Hello everyone. I am having a spot of trouble using PuTTY to transfer the information printed on my serial monitor. The data shows up, but there is no timestamp, and I want to transfer the data to Excel. How can I add the timestamp?
I am using an Arduino UNO, and using an Infrared CO2 sensor.
Here is the code:
#include <Wire.h>
#include <SPI.h>
#include <SC16IS750.h>
#include <string.h>
#include <NDIRZ16.h>
SC16IS750 i2cuart = SC16IS750(SC16IS750_PROTOCOL_I2C,SC16IS750_ADDRESS_BB);
NDIRZ16 mySensor = NDIRZ16(&i2cuart);
i2cuart.begin(9600);
if (i2cuart.ping()) {
Serial.println("SC16IS750 found.");
Serial.println("Wait 10 seconds for sensor initialization...");
Serial.println("SC16IS750 not found.");
while(1);
power(1);
//Wait for the NDIR sensor to initialize.
delay(10000);
if (mySensor.measure()) {
Serial.print("CO2 Concentration is ");
Serial.print(mySensor.ppm);
Serial.println("ppm");
Serial.println("Sensor communication error.");
//Power control function for NDIR sensor. 1=ON, 0=OFF
void power (uint8_t state) {
i2cuart.pinMode(0, INPUT); //set up for the power control pin
if (state) {
i2cuart.pinMode(0, INPUT); //turn on the power of MH-Z16
i2cuart.pinMode(0, OUTPUT);
i2cuart.digitalWrite(0, 0); //turn off the power of MH-Z16
//Zero Point (400ppm) Calibration function for NDIR sensor. Only used when necessary.
//Make sure that the sensor has been running in fresh air (~400ppm) for at least 20 minutes before calling this function.
void calibrate() {
i2cuart.pinMode(1, OUTPUT); //set up for the calibration pin.
i2cuart.digitalWrite(1, LOW); //start calibration of MH-Z16 under 400ppm
delay(10000); //5+ seconds needed for the calibration process
i2cuart.digitalWrite(1, HIGH); //toggle the pin HIGH back to normal operation
I need help doing that. I asked many people and they all told me to use PuTTY, as it will put the data into a document. Also, the Arduino UNO has an RTC clock.
If you turn on the timestamp in the Serial monitor, and print a space between subsequent data items then you can copy the output to Excel and use "Text to columns" to split the data into columns
Serial.print(date and time from the clock);
Serial.print(","); // comma separation
Serial.print(a data field);
Serial.print(another data field);
Or as @sterretje has finally pointed out, use a comma. Tabs work for separation of row elements also, it can make the text file easier to read by humans.
I've had a draft saying so for some time... doesn't anyone around here use spreadsheets as much as I do for all kinds things?
My suggestion to use a space was to make the use of Text to Columns as easy as possible but, of course, a comma is equally as good. In fact, if you printed a comma before the first data item and between them you could copy the output to a .csv file and import it directly into Excel
You could, of course, use a terminal emulator such as Coolterm which will add the timestamps and output the data to a file with no need to do the copy/paste
I've Paypalled the author of Coolterm on multiple occasions over the years, enough for (around here) lunch for two at a nice enough restaurant.
I tried the Serial Monitor time stamping some time ago. It didn't do what I needed right away and about 3 minutes of googling research left me back to just using Coolterm for whatever it was I need the times for.
Good a place as any: Does Serial Monitor time sampling work? Are there known limitations?
@cwisgunza is unfortunate enough to be using a Mac otherwise he/she could just use Excel Data Streamer and I am not sure if Coolterm is available for the Mac
I make it look like you said that; it is available on the Mac and I assume since it was developed with REALBasic is more or less identical in function to the other platform versions.
