help with ps3 controller
hi guys new to this i have a uno +usb shield +servo sensor shield
i have got the controller to talk to usb host on seirial moniter
but am strugling to work the code for controlling the servo via usb host
ps3 bluetooth
if someone could paint me in the right direction
many thanks
neal
what is your problem, what is happening or not happening, where is your code, what is your setup...
this is the code i found and it works on seiral print
what do i do to add the servo shield
to control the servo
 Example sketch for the PS3 Bluetooth library - developed by Kristian Lauszus
 For more information visit my blog: http://blog.tkjelectronics.dk/ or
 send me an e-mail:  kristianl@tkjelectronics.com
#include <PS3BT.h>
#include <usbhub.h>
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#include <SPI.h>
#endif
USB Usb;
//USBHub Hub1(&Usb); // Some dongles have a hub inside
BTD Btd(&Usb); // You have to create the Bluetooth Dongle instance like so
/* You can create the instance of the class in two ways */
PS3BT PS3(&Btd); // This will just create the instance
//PS3BT PS3(&Btd, 0x00, 0x15, 0x83, 0x3D, 0x0A, 0x57); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
bool printTemperature;
bool printAngle;
#if !defined(__MIPSEL__)
  while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
  if (Usb.Init() == -1) {
    Serial.print(F("\r\nOSC did not start"));
    while (1); //halt
  Serial.print(F("\r\nPS3 Bluetooth Library Started"));
  Usb.Task();
  if (PS3.PS3Connected || PS3.PS3NavigationConnected) {
    if (PS3.getAnalogHat(LeftHatX) > 137 || PS3.getAnalogHat(LeftHatX) < 117 || PS3.getAnalogHat(LeftHatY) > 137 || PS3.getAnalogHat(LeftHatY) < 117 || PS3.getAnalogHat(RightHatX) > 137 || PS3.getAnalogHat(RightHatX) < 117 || PS3.getAnalogHat(RightHatY) > 137 || PS3.getAnalogHat(RightHatY) < 117) {
      Serial.print(F("\r\nLeftHatX: "));
      Serial.print(PS3.getAnalogHat(LeftHatX));
      Serial.print(F("\tLeftHatY: "));
      Serial.print(PS3.getAnalogHat(LeftHatY));
      if (PS3.PS3Connected) { // The Navigation controller only have one joystick
        Serial.print(F("\tRightHatX: "));
        Serial.print(PS3.getAnalogHat(RightHatX));
        Serial.print(F("\tRightHatY: "));
        Serial.print(PS3.getAnalogHat(RightHatY));
    // Analog button values can be read from almost all buttons
    if (PS3.getAnalogButton(L2) || PS3.getAnalogButton(R2)) {
      Serial.print(F("\r\nL2: "));
      Serial.print(PS3.getAnalogButton(L2));
        Serial.print(F("\tR2: "));
        Serial.print(PS3.getAnalogButton(R2));
    if (PS3.getButtonClick(PS)) {
      Serial.print(F("\r\nPS"));
      PS3.disconnect();
    else {
      if (PS3.getButtonClick(TRIANGLE))
        Serial.print(F("\r\nTraingle"));
      if (PS3.getButtonClick(CIRCLE))
        Serial.print(F("\r\nCircle"));
      if (PS3.getButtonClick(CROSS))
        Serial.print(F("\r\nCross"));
      if (PS3.getButtonClick(SQUARE))
        Serial.print(F("\r\nSquare"));
      if (PS3.getButtonClick(UP)) {
        Serial.print(F("\r\nUp"));
          PS3.setLedOff();
          PS3.setLedOn(LED4);
      if (PS3.getButtonClick(RIGHT)) {
        Serial.print(F("\r\nRight"));
          PS3.setLedOff();
          PS3.setLedOn(LED1);
      if (PS3.getButtonClick(DOWN)) {
        Serial.print(F("\r\nDown"));
          PS3.setLedOff();
          PS3.setLedOn(LED2);
      if (PS3.getButtonClick(LEFT)) {
        Serial.print(F("\r\nLeft"));
          PS3.setLedOff();
          PS3.setLedOn(LED3);
      if (PS3.getButtonClick(L1))
        Serial.print(F("\r\nL1"));
      if (PS3.getButtonClick(L3))
        Serial.print(F("\r\nL3"));
      if (PS3.getButtonClick(R1))
        Serial.print(F("\r\nR1"));
      if (PS3.getButtonClick(R3))
        Serial.print(F("\r\nR3"));
      if (PS3.getButtonClick(SELECT)) {
        Serial.print(F("\r\nSelect - "));
        PS3.printStatusString();
      if (PS3.getButtonClick(START)) {
        Serial.print(F("\r\nStart"));
        printAngle = !printAngle;
#if 0 // Set this to 1 in order to see the angle of the controller
    if (printAngle) {
      Serial.print(F("\r\nPitch: "));
      Serial.print(PS3.getAngle(Pitch));
      Serial.print(F("\tRoll: "));
      Serial.print(PS3.getAngle(Roll));
#endif
#if 0 // Set this to 1 in order to enable support for the Playstation Move controller
  else if (PS3.PS3MoveConnected) {
    if (PS3.getAnalogButton(T)) {
      Serial.print(F("\r\nT: "));
      Serial.print(PS3.getAnalogButton(T));
      PS3.disconnect();
    else {
        Serial.print(F("\r\nSelect"));
        printTemperature = !printTemperature;
      if (PS3.getButtonClick(TRIANGLE)) {
        Serial.print(F("\r\nTriangle"));
        PS3.moveSetBulb(Red);
      if (PS3.getButtonClick(CIRCLE)) {
        PS3.moveSetBulb(Green);
      if (PS3.getButtonClick(SQUARE)) {
        PS3.moveSetBulb(Blue);
      if (PS3.getButtonClick(CROSS)) {
        PS3.moveSetBulb(Yellow);
      if (PS3.getButtonClick(MOVE)) {
        PS3.moveSetBulb(Off);
        Serial.print(F("\r\nMove"));
        Serial.print(F(" - "));
    if (printAngle) {
    else if (printTemperature) {
      Serial.print(F("\r\nTemperature: "));
      Serial.print(PS3.getTemperature());
#endif
Moderator edit: code tags. Again. I despair
