Help with score keeper
Hi Everyone,
I’m having a few issues with my circuit and hoping someone could help. I’ve uploaded a copy of the code, a picture of the circuit, and a picture from Tinkercad.
Issue 1:
I have three buttons:
  • left one increases the number on the display by one
  • middle resets number on display to zero
  • right one decreases the number on the display by one
In Tinkercad, my circuit and code work as desired but when I upload to the Uno, the decrease button actually resets the display to zero.
Issue 2:
When the number displayed is zero, it requires two pushes of the increase button
The file is a little slow to run on tinkercad, the delays help out some. I removed the delays when uploading to the Uno.
Thank you in advance for the help on my very first post.
single_digit_7_segment_with_buttons1.ino (3.8 KB)
Please read How to use this forum - please read how to post code (your code is small enough) and images.
I will ask a moderator to move this to a more suitable section as "installation and troubleshooting" is not meant for questions about your project.
I don’t think I’m surprised; the right button in your graphics connects to pin 11 which is the reset button according to your code.
OP’s ‘schematic’
Anyone have the code to post ?
lastchancename:
/*    7 segment display layout
              A
            _____
         F |     | B
           |__G__|
         E |     | C
           |_____|
              D
#define a 2
#define b 3
#define c 4
#define d 5
#define e 6
#define f 7
#define g 8
#define button1 9
#define button2 10
#define reset 11
int eb1;
int eb2;
int eb3;
int eab1;
int teamOneScore;
void setup(){
  pinMode(a,OUTPUT);
  pinMode(b,OUTPUT);
  pinMode(c,OUTPUT);
  pinMode(d,OUTPUT);
  pinMode(e,OUTPUT);
  pinMode(f,OUTPUT);
  pinMode(g,OUTPUT);
  pinMode(button1,INPUT_PULLUP);
  pinMode(button2,INPUT_PULLUP);
  pinMode(reset,INPUT_PULLUP);
  teamOneScore=0;
    digitalWrite(a,HIGH);
    digitalWrite(b,HIGH);
    digitalWrite(c,HIGH);
    digitalWrite(d,HIGH);
    digitalWrite(e,HIGH);
    digitalWrite(f,HIGH);
    digitalWrite(g,LOW);
void loop(){
  eb1=digitalRead(button1);
  eb2=digitalRead(button2);
  eb3=digitalRead(reset);
  if(eb1==LOW && eab1==HIGH){
    teamOneScore++;
  eab1=eb1;
  if (eb3==LOW && eab1==HIGH) {
    teamOneScore--;
  eab1=eb3;
  if(eb2==LOW){
    teamOneScore=0;
  switch (teamOneScore) {
    //zero
    case 1:
    digitalWrite(a, HIGH);
    digitalWrite(b, HIGH);
    digitalWrite(c, HIGH);
    digitalWrite(d, HIGH);
    digitalWrite(e, HIGH);
    digitalWrite(f, HIGH);
    digitalWrite(g, LOW);
    delay(200);
    //one
    case 2:
    digitalWrite(a, LOW);
    digitalWrite(d, LOW);
    digitalWrite(e, LOW);
    digitalWrite(f, LOW);
    delay(200);
    //two
    case 3:
    digitalWrite(c, LOW);
    digitalWrite(g, HIGH);
    delay(200);
    //three
    case 4:
    delay(200);
    //four
    case 5:
    delay(200);
    //five
    case 6:
    digitalWrite(b, LOW);
    delay(200);
    //six
    case 7:
    delay(200);
    //seven
    case 8:
    delay(200);
    //eight
    case 9:
    delay(200);
    //nine
    case 10:
    delay(200);
    default:
    teamOneScore=0;
    delay(200);
Try moving
eab1=eb1; inside the if() block.
and why eab1=eb3;
