Help with Radioshack 3d LED cube
Hello,
I a still a novice at hardware and electronics and I just finished the soldering for the the Radioshack 3d LED cube. I tested my arduino uno to make sure it works with example code like blink in the editor. My problem is though, when I plug my cube's board into the arduino the arduino's lights turn off even though it is connected to my computer. Also, I am trying to find the code for the cube because there seems to be a bunch of different versions. I am lost and confused if anyone has any helpful comments I would grately appreciate that.
Thanks for the code! But does anyone know why the arduino dosent light up when plugged into the computer and the LED cube board?
Probably messed up somewhere on the board, causing a short.
