I am working on my first real project. I am having trouble with part of the script. Basically the script reads 5 analog input values, averages them, and displays it on the terminal. It displays the first 2, then it restarts. I've annotated on the code where is quits working. Thanks in advance.
int i = 0;
int j = 0;
int analog_raw = 0; //var
int analog_in = 1;
int low_final = 0;
int low_array[5];
int mid_final = 0;
int mid_array[5];
int high_final = 0;
int high_array[5];
//Start zero Cal.
Serial.println("Set Joystick to zero");
for (i=0; i<=5; i++){
analog_raw = analogRead(analog_in);
low_array[i] = analog_raw;
for (i=0; i<=4; i++){
j=i+1;
low_array[j] = low_array[i] + low_array[j];
low_final = low_array[4];
low_final = low_final/5;
Serial.println(low_final);
delay(3000);
//Start midpoint Cal.
Serial.println("Set Joystick to midpoint");
mid_array[i] = analog_raw;
j=i+1;
mid_array[j] = mid_array[i] + mid_array[j];
mid_final = mid_array[4];
mid_final = mid_final/5;
Serial.println(mid_final);
delay(3000);
//Start high Cal.
Serial.println("Set Joystick to high");
Serial.println("Test1"); // Displays OK
high_array[i] = analog_raw;
Serial.println("Test2"); // Does not display from here on
j=i+1;
high_array[j] = high_array[i] + high_array[j];
high_final = high_array[4];
high_final = high_final/5;
Serial.println(high_final);
delay(3000);
//Print results
Serial.print("Low value is ");
Serial.print("Mid value is ");
Serial.print("High value is ");
