Help with scientific data logger
Hi everyone:
Since a couple of months ago I have been working in a code for a scientific data logger that can be used to aquire environmental data from the field during months without turning off. The variables I wish to aquire (and the sensors used to achieve this task) are:
  1. Date (DS3231)
  2. Time (DS3231)
  3. Ambient temperatura (AM2305, enclosed)
  4. Relative humidity (AM2305, enclosed)
  5. Soil temperatura (AM2305, enclosed)
  6. Soil humidity (AM2305, enclosed)
  7. LUX index (TSL2561)
The main controller I am using is an ATmega328P, which comes included in the Seeeduino stalker board V2.3 from SEEEDSTUIDO (specs here: Seeeduino Stalker v2.3 | Seeed Studio Wiki). I am using this board not only because it is arduino compatible, but also because:
  • It comes with RTC (DS3231) included and socket for 3.3 CR32032 battery
  • It ALWAYS uses 3.3V, so it is easy to connect 3.3V sensor directly without resistors or level converters
  • It comes with solar cell based LiPo charger and solar cell
  • It comes with JST socket for 3.7V lipo battery
  • It comes with XBEE socket (power can be turned on/off via digital pin 5)
  • It comes with mSD socket directly wired to ISP lines (power can be turned on/off via digital pin 4)
By itself, this board is supposed to offer a stand alone platform to log data for long periods in practically any environment (if you use it with its plastic waterproof enclosure), so the only thing I did was to add a TSL2561 sensor to it via GROVE (Stalker comes with 2.0mm grove connector for I2C peripherals) and a couple of enclosed AM2305 sensors directly soldered to board's pins (D7 and D8, also available via 2.0mm grove connector directly from the board).
I have been working hard in the coding part and, till moment I have achieved some good results. Nevertheless, a couple of weeks ago I decided to ask for profesional help with an external consultant and he came up with this code:
#include <avr/sleep.h>
#include <avr/power.h>
#include<SPI.h>
#include <Wire.h>
#include <SD.h>
#include <DS3231.h>
DS3231 RTC; //Create RTC object for DS3231 RTC come Temp Sensor
#include "RTClib.h"
RTC_DS3231 rtc;
#include <dht.h>
dht DHT44b;
dht DHT44a;
#define DHT44b_PIN 8
#define DHT44a_PIN 7
#include <Digital_Light_TSL2561.h>
//static uint8_t prevSecond=0;
static DateTimeDS interruptTime;
//const int chipSelect = 10;
char minute_m = 0;
char minute_l = 0;
/*Initialize INT0 pin for accepting interrupts */
PORTD |= 0x04;
DDRD &=~ 0x04;
pinMode(4,INPUT);//extern power
// RTC.begin();
Wire.begin();
rtc.begin();
rtc.adjust(DateTime(F(DATE), F(TIME)));
TSL2561.init();
pinMode(5, OUTPUT);
digitalWrite(5,HIGH);
pinMode(10, OUTPUT);
SD.begin(10);
delay(2000);
Serial.println("PLEASE ENTER SAMPLING TIME IN MINUTE :)");
Serial.println(" ");
delay(3000);
while( !(Serial.available() > 0));
minute_m = Serial.read();
Serial.print(minute_m);
minute_l = Serial.read();
Serial.print(minute_l);
// minute_m = 0x30;
// minute_l = 0x37;
minute_m -= 0x30;
minute_l -= 0x30;
minute_m = (minute_m*10) + minute_l;
attachInterrupt(0, INT0_ISR, LOW); //Only LOW level interrupt can wake up from PWR_DOWN
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
//Enable Interrupt
//RTC.enableInterrupts(EveryMinute); //interrupt at EverySecond, EveryMinute, EveryHour
// or this
DateTimeDS start = RTC.now();
interruptTime = DateTimeDS(start.get() + 5); //Add 5 mins in seconds to start time
delay(3000);
digitalWrite(5,LOW);
int counter = 0;
DateTime now = rtc.now();
delay(100);
DHT44b.read44(DHT44b_PIN);
delay(100);
DHT44a.read44(DHT44a_PIN);
delay (100);
Serial.print("Sample: ");
Serial.println(counter);
Serial.print("Date: ");
Serial.print(now.day(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.println(now.year(), DEC);
Serial.print("Hour: ");
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.println(now.second(), DEC);
Serial.print("LUX index: ");
Serial.println(TSL2561.readVisibleLux());
Serial.print("Ambient temperature: ");
Serial.print(DHT44b.temperature, 1);
Serial.println(" *C ");
Serial.print("Relative humidity: ");
Serial.print(DHT44b.humidity, 1);
Serial.println(" %");
Serial.print("Soil temperature: ");
Serial.print(DHT44a.temperature, 1);
Serial.print("Soil humidity: ");
Serial.print(DHT44a.humidity, 1);
delay (100);
File dataFile = SD.open("datalog.txt", FILE_WRITE);
if (dataFile)
dataFile.print(" Sammple: ");
dataFile.print(counter);
dataFile.print(",");
dataFile.print(" Date: ");
dataFile.print(now.day(), DEC);
dataFile.print('/');
dataFile.print(now.month(), DEC);
dataFile.print(now.year(), DEC);
dataFile.print(" Hour: ");
dataFile.print(now.hour(), DEC);
dataFile.print(':');
dataFile.print(now.minute(), DEC);
dataFile.print(now.second(), DEC);
dataFile.print(" LUX index: ");
dataFile.print(TSL2561.readVisibleLux());
dataFile.print(" Ambient temperature: ");
dataFile.print(DHT44b.temperature, 1);
dataFile.print(" *C ");
dataFile.print(" Relative humidity: ");
dataFile.print(DHT44b.humidity, 1);
dataFile.print(" %");
dataFile.print(" Soil temperature: ");
dataFile.print(DHT44a.temperature, 1);
dataFile.print(" Soil humidity: ");
dataFile.print(DHT44a.humidity, 1);
dataFile.println("");
dataFile.close();
Serial.println("");
Serial.println("UNABLE TO LOG DATA");
Serial.println("");
counter++;
/////////////////////////////////////////////////////////////////////////////////////////////////////////SLEEP MODE START
/* DateTimeDS nowDS = RTC.now(); //get the current date-time
if((now.second()) != prevSecond )
//print only when there is a change
Serial.print(nowDS.year(), DEC);
Serial.print('/');
Serial.print(nowDS.month(), DEC);
Serial.print('/');
Serial.print(nowDS.date(), DEC);
Serial.print(' ');
Serial.print(nowDS.hour(), DEC);
Serial.print(':');
Serial.print(nowDS.minute(), DEC);
Serial.print(':');
Serial.print(nowDS.second(), DEC);
Serial.print(" ");
prevSecond = nowDS.second();*/
RTC.clearINTStatus(); //This function call is a must to bring /INT pin HIGH after an interrupt.
RTC.enableInterrupts(interruptTime.hour(),interruptTime.minute(),interruptTime.second()); // set the interrupt at (h,m,s)
attachInterrupt(0, INT0_ISR, LOW); //Enable INT0 interrupt (as ISR disables interrupt). This strategy is required to handle LEVEL triggered interrupt
cli();
sleep_enable(); // Set sleep enable bit
sleep_bod_disable(); // Disable brown out detection during sleep. Saves more power
sei();
power_all_disable(); //This shuts down ADC, TWI, SPI, Timers and USART
sleep_cpu(); // Sleep the CPU as per the mode set earlier(power down)
sleep_disable(); // Wakes up sleep and clears enable bit. Before this ISR would have executed
power_all_enable(); //This shuts enables ADC, TWI, SPI, Timers and USART
/////////////////////////////////////////////////////////////////////////////////////////////////////////SLEEP MODE END
delay (3000);
void INT0_ISR()
detachInterrupt(0);
unsigned char temp_delay = 10;
interruptTime = DateTimeDS(interruptTime.get() + 60); //decide the time for next interrupt, configure next interrupt
The problema is that, even when he has no problems running the firmware in the exactly same components, I just cannot compile it. The coding erros seem to be very simple, but I just cannot fix them. Any ideas? I attach the arduino libraries that are needed to run the sketch.
Thank you in advance,
J
LIBRERIAS ARDUINO.zip (111 KB)
Please edit your post and add code tags ("</>" button). See the "How to use this forum" post.
Also add the error messages.
Most people will not download or open a .zip file.
OpenAGRO:
Hi everyone:
It seems to me that if you paid an external consultant then the code should work.
OpenAGRO:
The problem is that, even when he has no problems running the firmware in the exactly same components, I just cannot compile it. The coding errors seem to be very simple, but I just cannot fix them.
No matter how simple the coding errors seem to be, you keep them secret, and nobody will ever be able to help you until they know what they are. Assuming that the code is indeed kosher, the problem probably has more to do with where the libraries are kept than what they are.
It seems that there is a name conflict in DateTime declared either in DS3231.h and RTClib.h
