What is intended is so that when the rotary encoder is turned, the motor turns with it, but if the button is pressed it will not move. This all works, but there is an integer keeping track of how many steps have been taken, and the motor won’t move if passed 0 - 5 (inclusive). The problem lays in that when the button is pressed and the rotary encoder is spun the int still count the movement. Any help would be appreciated!
#include <StepperMotor.h>
#include <Stepper.h>
To be used with Arduino Uno, Step Motor Servo, and Rotary Encoder.
Turn encoder to turn motor, pushing down while turning double steps.
// Stepper Variables
StepperMotor stepper(8, 9, 10, 11);
int totalturn = 0;
long countSteps = 0;
// Encoder pins
int encoderPin1 = 2;
int encoderPin2 = 3;
// Encoder button pin
int encoderSwitchPin = 4;
// Encoder Variables
volatile int lastEncoded = 0;
volatile long encoderValue = 0;
int oldval = 0;
long lastencoderValue = 0;
int lastMSB = 0;
int lastLSB = 0;
int countsafe = 0;
// Limit switch button
int limitSwitchPin = 5;
boolean safetySwitch = true;
void setup(){
Serial.begin (9600); //setup serial for debugging purposes
stepper.setPeriod(5); // Set speed. Smaller = faster
pinMode(encoderPin1,INPUT); //initialize all encoder pins
pinMode(encoderPin2,INPUT);
pinMode(encoderSwitchPin, INPUT);
pinMode(limitSwitchPin, INPUT);
digitalWrite(encoderPin1, HIGH); //turn pullup resistors on for both pins
digitalWrite(encoderPin2, HIGH);
attachInterrupt(0,updateEncoder, CHANGE); //call updateEncoder() when any high/low changed seen
attachInterrupt(1,updateEncoder, CHANGE); //on interrupt 0 (pin 2), or interrupt 1 (pin 3)
digitalWrite(encoderSwitchPin, HIGH); //turn pullup resistor on
digitalWrite(limitSwitchPin, HIGH);
// Updates and converts encoder value
void updateEncoder(){
int MSB = digitalRead(encoderPin1); //MSB = most significant bit
int LSB = digitalRead(encoderPin2); //LSB = least significant bit
int encoded = (MSB << 1) |LSB; //converting the 2 pin value to single number
int sum = (lastEncoded << 2) | encoded; //adding it to the previous encoded value
if(sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011)// Detect direction of encoder
encoderValue ++;
if(sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000)
encoderValue --;
lastEncoded = encoded; //store this value for next time
Serial.println("STAT OF MAIN LOOP");
//TO DEBUG: REMOVE COMMENTS WITH SERIAL.PRINT
Serial.println("VALUE OF ENCODER=");
Serial.println(encoderValue);
Serial.println("VALUE OF OLDVAL");
Serial.println(oldval);
totalturn = 0;
safetySwitch = (digitalRead(limitSwitchPin));
if (safetySwitch==false){
//Serial.println("SAFETYSWITCH FALSE");
countsafe = 1;
stepper.stop(true);
else {
//Serial.println("FINISHED SAFETYSWITCH CHECK, TRUE");
while (safetySwitch==true) {
Serial.println("START OF WHILE LOOP");
//Serial.println("SAFETY SWITCH FALSE IN WHILE LOOP");
countsafe = 1;
break;}
/*if (countSteps>5) { // Soft boundary top
countSteps=5;
if (countSteps<0) { // Soft boundary bottom
countSteps = 0;
/*if (digitalRead(encoderSwitchPin)== false) { // Increase encoder sensitivity when pushed
StepsPerTurn = 1;
else {
StepsPerTurn = 2;
//Serial.println("ABOUT TO RUN IF LOOP");
if (encoderValue-oldval>0 && countSteps > 0 && safetySwitch==true) // Limits movement to 5 CCW Rotation
//Serial.println("POSITIVE TURN LOOP SAFETY SWITCH WAS TRUE");
Serial.print("WTF IS THE VALUE OF COUNTSAFE ");
Serial.print(countsafe);
Serial.println("");
if (countsafe == 0){
totalturn = 50; //steps per turn
stepper.move(totalturn); // Rotate
stepper.stop();
oldval = encoderValue;
countSteps--; // Decrement steps
Serial.println("STEPS TAKEN: "); // Debug
Serial.println(countSteps);
totalturn = 0;
stepper.reset();
else {
Serial.println("COUNTSAFE IS ON, DONT ADD");
countsafe = 0;
else if (encoderValue-oldval<0 && countSteps < 5 && safetySwitch == true) // Limits movement to 5 steps CW Rotation
// Serial.println("NEGATIVE TURN LOOP SAFETY SWITCH WAS TRUE");
Serial.println("");
totalturn = -50; // steps per turn
stepper.stop();
countSteps++; // Decrement steps
totalturn = 0;
stepper.reset();
else {
countsafe = 0;
