Help with remote switches
Hi Guys I'm fairly new to this and could do with some help.
I want to use one nano to send signals to another.
nano one will be a bank of 5 switches
Nano two will copy the output status of each switch.
I want to use the minimum of connections between .
I think I2c is the way to go but I'm not very clued up.
Any suggestions as to where to look for help?
Dave
Why do you need 2 Nanos?
What is the distance between the two boards?
HI folks
2 nanos one tx with switches one as rx and outputs.
About 2mtrs off shielded cable between
I am not understanding what “Nano two will copy the output status of each switch” means.
Sdrwolf:
HI folks
I run about 50 feet of shielded cable, how many meters is that, from a Nano to an anemometer with a reed switch in it. No problems. Your switch with shielded cable should have no problem, either.
Paul
