Help with running a Stepper Motor with L293D IC
Hello,
I have been having a heck of a time getting this simple stepper motor script to run the motor. We have the bi-polar stepper motor ( http://www.sparkfun.com/datasheets/Robotics/SM-42BYG011-25.pdf ) connected to the L293D controller chip in this fashion: http://arduino.cc/en/Reference/StepperBipolarCircuit (4-pin setup) and when it all gets plugged in, the motor shakes pretty hard, and kinda does some random turning back and forth (very hard to describe)… it also seems to do a few steps in any direction I start to force it to go…
I have tried all the combos of the motor wired, thinking I had those connected in the wrong order…
Anyone have any suggestions?
I have tried the two following sketches with the same results:
1:
#include <Stepper.h>
Stepper stepper = Stepper(85, 2,3,4,5);
// set the speed of the motor to 30 RPMs
stepper.setSpeed(30);
void loop(){
stepper.step(9000);
// change this to the number of steps on your motor
#define STEPS 100
// create an instance of the stepper class, specifying
// the number of steps of the motor and the pins it’s
// attached to
Stepper stepper(STEPS, 8, 9, 10, 11);
// the previous reading from the analog input
int previous = 0;
// get the sensor value
// int val = analogRead(0);
// move a number of steps equal to the change in the
// sensor reading
stepper.step(500);
// remember the previous value of the sensor
// previous = val;
well, I got it working… there were some bad connections to the motor and only one coil was energizing…
thanks anyways…
