help with rotary shaft encoder midi input
hello
i am in the process of building a wooden crank for winding on a video file - a bit like controlling the playhead of the video file but just having a big wooden handle for it (this will be attached to a pair of rollers across which the video will be wound on). I bought a simple rotary encoder with a fairly low resolution but it will do. it counts from 0 to 255 which is great because the way i plan to control the video is through a program called Modul8 and using midi. the playhead is a variable parameter in modul8 that can be mapped to a midi CC value.
I have been playing aroudn with some code I found and bits i have written before, and at the moment the code outputs a count and i can see that it is sending it over MIDI (my midi to usb interface shows an led pulse that matches the rate at which i turn the encoder) however i am not actually receiving any midi into my computer. does anyone have any suggestions of where i might be going wrong?
all help is greatly appreciated
/* Rotary encoder read example */
#define ENC_A 14
#define ENC_B 15
#define ENC_PORT PINC
 byte printing_byte = 0;
 byte incomingByte;
byte note;
byte velocity;
int pot;
byte byte1;
byte byte2;
byte byte3;
  /* Setup encoder pins as inputs */
  pinMode(ENC_A, INPUT);
  digitalWrite(ENC_A, HIGH);
  pinMode(ENC_B, INPUT);
  digitalWrite(ENC_B, HIGH);
  Serial.begin (31250);
 static uint8_t counter = 0;      //this variable will be changed by encoder input
 int8_t tmpdata;
  tmpdata = read_encoder();
  if( tmpdata ) {
    Serial.print("Counter value: ");
    Serial.println(counter, DEC);
    counter += tmpdata;
/* returns change in encoder state (-1,0,1) */
int8_t read_encoder()
  int8_t enc_states[] = {0,-1,1,0,1,0,0,-1,-1,0,0,1,0,1,-1,0};
  static uint8_t old_AB = 0;
  old_AB <<= 2;                   //remember previous state
  old_AB |= ( ENC_PORT & 0x03 );  //add current state
  return ( enc_states[( old_AB & 0x0f )]);
  int8_t tmpdata;
  printing_byte = map(tmpdata, 128, 255, 0, 127);{
  Midi_Send(0xB0, 7, printing_byte);
void Midi_Send(byte cmd, byte data1, byte data2) {
  Serial.print(cmd, BYTE);
  Serial.print(data1, BYTE);
  Serial.print(data2, BYTE);
never mind - managed to get it to work - was sending too much information over serial.
#define ENC_A 14
#define ENC_B 15
 byte incomingByte;
byte note;
byte velocity;
int pot;
byte byte1;
byte byte2;
byte byte3;
 int8_t tmpdata;
  if( tmpdata ) {
    counter += tmpdata;
    printing_byte = map(counter, 0, 1020, 0, 127);
  int8_t tmpdata;
