if (!psx.read ()) {
Serial.println (F("Controller lost :("));
fastDigitalWrite (PIN_BUTTONPRESS, !!psx.getButtonWord ());
dumpButtons (psx.getButtonWord ());
byte lx, ly;
psx.getLeftAnalog (lx, ly);
if (lx != slx || ly != sly) {
dumpAnalog ("Left", lx, ly);
slx = lx;
sly = ly;
byte rx, ry;
psx.getRightAnalog (rx, ry);
if (rx != srx || ry != sry) {
dumpAnalog ("Right", rx, ry);
srx = rx;
sry = ry;
delay (1000 / 60);
and this is the serial monitor
Controller lost
Controller found!
Controller lost
Controller found!
Controller lost
Controller found!
