Hi All, im in the process of writing a peice of code based off my current one to
1: clean it up and,
2: make it more user friendly.
Here is a link to my github repo
So it mostly works. i can send a command to the Mqtt topic and see whats its receiving Either a "1" for ON or a "0 for OFF"
in this case the topic would be house/switchboard/12/relay/+/command with the + being a single level wildcard for the relay number
so in this example if i wanted to turn relay on i would publish a "1" to house/switchboard/12/relay/1/command
the part i get stuck at is how can i take the single-level wildcard to sort of select a relay channel and then turn it on or off.
currently i use this
if (strcmp(topic, "relay1") == 0) {
if (true) {
Serial.println("Matched");
if ((char)payload[0] == '1')
setLatchChannelOn(1);
Serial.println("Relay 1 triggered ON");
client.publish(mqttStatusTopic, '1');
else if ((char)payload[0] == '0')
setLatchChannelOff(1);
Serial.println("Relay 1 triggered OFF");
client.publish(mqttStatusTopic, '0');
and then i have it listen on 32 MQTT topics which i think is not the best practice.
So this would listen on topic "relay1" for a "1" or a "0" and do the respective action
hopefully that makes sense, i just cant figure out this part of the code
Regards
Bedrock
