Help with Scoping
Just started with the Arduino, finding 'scoping' a bit of an issue, usually code via assembler or Basic. So my problem is that I'm trying to write/convert a library for product I already have using a PIC, and I can't for the life of me sort out scoping errors. I have an ISR I want to place in the library but it produces a scoping error for the variables it uses. I also get scoping errors when I try to initialize variables in the .cpp, especially arrays either empty or filled with values.
Any help or guidance would be gratefully received, copy of files below:
Copy of sketch:
//EGamer tester for Library
//Includes
#include <avr/pgmspace.h>
#include <Egamer.h>
Egamer Eg;
//Setup Vars
volatile int Trac = 0;
//Screen variables
byte Display[8];
byte MatCol[] = {40,0,8,24,16,32,48,56};
byte Backg[24];
byte TxtLayer[8];
byte Xpos = 0;
byte Ypos = 0;
//Setup constants
const byte Splash[] PROGMEM = {31,21,21,0,255,129,133,199};
//Main setup function
  Eg.Config();
  //eGamer Splash Screen
  for (int i = 0; i < 8; i++){
    Display[i] = pgm_read_byte(&Splash[i]);
//ISR here
ISR(TIMER1_COMPA_vect)
    PORTD = Display[Trac];
    PORTC = MatCol[Trac];
    Trac++;
    Trac &= B00000111;
//Main loop
    Display[i] = ~Display[i];
Copy of the .h file
eGamer.h - Library for the eGamer Shield
Created by Brian P Smith, 26.08.11.
#ifndef Egamer_h
#define Egamer_h
#include "WProgram.h"
class Egamer {
public:
  void Config(void);
private:
#endif
Copy of the .cpp file
eGamer.cpp - Library for the eGamer Shield
#include "Egamer.h"
extern "C"
#include <avr/io.h>
#include <avr/interrupt.h>
#include <inttypes.h>
void Egamer::Config(void)
  //Setup ports for the display, buttons, joystick & audio
  //PortD = Row data - 76543210
  DDRD = B11111111;
  //PortC = Column + Buttons - xxCBAxba
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  pinMode(A2, INPUT);
  pinMode(A3, OUTPUT);
  pinMode(A4, OUTPUT);
  pinMode(A5, OUTPUT);
  //PortB = Joystick +6 Audio - xxACuldr
  DDRB = B00110000;
  //Basic interrupt system
    // Disable interrupts while setting registers
    cli();
    // Reset control registers
    TCCR1A = 0;
    TCCR1B = 0;
    TCNT1 = 0;
    // Interrupt every 16000000/256/400Hz, 1 column per call
    OCR1A = 150;
    // Clear Timer on Compare Match (CTC) Mode
    bitSet(TCCR1B, WGM12);
    // Prescaler x1024
    //bitSet(TCCR1B, CS10);
    //bitSet(TCCR1B, CS11);
    bitSet(TCCR1B, CS12);
    // Use system clock for Timer/Counter2
    //bitClear(ASSR, AS2);
    // Reset Timer/Counter2 Interrupt Mask Register
    //TIMSK1 = 0;
    // Enable Output Compare Match A Interrupt
    bitSet(TIMSK1, OCIE1A);
    // Enable interrupts once registers have been updated
    sei();
Moderator edit: Code boxes instead of quotes to remove spurious italics.
That's everything but the error messages...
Ok, if I put the ISR into the .cpp file and the the arrays Display[8] and MatCol[8], the error I get is Display not known in this scope, ditto for MatCol. I have tried to follow a couple of examples but always have the same problem that any variables or arrays identified in the .h and created in the .cpp file always give scoping errors. Is there a specific method to set them up, I'm ok with the idea of private and public but I feel I'm missing something that different to my usual environments.
The ISR have tried to add the the .cpp is:
    Trac++;
    Trac &= B00000111;
The error that I get is:
C:\Program Files\Arduino\arduino-0022\libraries\Egamer\Egamer.cpp: In function 'void __vector_11()':
C:\Program Files\Arduino\arduino-0022\libraries\Egamer\Egamer.cpp:60: error: 'Display' was not declared in this scope
C:\Program Files\Arduino\arduino-0022\libraries\Egamer\Egamer.cpp:60: error: 'Trac' was not declared in this scope
C:\Program Files\Arduino\arduino-0022\libraries\Egamer\Egamer.cpp:61: error: 'MatCol' was not declared in this scope
If I try to add them to the .h file and create them in the .cpp, I get the same error, I must be missing a connection between the two files in how variables are identified and subsequently created.
Thanks
This statement is incompatible with declaring variables in the sketch. In your example, you are declaring the variables Display and MatCol in the sketch.
The sketch is in a completely different file, so if you want to reference them in the class (not a good idea, by the way), you need an extern statement in the source or header file that tells the compiler that these variables are defined in another file. The linker will then resolve where they are really defined.
Better, though, would be to define a reference to them in the class, and have the sketch call a method of the class to define the actual arrays to use.
A library should not have/require intimate knowledge of the calling code.
Edit: Skip a bunch of that stuff above. I reread the code, and I see that you are writing code to define the behavior of an ISR in an external (to the sketch) file. Not a great idea, in my opinion.
A sketch should use a library like a black box. Having the library, not the sketch, own the interrupt handler violates that separation, in my opinion.
From your comments I would be better keeping the ISR in the sketch but have it call a method in the library and have the two arrays defined in the library? The only problem I have encountered here is define variables in a library, I assume in the .h file I define as a name and create, dimension and assign values in the .cpp file? Thanks for the guidance I think I'm seeing how it fits together.
Yes.
The variable is defined (given a type, size, and name) in the header file. It is assigned values in the in the source file.
Thanks PaulS, I think I might be able to crack this issue now, I'll let you know how I get on later in the week.
