I can't thank you enough for your help! I feel bad asking for more but now I'm trying to add the morse decoder part of the project into the code and I'm not sure what I'm doing wrong. I tried Googling some of the errors but I didn't understand too well.
Here's the morse decoder I'm trying to integrate:
PROGRAM TO DECIPHER MORSE CODE USING A PUSH BUTTON AND DISPLAY IT ON THE SERIAL MONITOR
DATE: 20 JANUARY 2017
AUTHORS: PINAKI SADHUKHAN AND PRIYANKA SADHUKHAN
unsigned long signal_len,t1,t2; //time for which button is pressed
int inputPin = 2; //input pin for push button
int ledPin = 4; //outpu pin for LED
String code = ""; //string in which one alphabet is stored
pinMode(inputPin, INPUT_PULLUP); //internal pullup resistor is used to simplify the circuit
pinMode(ledPin,OUTPUT);
NextDotDash:
while (digitalRead(inputPin) == HIGH) {}
t1 = millis(); //time at button press
digitalWrite(ledPin, HIGH); //LED on while button pressed
while (digitalRead(inputPin) == LOW) {}
t2 = millis(); //time at button release
digitalWrite(ledPin, LOW); //LED off on button release
signal_len = t2 - t1; //time for which button is pressed
if (signal_len > 50) //to account for switch debouncing
code += readio(); //function to read dot or dash
while ((millis() - t2) < 500) //if time between button press greater than 0.5sec, skip loop and go to next alphabet
if (digitalRead(inputPin) == LOW)
goto NextDotDash;
convertor(); //function to decipher code into alphabet
char readio()
if (signal_len < 600 && signal_len > 50)
return '.'; //if button press less than 0.6sec, it is a dot
else if (signal_len > 600)
return '-'; //if button press more than 0.6sec, it is a dash
void convertor()
static String letters[] = {".-", "-...", "-.-.", "-..", ".", "..-.", "--.", "....", "..", ".---", "-.-", ".-..", "--", "-.", "---", ".--.", "--.-",
".-.", "...", "-", "..-", "...-", ".--", "-..-", "-.--", "--..", "E"
int i = 0;
if (code == ".-.-.-")
Serial.print("."); //for break
while (letters[i] != "E") //loop for comparing input code with letters array
if (letters[i] == code)
Serial.print(char('A' + i));
i++;
if (letters[i] == "E")
Serial.println("<Wrong input>"); //if input code doesn't match any letter, error
code = ""; //reset code to blank string
And here's the working chat bot code:
// Example 2 - Receive with an end-marker
const byte numChars = 32;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
Serial.println("Waking up...");
Serial.println("Snoozing the alarm clock...");
Serial.println("Getting coffee...");
Serial.println("Petting the dog...");
delay(2000);
Serial.println("Done!");
Serial.println("Ava: Hi there! I'm Ava; the morse code training bot! I'm designed to help develop your skills in communicating with morse code through conversation. For a list of words or phrases I know, check the README.txt file");
recvWithEndMarker();
if (newData == true)
if (strcmp(receivedChars, "Hello") == 0)
Serial.print("Me:");
Serial.println(receivedChars);
Serial.println("Ava: Hi there!");
else if (strcmp(receivedChars, "Hi") == 0) // ****** added else if to make a if-else if-else chain
Serial.println("Ava: Hello, how are you?");
Serial.println("Ava: Sorry, I don't know that one. Check the README.txt file for a list of words or phrases I know.");
newData = false;
void recvWithEndMarker()
static byte ndx = 0;
char endMarker = '\n';
char rc;
while (Serial.available() > 0 && newData == false)
rc = Serial.read();
// ignore carriage return
if (rc == '\r')
return;
if (rc != endMarker)
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars)
ndx = numChars - 1;
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
Finally, here's my unsuccessful attempt to integrate it:
//MORSE CODE SECTION
// END OF MORSE CODE SECTION
//END OF MORSE CODE SECTION
delay(2000);
NextDotDash:
goto NextDotDash;
{ convertor(); //function to decipher code into alphabet
char readio()
newData = false;
char rc;
rc = Serial.read();
if (rc == '\r')
return;
ndx++;
ndx = numChars - 1;
ndx = 0;
newData = true;
//MORSE COURSE SECTION
void convertor()
int i = 0;
i++;
Thanks again for any help you're willing to provide. I think I'm slowly understanding more how it works.
